Question about Troy Bilt 5.5hp Self Propelled Mower
Have a riding Troy Built that just quit. Will not start. Tested battery, it's good. Has gas. Any suggestions?
    Scholar:
  • 81 Answers
Sounds like your electronic ignition has gone bad. Usually when they start going bad you can let the engine cool and it will restart. In your case, apparantly it gave no warning. Check it by unscrewing the spark plug, leave the lead wire hooked to it, placing the spark end of the plug against the head. Try to turn the engine over and see if there is any spark jumping from the end of the plug to the metal. If not, it's the electronic ignition. But be sure the plug you are using is good.
Posted on Jun 19, 2009
My troy built 26j riding mower blade hit a rock and quite now it won't start what do i do please
CHECK THE SHEAR KEY ON THE FLY WHEEL IT SOUNDS LIKE IT IS BROKEN
Aug 16, 2017 | Troy Garden
What is the battery size for a Troy built riding mower?
call your troy built dealer and ask it depends on motor hp etc which we do not have
Sep 12, 2016 | Troy Garden
Why doesn't it start?
Might be a full tank of wet gas from over-winter condensation.
Apr 11, 2016 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy built trimmer model # tb65ss
check the kill switch position and wiring, if good, check magneto wire
Jun 30, 2014 | Troy Bilt Tb70ss Gas Trimmer
Troy bilt pony riding mower
spray some carburetor cleaner in the intake and try to start it if it starts for a few seconds the carburetor is dirty and needs cleaned. put a new needle in it they are cheap and will solve your problem. take the spark plug out and try to start it. if it spins over freely and blows gas out the hole it is the needle in the carburetor. you may want to check the valves, they may be out of adjustment causing hard starting.
Jul 17, 2017 | Garden
Lawnmower has no current to starter
In-line fuse may be flown.
Jun 15, 2012 | Troy Garden
My Troy-built Bronco riding mower gets gas to the carb, but there doesn't appear to be any getting to the spark plug. Any suggestions?
there is a solenoid on the bottom of the carb you need to see if your getting power to the connector if you have power the solenoid is stuck if not there is a safety switch on the clutch/brake pedal that goes bad
May 07, 2012 | Troy Garden
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
Troy Built Riding Mower will not start
Your replacement battery is likely defective.
Jul 09, 2009 | Garden
My troy built rider will not turn over at all. Battery has been tested and plug has been changed. Nothing at all
Check the inline fuse coming off the battery side of the solenoid. If that's good, check that there is power to the wire that plugs into the bottom of the solenoid when you turn the key to start (with the brake locked down). If there is, the solenoid needs to be replaced. That's probably as far as you'll have to go.
May 28, 2009 | Troy Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
153 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
