Question about Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GRBWW
Hotpoint side by side no dispensor door handle loose
My hotpoint side by side refrigerator door handle is loose and needs tightening. It has no visible screws on the handle and is eleven years old
  • 104 Answers
Removing the door gasket would probably reveal screws to separate both shells of the door - warning: door gaskets are expensive and may be hard to find on a fridge that old, so be gentle with it.
JOAT
Posted on Sep 23, 2009
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
I dont have any water coming from the dispenser i do have water coming out of the hose beneath the door from the solenoid my question is is there another solenoid inside the door of the freezer im thinking...
The water line in the door is frozen . Several ways to thaw . 1 ) turn on the dispensor light for a few daws until thawed , 2 ) raise the freezer temp a few days until thawed , 3 ) use compressed air to the bottom of the door on the line , to blow out the ice , 4 ) order the GE dispensor heater pt. # WR49X10173 , it comes with installation instructions .
May 09, 2010 | Hotpoint HSS25GFP Side by Side...
Fridge makes a clicking sound, stops if lever for ice/water press
this model has a p c control in the back and the clicking sound is common when its failing . Pt # wr55x10656 ) there is a up date kit for this frig . ck on the kit before replacing the board as its included in the kit . hope this helped ****
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
No water from door. I've taken the water line loose from the siloniod water will flow when activated. but will not come out at the door.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then , the water tank inside the refrig section , behind the crispers , is frozen . If the door line is frozen , pt # WR49X10173 , is a dispensor heater kit , with instruction , to keep the door line thawed .
Nov 11, 2009 | Hotpoint HSS25GFP Side by Side...
When i place my cup into the ice dispenser it won't shut off. just keeps spitting out ice for minutes.
Sounds like the actuator switch has moisture in it .
1 ) remove the top hinge cover from the freezer door and disconnect the plug there . This removes power to the door .
2 ) Use a small screwdriver under the dispensor control panel , and
pry outward , to remove the panel .
3) Disconnect the 3 plugs to the panel .
4) Remove the 4 screws holding the white dispensor cover on , and
remove the cover .
5) Push in on the cover arm , and you will see the switch which is
activated by the arm . Replace this switch .
6) With this cover off , look in the dispensor area , and make sure the
door flap snaps closed completely . If not , then this is where the
moisture is comming from , and the solenoid at the top right , is
probably rusted , and needs to be replaced .
re-installation is in reverse .
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
Need to tighten loose door handle on refrigerator side
Hi, Look at the top and bottom end of the handle to see if there is a cap that can be removed. You should find a screw behind the cap to tighten. \Please let me know if I can assist you further.
Vic
Jun 13, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Can I remove the door handles from my refrigerator?
should be a screw at top and bottom contact points of handels, under decrotive covers. use small straight screwdriver or something like that to remove covers. be carfull not to scratch doors or covers (it's yours so it's your call)
Jun 02, 2009 | Hotpoint HSS25GFP Side by Side...
GE Adora Side by Side Loose Handle
do the covers pop off to tighten screws on the handles
Oct 21, 2008 | GE Adora (DSF25KGTBG) Side by Side...
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
No water
MORE LIKELY TO BE BLOCKED OR A KINKED PIPE AT BASE OF DOOR, WHEN YOU ACTIVATE THE VALVE THE WATER FLOWS STRAIGHTOUT OF THE DISPENSOR SO THE MUST BE A PROBLEM IN THE DOOR AREA. REGARDS DVISOR
Aug 24, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
204 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
