AKAI F260EA I am trying to view videos on an old VCR but do not know how to tuning in the VCR - can anyone help
  • yorkmeg Nov 01, 2007
    I am trying to view videos on the VCR.
  • 275 Answers
Just get a pair of AV cables, and connect Audio Out of the VCR (at the rear of the machine) to Audio IN of your TV, and Video Out of VCR to Video IN of TV. Select AV on TV using TVs Remote. Play the casette. You should be able to view the Video.
Posted on Nov 02, 2007
Setup VCR to TV, using RF plugs & coaxial cable
The solution was both simple and elementary - why didn't I remember it sooner?
The TV needed to be 'tuned' to the video just as it needed to be tuned for each TV channel.
I selected channel 12 on the TV, went into the tuning mode on the TV and with the video playing, cycled through the TV tuning process until, Voila, there was the video showing on the TV.
Oct 14, 2009 | Philips Televison & Video
Tuning VCR into Tv
Set the LCD to TV source and tune the LCD TV channel to 3 or 4.
For best viewing experience, you should connect the LCD TV to the VCR using component / SVideo or RCA cables instead of RF coxial to avoid signal loss. Your VCR manual should indicate these types of connections.
Aug 11, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Hi. I'm after an owners manual for a JVC video recorder HR-J200EA. Email:
Jun 05, 2008 | Akai VS-J200EA VHS VCR
Akai VSG285 video - I can't tune any TV stations thru to the VCR?
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Apr 09, 2008 | Televison & Video
How to connect my (old) vcr to my sony tv
if you connect via SCART lead, then you will need to select your AV channel or channels on your tv.
If its via arial, you will have to tune your tv to find it.
Mar 04, 2008 | Akai VS-X800EGN VCR
TV, freeview, DVD and video set up.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
Jan 20, 2008 | Televison & Video
Tuning a VCR into a digital tv set
Switch to using the A/V (Audio, Video) connections to watch your vcr
Dec 18, 2007 | Televison & Video
Tuning Sanyo VCR
Press both channel buttons simultaineously for 3 seconds it will automatically tune your programmes press ok when ok flashes on vcr screen display
Nov 04, 2007 | Sanyo DS27910 27" TV
Tuning in Akai Video
Please explain what you mean by "tuning in."  Are you referring to hooking up to your Television, or to a cable/satellite box?  Or can you not see video when you play a VCR.
Check your hookup cabling.  With a cable or satellite system, the VCR normally is hooked between the cable/sat receiver box and the TV.  Cable box RF output to VCR RF input, VCR RF output to TV RF input.
There are other possibilities when your TV has video or line inputs.
Oct 30, 2007 | JVC BR-S622DXU VHS / S-VHS playback VCR
Can tune mitsubishi HS-651V video player/recorder to watch TV.
Hi Jaco, Have you fed in your Antenna / cable into the Rear of the VCR? And if your VCR has a Input selection switch, just check input to Tuner. You will get Blue screen if input selction is not Tuner but Camera / External source. If this does not solve your problem, then there is no Input selection happening.
Apr 06, 2007 | Mitsubishi HS-U448 VCR
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
