Question about Jensen VM9410 Car DVD Player
Bypassing E-Break How do I bypass the emergency break connection on my Jensen VM9410 in-dash CD/DVD Head-Unit? Also are there any codes available? Thanks, Randy
    Problem Solver:
  • 12 Answers
Just connect the emergency brake wire to earth (vehicle body)
Posted on Jun 17, 2009
Bypass brake wire so screen allways play I have a wm9212n Jensen system I reloaded default settings now it requires me to place the parking break to watch the dvd
connect the red wire to the negative on your battery run it straight to it and it will always play so you don't have to pull up your e~brake
May 29, 2009 | Jensen VM9410 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 23, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
I installed my in dash my self but i dont know how to bypass the e brake screen?
Aug 18, 2008 | Car Audio & Video
Hooking up the parking brake sequence
There are no "bypass codes". Making the unit work without the handbrake is a wiring issue, and it's easy. I highly suggest doing it this way to make the player much more useable.
Aug 11, 2008 | Jensen VM9510 Car DVD Player
HOW DO I BYPASS THE EMERGENCY BRAKE WHEN INSTALLING A VM1412
Aug 03, 2008 | Jensen VM9410 Car DVD Player
JENSEN VM9311TS DO I HAVE TO HOOK THE BRAKE WIRE UP AT ALL?
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jul 26, 2008 | Jensen VM9411 Car Video Player
Bypass code
Jul 15, 2008 | Jensen VM9411 Car Video Player
I dont have a code 4 my jensen vm9410 i need 1
wire the parking break wire from the deck to the ground and it will work like a charm, until your crappy vm9410 all of sudden won't turn on any more :( It seems no one has a solution for that PROBLEM!!
Feb 03, 2008 | Jensen VM9410 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9410 Car DVD Player Logo
271 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
