Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
Don't know what side allen key to use on danze D456513SS to fix a leak?
  • 3 Answers
Buy a cobination set of allen keys usually between 1mm to 10mm and use the one that fits
Posted on Jun 17, 2009
How do i remove handle from danze kitchen faucet?
Google Danze kitchen faucet diagrams and it shows the intricate parts of different faucets
May 03, 2014 | Danze Plumbing
Bannockburn handle removal
lots of these types of handles have a very small allen wrench set screw somewhere under the handle or on the side...loosen set screw and pull off...good luck
Sep 22, 2012 | Danze & Single Handle Tub And Shower...
I have a single handle Danze shower. I can't turn on the water. The handle just turns all the way around.
sounds like handle is not engaged....pull handle...may need allen wrench...after handle is off see if you can turn water on with pliers...should go from right to left...if that works...install handle and tighten with allen wrench....handle should set from off area...see if handle is stripped out or not on proper...if need new handle...pick up at lowes or plumbing supply...good luck
Jan 16, 2011 | Danze & Single Handle Tub And Shower...
Lever won't stay on at low flow rate; lever closes automatically. What can I do to fix it?
Sounds like the retaining ring under the handle may need to tighten a little to stiffen lever a little. To remove handle take plastic red/blue cap at base of lever covering the screw. Remove allen screw that holds handle to base with a allen wrench.
Try to tighten collar that holds the stem for the lever and that should help with the lever. if not the gasket that's under the collar maybe wore to the point that tightening want effect it.
If you need a parts diagram go to this link for an exploded view of the internal parts. I hope this will be helpful to you.
http://www.needplumbingsupplies.com/Danze/Specs/D403412_Inst.pdf page 4 has a breakdown.
Dec 29, 2010 | Danze D403412 Melrose Single Handle...
We do not have book on the kitchen faucet which was purchased by a previous owner. Looks just like the Danze D306357BN. It is leaking from the first joint above the base. A plumber could only tell us that...
there are several O-rings inside the spout assembly. 3 that I know of from memory.<br /> <br /> here is a link to the PDF parts breakdown to show your plumber. also that faucet is for the bathroom sink.<br /> <a href="http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN">http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN</a><br /> the link to the PDF is at the bottom of the page "illistrated parts list" <br /> <br /> here is the link to the kitchen faucet. just click on the "illistrated parts list" to get the breakdown.<br /> <a href="http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357">http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357</a><br /> <br /> if neither one of these is your faucet, just continue looking through till you find yours, and call a different plumber.<br /> <br /> hope that helps<br />
Aug 31, 2010 | Danze Plumbing
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
How to get the handle off , it is very loose
Should be a little round button to pry out at lower part of handle itself, and likely an Allen key behind it to loosen off and remove, or tighten to snug up handle.
Jan 21, 2010 | Danze D403412 Melrose Single Handle...
Danze shower fixture issue
If it is a single handle there should be an access hole to the under side of the handle that will allow access to a allen style set screw, loosen it and the handle can be removed.
Feb 21, 2009 | Danze D500540BNT Brushed Nickel Fairmont??...
Leaking single lever kitchen tap
on most of the single handle faucets there is an erasure like button ( may have a hot and cold blue and red indicator or be silver ) usually located right under the faucet arm on the manifold chrome sleeve or back behind the arm or it could have a large ring nut over the doam of the lever take your hand and feel the area that covers the area where the spout arm swivels and feel for the button or take your fingers and fel the to of the lever doam
if you find the button just take a sharp screw driver( be sure to plug the drain holes and turn hot and cold water off under sink) pry the button off and use a hex wrench and loosten
if no button then there has to be a large nut on top you may seee two grooves oppsoite each other wheich would mean a special tool
use an adjustable wrench (put cloth ofer chrome to protect and turn counter clock wise( the ring nut will not be very thick
after removing you should be able to replace the cartridge
good luck
Dec 30, 2008 | Danze D403412 Melrose Single Handle...
Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
531 people viewed this question
Top Danze Plumbing Experts
john h
Marvin
Marvin
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
