Question about Icom IC-R5 Handheld Scanner
Ic-r5 scanner will not connect to my xp computer
When i try to get the scanner to conect it cannot find a coms port i have reinstalled the soft ware, but still does not work
any ideas
  • 42 Answers
If you have re-loaded the software and then connected the scanner the pc should say "found new hardware" if this is not the case then the port may be inactive, try loading the software using windows add new progs in control panel and see if this solves the problem. You can check the ports by going into control panel / system / device manager / ports. By the way, are you using the ICOM OPC 478 lead with the inbuilt electronic converter in it!
Posted on Sep 27, 2009
Samsung hdmi problems
if you have the soft ware for your system try reinstalling the software
May 12, 2014 | Computers & Internet
I just purchased a samsung scx-4623 and it shows in my control panel that it is installed but when I select to scann on the scanner panel it says its not connected even though the test during installation...
you may deinstall the software from your computer and install it new after, then try, if it is still the same problem go to samsung web side and write your modell name scx4521F then go to download side and download: 1. Printer driver; 2. Scanner driver; 3. Dr. Printer,
when you download the soft ware do not install this direkt from down load, say save then you will find the soft ware in your download folder and you can install this soft ware from this folder as many times you need it. Choos allways the newest version of the soft ware mentioned on the samsung download side for your printer modell, hope this solves the problem.
Apr 19, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I have a scanner 5000l but i dont have soft ware so please help me to downrod
Use this link to download the driver for your scanner: http://www.lostmydrivers.com/driver/download/15735/BENQ/Scanner-Drivers/benq-flatbed-scanner-5000u-driver-v509-win2000-xp.
Mar 13, 2011 | BenQ Scan to Web 5000U Flatbed Scanner
I have a icom ic-r5 scanner that will not start
Check the battery contacts. Sometimes there may be corrosion on them from old batteries. You can also check the contacts that connect the logic board to the battery contacts. There are two small Philips screws in the battery compartment. Remove them and the back cover comes off. You can check the contacts on the inside of the back cover and see where they make contact with the logic board. Make sure all contacts are free of corrosion. If it still will not power up. try a CPU reset. While holding down [FUNC] and [V/M], turn the power ON to reset the CPU.
Nov 02, 2010 | Icom IC-R5 Handheld Scanner
I need driver for Visioneer Paperport 6100 Scanner
Go on line to the Visioneer web site. You can down load new drivers, manuaals and soft ware...Roy
Feb 03, 2009 | Office Equipment & Supplies
Samsung sgh j700 phone shows up as mass storage device
check the pc connectivity settings on ur phone.
make sure that ur using the 2.0 port of ur computer
dont use front usb ports cpu. use rear ports. they are faster.
if still problem persists. try below
conect ur phone to usb. now without disturbing the connections switch off and then on the phone. now there may be chances.
samsung sofware could be corrupted due to virus on ur pc. remove all the viruses then freshly install suit
Dec 09, 2008 | Samsung J700 Cellular Phone
Computer (Windows XP) can't connect to Nikon camera as it used to
hi bauerlina
have you tried using control panel (add/remove programs) to uninstall the nikon software then switch off pc for 5-10 seconds,restart an reinstall nikon soft ware
Oct 25, 2008 | Nikon D70s Digital Camera
WHY CANT I GET AIR TRAFFIC CONTROL OR AIRCRAFT ON MY IC-R5
The only thing you can do about this problem is to buy a Uniden product.However the problem about this is that it does not get all frequencies unlike this model.
Dec 01, 2007 | Icom IC-R5 Handheld Scanner
Scanner
Reload the soft ware correctly, make sure you have got the device in the correct port- Not LPT 1. So uninstall - restart the computer - reload
Jun 23, 2007 | Brother MFC 8500 All-In-One Laser Printer
Icom IC-R5 Handheld Scanner Logo
223 people viewed this question
Top Icom Radio Communications Experts
Steve
johncassells
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
