Question about Hotpoint NBXR463EBWW Electric Dryer
Low Heat - Hotpoint NBXR463EBWW Electric Dryer
  • 121 Answers
You may be running one side of your 240
if its electric please do a voltage on both sides of your plg to make sure your getting 240
Posted on Jun 18, 2009
ML-3051N samsung printer saying Low Heat Error what do I do?
http://www.fortwayneprinterrepair.com/wordpress/2013/04/10/samsung-ml-3051nd-low-heat-error/
Aug 28, 2014 | Samsung ML-3051N Laser Printer
Tip
HOW TO REDUCE CHANCES OF H4 CODE IN SHARP COPIERS
The code H4 is common to all Sharp copiers. This occurs due to abnormal low temperature being sensed by thermistor. This means that the heater lamp which generates heat around the fuser rollers is either not working or producing very low heat. Low heat generated comes from low power output in the mains so, when you suspect low voltage, always switch off your copier and wait for normalcy. You can see from dim bulbs and know that's low voltage.
on Dec 02, 2009 | Office Equipment & Supplies
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Low heat
Dryers either heat or they don't heat. Complaints of "low heat" are always due to a restriction in the venting system.
There is either a clog in the hose somewhere or the hose is smashed. There could be an obstruction at the exit outside or the hose runs longer than 12 feet before exiting the house, to name a few.
Mar 09, 2014 | Magic Chef Dryers
2007 montana - low rpm - under 1k - no heat.
Make sure you radiator is full. There are 2 bleeder screws for that engine because its really hard to get all the air out. If its low or has too much air in it, you won't have any heat at low rpms.
Second thing is that your heater core may be a little stopped up and needs flushed, or replaced.
Thirdly, i've noticed that the Montanas don't put out a lot of heat if you're setting. But you should have some heat to keep you warm. No heat is no good.
Jan 09, 2013 | 2007 Pontiac Montana
Kennmore Elite HE4 no heat on low or extra-low setting
Assuming this is a gas dryer, it is likely the igniter has failed. The igniter plate has to heat up to glowing in order to heat up the thermocouple that turns on the gas valve.
Sep 03, 2012 | Kenmore Dryers
Hi Sir my heatbgun is still starting but the problem is its air takes time to heat even if i turn its heat control to the max . What could be its problem?
Usually you should have heat very quickly. I can think of a few things that might cause low heat. One would be a low power level at the outlet. The other might be the heater element is just about worn out. And third is the power or heat selector switch is faulty.
I've seen the low heat from low power caused by too long extension cords as well as low power levels. Try plugging into a different outlet and directly and see if it heats up normally.
Unfortunately if it is a problem with the heater element or the switch unless you are under warranty you would have to buy a new unit. If you have warranty then you should contact the store you purchased or McCulloch about getting it replaced.
Sep 02, 2011 | McCulloch Heat Gun Kit
PRINTER LOW HEAT ERROR
Low heat means either the fuser is not heating up or it is not sensed properly. you can find a new fuser at www.precisionroller.com but the low voltage power supply could be bad as well.
Oct 29, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Hotpoint NBXR463EBWW Electric Dryer Logo
70 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
