Question about Pc Ware M748LMRT Motherboard
FTR 9965/12 The screen will not come on, no VGA signal! We have looked over the connections and can´t find anything wrong!
  • 79 Answers
Hi there ,
What you can try is to boot in SAFE-Mode, by pressing the F8 key on your keyboard more continiously when turning on your pc, If you are able to view the desktop in safe mode, then you must set your screen resolution lower, but if still no display, then your display adapter might be faulty, check your RAM, remove and re-insert them into the motherboard...try that......Let me know how it went
Regards
Techmor
Posted on Jun 18, 2009
  • Morne Swart Jun 18, 2009
    Hi there ,
    Regards
    Techmor
Need to install replacement monitor on laptop. Need to know how.
Look for the VGA output, there you'll connect the external CRT or LCD monitor signal cable (VGA input), at the funtions keys (F1 to F12) find the one that has a monitor or screen icon, it activates using the Fn and the found funcion key.
If you are replacing the LCD panel, the first step is to check if the screen frame has covered screws (commonly there are two), if it doesn´t have them, the frame is only set by inner clamps and can be separated with your nails and fingers carefully, after removing the screen frame you'll have access to LCD panel that is assembled usually in a metal frame, look for all the screws that hold panel, also carefully identify and disconnect all the cables that the panel uses. Look for the LCD panel model, but also you can buy it using the make and model of your laptop, to install it follow the reverse steps of above.
Mar 13, 2011 | Computers & Internet
I own a Toshiba NB 205 Notebook PC. I connected my flat screen TV to the notebook so I can use the TV as the Toshiba's monitor. I purchased a male-to-male VGA cable and plugged it into the VGA port on...
you need to tell the computer to move the signal over ---look for a picture of 2 tv screens on the laptop usually F5 or F8 (use with Fn key)otherwise right click on the desktop>choose PROPERTIES>SETTINGS
Jan 01, 2011 | Toshiba Computers & Internet
Screen stays black
Get a vga cable and connect it to the side of the laptop, or where you can see the vga connection then send signal to either a monitor/ tv (if they have a vga connection).
by doing this you will be able to find out if its the screen that is faulty or the graphics card.
if you cant see anything else on external screen then its either the graphics card or the laptop motherboard.
if you can view pic, then its the screen, then you can decide if its worth replacing?
Oct 15, 2010 | Toshiba Satellite P305D-S8818 Notebook
No VGA signal from my Lenovo laptop to the tv
Most notebook computers can be "toggled":
* video-output only to LCD screen
* video-output only to external VGA
* video-output to both device
Be sure that you toggle to select the 2nd or 3rd of the above settings.
Apr 03, 2010 | Olevia LT27HVX 27 in. LCD Television
My screen doesnt get a signal from the computer what could be wrong?
There could be three reasons for the same .
1. Loose signal cable: Check and reseat the VGA or DVI cable from the back of the system tower to the monitor.
2. Bad monitor : Disconnect the monitor cable from the back of the monitor check if the monitor displays anthing .
3. Bad video card : Try connecting an alternate monitor to check if the same is displaying anything on the screen.
Thanks for using Fixya
Proton
Jan 07, 2010 | Acer Aspire T310 PC Desktop
When connecting the Dazzle Video Creator to the PC
Your television company may not be providing a hd signal.
Nov 18, 2009 | Pinnacle DAZZLE DVD RECORDER Video...
Brand new Monitor blank screen says No Signal
There is nothing wrong with the monitor. The LCD is not recieving any signals from the PC. Either you are connecting the VGA cable incorrectly or your VGA card is not set from the PC BIOS. The VGA cable might also be faulty.
Recheck that all the connections are clean and secure. If you are using a PCI-E or AGP card, the computer BIOS should be set to send the video signals through the PCI-E or AGP card. Follow the procedure in your motherboard manual.
If your pc has on-board graphics then you should connect the VGA cable to the on-board VGA out connector.
Oct 19, 2009 | Acer X203H bd Monitor
Hook-up from d610 to tv
It is possible that your laptop drives EITHER its own display OR an extrnal monitor such as your TV. Look for a Screen Swap key on the laptop keyboard. It is usually a "Fn" key and requires you to hold down the "Fn" (Function) key whilst you tap the screen swap key. This key usually has a small picture of two screens seperated by a / . Hope this helps. Ian.
Sep 29, 2009 | Dell Latitude D610 Notebook
Dell 3100MP Projector - No Signal Check Cable
Make sure you have the right input source selected. It may be looking for a signal from some input other than the one you're connected to. Beyond that, if it truly isn't seeing the input then you'll need to have the projector serviced.
Dec 17, 2008 | Dell 3100MP Multimedia Projector
Pc Ware M748LMRT Motherboard Logo
205 people viewed this question
Top Pc Ware Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
