Question about Boating
My exhaust is a lot hotter on the right side then the left
It burns my exhaust hose on both sides and I have already replaced the impeller
  • 5,687 Answers
You do need a lot of water to prevent your problem. I think we are talking about an inboard or I/O unit. Make sure you replaced the flapper valves in the exhaust too. There should be a water pump on the motor as well as the impeller in the outdrive. Check to see if you have a sealed cooling system with a radiator or an open system using only outside water. There may be a thermostat in the motor in either case. Do not run a boat above idle when you use muffs and a hose. Everyones water pressure is different at the tap.
The closed system uses an intercooler and a radiator. You can have the same radiator problems as a car and you should always use antifreeze in the radiator to prevent rust. If the right side is hotter then it is probably more blocked.
Posted on Jun 18, 2009
Locate camshaft sensor 2008 3.6l malibu
Which one ?
Camshaft Position Sensor Replacement - Bank 2 (Left Side) Exhaust Camshaft Position Sensor Replacement - Bank 2 (Left Side) Intake Camshaft Position Sensor Replacement - Bank 1 (Right Side) Exhaust Camshaft Position Sensor Replacement - Bank 1 (Right Side) Intake
Sep 02, 2016 | 2008 Chevrolet Malibu
Engine seems to run fine but when pto is engaged engine loses power
whatever the pto is hooked to,is putting pressure on it and slowing it down,if its a deck,then the spindles are bad or binding,blades need to turn freely
Jul 11, 2015 | Garden
2013 Toyota Avalon
I suspect that the insulator that seals the selector lever to the floor and the lever inside the car is allowing engine heat ,road heat to enter the cab past the gear lever. IT is common problem if the insulator rots or is not replaced after gear box removal say for clutch replacement.
May 12, 2014 | 2013 Toyota Avalon
Stuck valve
It is not unusual for the left side exhaust to be hotter. It hooks to the rear cylinder that has the least air flow and consistently runs hotter.
If the back pressure draws a dollar bill in when placed at the end of the pipe, this is typically caused by improperly closing valves.
Oct 19, 2013 | 1993 Suzuki VS 1400 Intruder
Why is the right side of the heater flame higher and hotter then the left side
Combustion needs air mix in the correct proportion to burn efficiently-also gas supply may be stronger on the outlet side of burner causing an imbalance-chech for obstruction in either area-cheers Denny
Oct 11, 2013 | Vanguard International Blue Flame - Large...
Oil leaking on exhaust manifold and smoking on 1998 nissan altima 2.4
You need to find out just were the oil is leaking from to start with .I have just done my Mercedes with the same problem valve cover gasket was leaking .Oil was leaking down the side and on the plugs that are hot ,, so it burns off the oil ,this is what you can smell. If other items are doing the same you will need to do that part as well..The breather system may be blocked up also if it is not breathing oil will build up . Good luck
Dec 27, 2017 | 1998 Nissan Altima
On my pipes one side is hot and the other is cold
Check the pipe right where they come out of the heads. It depends on what type of exhaust system you have on your Road King. If the stock exhaust is on the bike, the rear cylinder exhaust is directed to both mufflers. With the exhaust from the front and part of the exhaust from the rear cylinders going to the right side muffler, it gets more exhaust than the left side and runs hotter. Like I said, check the temp of the exhaust pipes at the cylinder heads. If one of them is cold, that cylinder is not firing. As long as both of the pipes are hot there, you're fine. Just ride the bike and have fun.
Ride Safe.
Stevev
Apr 09, 2011 | 2000 Harley Davidson FLHR-FLHRI Road king
P0410
99-01 Blazers with the 4.3L motor and 00-03 2.2L motors have the Secondary Air Injection system and I've listed the codes, part #s, circuit description, and have to fix below.
DTC P0410 (SES Light On) - Secondary Air Injection
P1415 and/or P1416 for secondary air injection Bank A and B can also be set if the powertrain control module (PCM) detects a heated oxygen sensor voltage mismatch and activates an internal test to confirm.
