Question about Nintendo NES Console
NES controllers won't work!
My NES, that I just bought had 2 controllers and 16 games, but that doesn't matter. Anyways when I want to play two player in Mario the down button won't go down to 2 players, same with Ikari Warriors. But wierdly it works on Dr. Mario. Can anyone help!!!???
  • 36 Answers
Using the select button will switch between the options.
Posted on Aug 02, 2009
Buy new ones off amazon
Posted on Jul 03, 2009
When playing Mortal Kombat II second player keeps "popping" into game even though only one controller is hooked up?
Well try cleaning the game pack out with quips and rubbing alchoal it could just be dirty then or the worst case is that the game pack could have internal issues Check for Unlicensed products. Make sure that you're using only licensed products with your Nintendo system. Unlicensed products are not tested for compatibilty and may not work correctly with all games. Try playing the game without the unlicensed accessory.
Insert the Game Pak into the system. The Game Pak label should be facing the front of the machine (or facing up if you are using an original NES).
Make sure the Game Pak firmly clicks down into place.
Remove all accessories to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
Check the instruction manual for the game to see if it requires any special accessories to operate (such as the Super Scope, NES Zapper, SNES Mouse, etc.).
Do not blow into your Game Paks or systems. The moisture in your breath can corrode and contaminate the pin connectors.
Apr 20, 2013 | Nintendo Super NES Console
Sounds not working on super nintendo
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.well I guess that you will have to hook it up to a DVD player or a VCR player to have it work on a digital tv
Note: pictured above is the original Super NES. The redesigned Super NES uses the same hookup steps listed below.
Installation Steps:
Locate the Audio/Video inputs on the back of the VCR.
Place the yellow end of the Stereo AV Cable into the Video "in" on the back of the VCR.
Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono VCR with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV Cable into the "multi out" connector on the back of the Control Deck.
After system is connected to the VCR:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Slide the Power Switch on (toward Game Pak).
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen. You are ready to play!
Recording Game Play
Set up the Super NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Jan 31, 2013 | Nintendo Super NES Console
My nintendo wont work the controllors i bought new ones
Well it sounds like the controllers might be defective then you could clean the controllers out with rubbing alcohal and qutips and soft cloth and use a tooth brush too to clean them out. Buy controllers from lukie games then or jj games.
Nov 01, 2012 | Nintendo Super NES Console
Snes doesn't read games
Well it sounds like the console it's self needs to be cleaned out then 4.5 mm bit screw driver to open her up lukue games sell those 4.5 mm game bit tool compressed air to clean it out and it should work
Sep 29, 2012 | Nintendo Super NES Console
Super Mario game loads, the battery-operated wireless controllers do absolutely NOTHING. Cannot start the game -- get it onscreen and it goes through its little demo but the controllers just won't get...
I don't know a lot about this console (the Retron 3), but the game sounds like it works fine, try using a different third-party console, I recommend the Retro Entertainment System, it's only around $20 - $25 on eBay, try a different NES game, if it doesn't work, than it's probably the controllers, get replacements, or the batteries are dead.
May 06, 2011 | Hyperkin Wireless Retron 3 Video Gaming...
The red light flashes on my NES and on the TV screen, it keeps on changing colors. Do you know whats wrong?
The NES is touchy like that, sadly-- your problem isn't uncommon. My NES, and the NES of nearly every friend I have who still owns one, plays this little trick on them from time to time. Here's what we do:
1. Turn off the NES console.
2. Blow into bottom of the game, near the chip that connects to the NES.
3. Wipe away any excess dust from the game itself.
4. Blow into the console of the NES.
5. Wipe away any excess dust.
6. Re-insert the game and try again.
If this doesn't work, try placing the game in more delicately, or with more force. It's just a matter of trial and error, and sometimes it will work faster than others. Hope this helped!
Mar 12, 2011 | Nintendo NES Console
Grand campaign is impossible to play no matter what empire chozen
Play on the easiest difficulty. Plus Total War games are designed to epically difficult
Jun 12, 2010 | Sega Medieval II: Total War for Windows
My nintendo nes works fine but when i put in mario/duck hunt i can choose which one i want to play and when i choose mario it gose to the next screen where you choose 1 or 2 players and this is where i...
Will try cleaning the game packs out with quips and vinegar try connecting it to a DVD player or a VCR then.
Installation Steps:
Locate the VCR's VHF IN [ANT, CATV, 75S(ohm)] or Cable Connector.
Disconnect the existing cable wire from the VCR's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your VCR's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire from the RF Switch (labeled Control Deck) to the back of the NES (labled RF Out).
On the back of the NES, set the 3/4 switch so that it matches the channel of the VCR.
After the system is connected to the VCR:
Plug the controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Press the Power button on the front of the Control Deck.
Turn your TV and VCR on. Set up your TV and VCR the same way you would to watch a movie on the VCR.
The game image should now be displayed on the TV screen.
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Apr 14, 2010 | Nintendo NES Console
Snes works at game testing store, but not my tv. What's going on?
Nintendo solved the problem with the whole "you gotta blow the dust off the card and jam the game in right to play" thing when they brought out the SNES.
But in time, well, you gotta blow off the games.
Use your old NES Ninja tricks to get it to work. Blow the games out, blow out the slot. It should make it work.
Good luck man!
-Captain Jake
Feb 07, 2009 | Nintendo Super NES Console
NES console - white or green tv screen
first off flip your nes upside down and remove the screws to the cover of nes..... then flip your nintendo over and remove the cover.... remember you just voided your warranty for your nes..... then proceed to do the following:
find Chip 3193A and find the 4th pin on the left hand side near the blue coils. Remove or pull back the pin and your NES Will play Pal and NTCS games.
Sep 17, 2008 | Nintendo NES Console
Nintendo NES Console Logo
405 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
