Question about Philips 26MF605W/17 Television
Power supply squeal magna.26MF605W/17
Tv had blown fuse and main switching transistor was shorted. Replaced w/ original part. Screen comes up and looks good. When backlight turns on, main xformer squeals. +24v has a tiny ripple. +18v ? drops to 16 when on. The last tv I saw w/ this power supply also had the sagging 18volts. If it is 18.
  • dachshock Jun 18, 2009
    Thanks rulds2008. A 2nd opinion is nice when youve got a headscratcher. At 9000' in colo. Rockies, techs are REALLY scarce. Proceeding forward w/ fingers crossed.
  • Philips Master
  • 3,866 Answers
You need a higher capcitor as far as voltage if you got a sag, A power supply making noise is not a verry good sign period and this is dcomming from a eletronics engineer! There is something wroung with the circuit. I would sugges changing out the power supply unit due to a possiable problem with the rails.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 17, 2009
Fuses keep blowing for my flat screen tv
Short circuited component/s at its main power regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 16, 2014 | LG 42LC2D 42 in. LCD HDTV
Diagram tcl21106
If fuse blows off, the power supply regulator section circuit to your TV should be checked in detail. Check all the rectifier diodes first. Then check the main switching transistor for short. The work is a semi skilled one. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 12, 2013 | Toshiba 32A33 32" TV
NO POWER AT ALL
Hi
our tv set need to be serviced. Here are some tips:
1. Open main fuse. The fuse is clean but interrupted. You can try replacing it with one o the same value.
2. Fuse Blown or blackened. Short in the rectifier bridge or in the switching transistor. Out of the power supply: supply line rectifier (100/150V) shorted.
Sully
Sep 29, 2013 | Televison & Video
Hi, when i switch on my LCD, screen is coming blank, with clear sound and after few seconds the LCD is switched off automatically.
In that case or symptom,the problem is either come from the power supply or back lights inverter board.The screen or the display is totaly black when the back lights is not working. The inverter board have blown surface mounted fuses that my cause of shorted transistor,transistor or leak capacitor.Thanks.hope it will help you..
Sep 03, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Acer 1721 17" flat screen
I suspect the power supply problem, that will be the first place to look.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
May 09, 2011 | Acer AL1721 17" Flat Panel LCD Monitor
No power fuse blown replaced fuse new fuse blown
It shows that there is shorting in the further circuit,check MOV (metal oxide varistor) used for protection in the mains supply,MOV is mounted parallel to the main input supply,if o.k check further bridge rectifier and finally switching device used for SMPS power supply either transistor or STR by replacing the same.
Feb 04, 2011 | Emerson TS1997 19" TV
Loud crack when turning unit on, blows main fuse no lights come on.. bottom of power supply black and signs of burn...
DO NOT REPLACE THE FUSE !!! You will do more damage.
I just repaired one of these. A small ceramic surface mounted cap very near where the +/- 85 volt connectors plug onto the board blew up.
This left a sputtered mess on the insulating material at the right rear corner of the power supply.
The net parts list of parts I had to replace:
1. Main IGBT transistors on heat sinks. You have to remove the heat sinks to get at the mounting screws. 1MBK50D or equivalent. I used DigKey part APT28GA60BD15
2. One 1N4148 surface mount diode that is for gate drive speedup. D24 and D25. (don't remember which one was shorted)
3. All four driver transistors for the gate of the IGBT's. @ each 2SA1020 (PNP) and 2SC2655 (NPN). These are tall TO92-like transistors and I believe that at least one of these I had to get from Mouser.
4. Transistor T9, suface mount BC856B (PNP)
5. Replaced all four surface mount caps, one had exploded.
C50, C51,C54,C56. Replace with 0.01mfd/200 Volt 1206 style surface mount caps Digikey 478-1511-6
6.Replaced ceramic wire wound 10 Watt stand up resistors that were blown open. Replaced with 20 ohm design change. These slowly charge the main input filter caps and when supply is stable, a relay shorts them out. If you have replaced the fuse, you LIKELY blew them out. Original value was 10 ohms on some units. This was a Mouser part. 280-PRM10-20-RC
7. The 2153 switching reg chip IC1. This chip shorts. It is made by International Rectifier and I believe the full number is something like IRF2153. I had these in stock and not sure of which source I had procured them from... It was from one or the other.
Lots of destruction and one really needs a desoldering station to work this. Removal of the blown IGBT's is especially tough. All solder must be removed from the transistor leads AND the thermistor on one of the heat sinks. Once you have verified the leads are loose, one has to rock the heat sinks to get the tabs free. The tabs are NOT soldered! Be careful when restoring to get the thermistor leads started in their holes.
Note: ALL these repair parts were procured from DigiKey.com and Mouser.com. Neither of these places had all, I had to order from both. Mouser had the ceramic resistors.
When restarting this, leave outputs disconnected until it is running again. USE a series 75 watt light bulb in the 120 volt input. ONLY work on the unit using an isolation transformer as a large portion of this is connected right to the power line.
There is a small 15 volt switching supply that comes on first that runs the relay to short out the inrush limiting resistors. With the 2153 shorted as usual, this auxilary supply can't reach voltage enough to turn on the relay. The power for this is supplied through the ceramic resistors.
May 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Channel short
Hi there, sounds like you may have a short to ground on the output transistors. Does it have transistors or an IC output. It is most likely that you have not replaced a mica washer or insulator. Check to ground with a meter from the case of the output devices.
Aug 24, 2007 | NAD S300 Amplifier
My tv power does not come on
This set uses a switching power supply. Usually when there is a short on the output side of the switching transformer the supply will just shut down and refuse to operate but normally will not blow a fuse. If the fuse blows suspect a problem with something shorted on the input side of the switching transformer such as I801 regulator IC, diode bridge D801,or other shorted component. Perhaps someone else could tell both of us any other part that could cause the regulator to blow and should also be replaced to prevent regulator failure in the future.
Jun 23, 2006 | Sylvania 6427TE 27" TV
Televison & Video Logo
240 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