Circuit Description:
This is located under the radiator (pump, electric solenoid, and vacuum shutoff valve) and tees off up to the exhaust manifolds thru 2 check valves on 4.3L. For 4wd remove the front skid plate to access. The secondary air injection pump is used to lower tail pipe emissions on start-up. The PCM supplies a ground to the pump relay, which energizes the pump and the electric solenoid valve. Engine vacuum is applied to the shut-off valve when the solenoid is energized. The engine vacuum opens the shut-off valve that allows air to flow to the exhaust manifolds. Often the pump gets water/moisture in it and freezes up blowing the fuse and the check valves rust or freeze open internally and then burn threw the rubber hose, and even melt the lower “T”, shutoff, and even pump impeller.
Check/Replace as required:
1. You should hear the pump on starting the Blazer and if you put your hand on it you will feel it running for about 1 minute. Part #12560095 (AC Delco 215-364) Pump, Sec Air Inj for 1999-2000 L35 (4.3L) or #12568324 (AC Delco 215-425) Pump, Sec Air Inj for 2001 L35 (4.3L) + 2000-2003 L43/LN2 (2.2L).
The GM # is on your current pump so check it because the Dealer is very confused and/or out of these and will sub other pumps. You can remove the pump and take the #25 torx screws out and see if the impeller is clogged, rusted, melted, etc before spending $100-200 for it. Impeller should spin freely.
2. Extend the air intake hose that ends halfway up the passenger side of the radiator about 2 more feet so it can run between the battery and coolant reservoir and push into the fender hole to keep dry. 99-00 is 5/8 heater hose and inline connector and 01-03 is 3/4 heater hose and inline connector –check size.
3. #12558992 (AC Delco 215-638) air injection check valves 2 required – most stores sell these for $12-20 each or Dealer $33 each. If they rattle or the hoses are burned threw replace – should only flow air into the exhaust. The easiest way is to remove the two 13mm nuts that mount the check valve pipe to the exhaust manifold and use a vise to hold them – trust me here. The little exhaust gaskets should be reusable.
4. #10217106 connect (hoses) 2 required check valves to pipes (Dealer Only $7 each). If burned threw or hard/brittle replace. Usually a good thing to plan on buying!
5. #12555165 secondary injection shutoff valve (vacuum operated in the ¾” hose in the pump outlet to the “T” pipe under the Blazer (Dealer Only $27). Only open when the pump is on and vac applied. Also replace the 5/32” vac hose from the solenoid to valve and solenoid to intake (about 4 ft of it). Once you extend the air intake listen to the hose end and you should not hear any exhaust noise after the short initial one minute pump run – if you still do the vac diaphragm is stuck open/clogged/burned so replace. Vac is applied by an electric solenoid mounted by the pump #01997264. The center vac port goes to the intake Manifold vac and the off center vac goes to the shutoff valve above. The vac should only be applied to the shutoff valve for that 1 minute as the Blazer starts then is switched off. Hose clamps will be needed here.
6. #10105352 “T” for under Blazer where pump outlet to both pipes connect – if yours melted! One end is ¾” and two are 5/8”ends - but you can use a ¾” on all ends with a little lube. Hose clamps here too.
7. The pumps 30 amps Maxi-fuse (large size) is under a little black cover between your battery tray and inside the passenger side fender. You may have to remove your battery to get to it. Depress the little cover retainer and remove, then pull the large fuse out to check/replace. There’s also a 10 amp small fuse to check for the electric solenoid that controls the secondary injection shutoff valve mounted by the air pump.
8. If you need the 2 lower hoses that connect the metal pipes to the “T” going to the pump here’s the bad news – Dealer Only and includes the pipes so over $100.
Good luck and thank you for using Fixya.
Mar 07, 2010 | 2000 Chevrolet Blazer
Noise from the front
Car will pull if brake is binding...as soon as your speed cannot overcome the amount of braking being applied. Be careful when examining it the rotor will be much hotter than normal. (sometimes will turn blue and warp as well)
Sep 19, 2009 | 2001 Pontiac Grand Am SE
Boating Logo
180 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
