Question about Dryers
My dyer will not cut off
I CHANGE THE FUSE, THEMORSTATAND HEATING ELEMENT. BUT NOW THE DYER WILL NOT CUT OFF. WHAT ID I FIX NOW?
  • Al Bushman May 11, 2010
    brand and model number please.
  • 121 Answers
I would suggest checking to see if your start button is stuck
Posted on Jun 18, 2009
Frigidaire LC-240H-W*2 change heating from 240 to120
the heating element is always 120 volts.
the two lines from the breaker box to the dyer consist of two 110 volt lines which one runs the motor and one for the heating element
May 21, 2011 | Dryers
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
Dyer is not getting hot
If the dryer is not heating, check for a faulty thermal fuse or heating element. The thermal fuse is located just inside the rear of the unit, and is usually attached to the exhaust duct. It is about one inch long. The thermal fuse and the heating element can be tested using an ohm meter or multimeter. Check for continuity. If there is none, the component is defective. Sure hope this helped and best wishes.
Jul 31, 2009 | Whirlpool Dryers
No heat
yes there is a thermal fuse just above the heating element.
Apr 02, 2009 | Dryers
Tumble dyer
first, you should check the exhaust system, make sure every inch of it is clean on the inside. if it is clogged, there is sensors that turn off your heating element as a safety measure. if this is clean, there is 2 heat sensors, one of them probably needs replaced.
Oct 28, 2008 | Dryers
Dyer not heating up
just check the heating element it might burn out,check the thermal fuse of the heating element might be open.hope.
hope it may help,
regards
Sep 08, 2008 | Dryers
Where is the fuse?
The fuse is located in the dryer fan/blower wheel cover and is a one time fuse, which means it is not resettable. I did a look up for the kenmore model # that you gave and I cannot find your model listed. If you go to parts.com and do a search for your dryer you will be able to see all the drawings on your dryer. You will be able to find the replacement part # and how to get to it. Test your fuse to check if it is open if it is, then replace the fuse. There is also a temperature sensor on the back wall of the dyer drum (it is a small metal circle close to the exhaust outlet). Sometimes there is simply a build up of fabric softener residue on them that stops the dryer from heating up. Clean the sensor with an alcohol wipe.
Hope this helps and don't forget to get all the lint out of the dryer before putting it back in service.
Jan 27, 2008 | Kenmore 64942 Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
53 people viewed this question
Top Dryers Experts
Marvin
Marvin
