Question about Haier Refrigerators
Haier minifridge freezing everything
I have a Haier HSA02WNDWW, and it's freezing everything I put in it, even on its lowest temperature setting. Does the thermostat need to be replaced? Can I do that myself?
  • Aaron
    Aaron Apr 10, 2014
    Water freezes in the refigerator overnight. The compressor runs on any setting above "off."
  • Aaron
    Aaron Apr 10, 2014
    The knob's not on backwards, since the fridge has worked fine for about 5 years.
  • 84 Answers
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
Posted on Apr 10, 2014
SOURCE:
SOURCE: I have a kenmore mini-fridge
they do that when they are on the way to the big kitchen in the sky. sorry, but mini fridges do not typically last very long.
Posted on Jun 14, 2008
HVACRH20
  • 237 Answers
SOURCE: Refrigerator freezes everything even on the lowest setting
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
Posted on Dec 26, 2006
  • 110 Answers
SOURCE: Refrigerator freezing over
if you haveno control of the temp. it is the cold control t-stat that is bad, but first i would sett all controls to factory setting and allow to run for 24 hrs to confirm
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 01, 2008
SOURCE: Avanti Compact Refrigerator Mod.#18ERC/RW
I am about to purchase one of these--Have you found a solution yet??
Posted on Oct 06, 2008
louislevel_2
  • 374 Answers
SOURCE: frigidaire refrigerator freezes everything with setting on lowest
hello there,
try to check your thermostat setting adjust below gradually,
you set it up to coldest point that's why it's doesn't cycle on no auto shutt off and shut on,
if still not change for 12 hours still freezing up,replace thermostat by your technician,might defective.have a nice day
don't forget to rate me,thank's a lot.
Posted on May 05, 2009
Everything freezes
Make sure it is level.
Nov 25, 2013 | Hotpoint Refrigerators
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
My haier mini fridge is frezing everything and i have it on its lowest thermostat setting what is wrong with it
just a suggestion: but you might have to much coolent in it, or its useing alot of power,maybe too much power and the fan is spinning at a high rate,IDK maybe thats it.it probably wont help you though
PS:maybe take it to a shop
Jun 08, 2012 | Haier Refrigerators
Frigidaire side by side freezes in the Refrigerator side
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 16, 2012 | Frigidaire Refrigerators
I have a Norcold n611 fridge gets too cold and freezes even on lowest setting.
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 10, 2012 | Thetford Norcold RV Cooler/Freezer
Even at lowest setting refrigerator side freezes up
Possible failure of the thermostat or the sensor to the thermostat that is not working to control the cooling temperature and hence making the compressor work.
Try and set the thermostat to lowest just a little before it cuts off , if this wont work then the thermostat is faulty. Check the wires of the sensor to the cooling coils.
Mar 13, 2011 | Dometic NDR 1292 Refrigerator
Frigidaire FRS23KF5CW2 freezes everything even on the lowest setting including the water filter. Water is not dispensing and ice maker not making ice.
Your refrigerator has an air damper that should open and close when the temperature is changed for freezer. If increasing temperatures in freezer does not lower temperatures in fresh food section then we will need to consider three things. Thermostat is defective, problems with the Adaptive Defrost Board and possibly the air damper motor is defective. I would like you to stay with me on this as I can instruct you on what and where to look for changes. First if you turn thermostat to very low does the compressor stop? Let me know, Sea Breeze
Oct 25, 2009 | Refrigerators
Kenmore side by side coldspot, model 5687
I'm not trying to be a smart ***,but a lower temperature setting would make it colder.Try using a higher temperature setting.If this was just a poor choice of words you may need to replace your thermostat.
Jun 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
4,325 people viewed this question
Top Haier Refrigerators Experts
geob91
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
