Question about Xerox WorkCentre M15 All-In-One Laser Printer
Our workcenter m15i has a OPEN HEAT ERROR ?
What can we do ?
    President:
  • 2,072 Answers
Best thing to do it replace the fuser.
You can google a business called "the parts drop". Call and ask for Britt, He will have the parts you need at a fair price. I dont work there, but have done business with them for long time.
He may also just recommend some parts to replace.
But if the fuser has over 30,000 prints on it, it really is worth just putting in a new one.
Its easy to reaplace. Just 4 small screws.
You may want to first off, open the right side door, as if clearing a jam. One the upper rear, there is a white connector from the fuser to the frame. It may have become unplugged if the plastic cover is missing.
Posted on Jun 18, 2009
How do I replace the power supply capacitors?
I would recommend purchasing and replacing the power supply as a unit
Sep 04, 2014 | Xerox WorkCenter M15i
Is stuck in scanner mode
did you check the scanner cable and the optics or the harness or a program, or a sensor or scanner board the harness cable maybe misallign
Feb 19, 2013 | Xerox WorkCenter M15i
Hi i have a Xerox work centre workcenter m15i which when it turn on, it display heating Error.what could b the problem.assist
Heater quarz lamp is blown/cut. You can access it by removing the right side back vertical panel, removing a connector and four screws. You can pull the whole fuser assembly out very easily.
There is no spare part for the lamp itself. You must replace the fuser unit (which contains the lamp + thermostat).
Sep 15, 2010 | Xerox CopyCentre C20 Black and White...
Xerox M15i has a paper jam 2 error, how to fix
Hi, open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Take care
Jul 19, 2010 | Xerox WorkCentre M15i Laser Printer
Open heat error
its a fuser problem.
This usualy is:
1. heating lamp is broken
2. heating sensor failed
3. termo switch failed
You have to visit autorised service to solve your problem.
Good Luck!
Jul 13, 2010 | Xerox WorkCentre M15i Laser Printer
Reads open heat error
This sounds like a problem with the fuser or possibly the fuser lamp. You can try turning the printer off for about ten minutes to cool the machine off and then turn back on. If that doesn't work you would need a new fuser unit. The fuser is located behind the door on right side of the machine. There are four screws used to hold the fuser in place. Good Luck, I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
ANNOT GET INTO TCHE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
that is perfectly normal. That maintains the lamp temperature.
Not a big deal.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Xerox m15i
The heat rod is bad in the fuser.
You need to replace the fuser.
Look at this site.
https://www.partsdrop.com/store/
May 28, 2008 | Xerox WorkCentre M15i Laser Printer
Xerox WorkCentre M15 All-In-One Laser Printer Logo
866 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
