Question about Fusion Digital designs Homedics SoundSpa Fusion Clock Radio
Clock issue When I set the clock it just stays on that time forever. The colon in the middle blinks like it is working, but the time never changes
How to use the ipod charger
Posted on Jun 21, 2010
    Problem Solver:
  • 9 Answers
Yor clock is a "lemon". This is unusual but means that an error was made at the manufacturing plant. The manufacturer will usually replace a clock with this type of problem. (you did not cause it, it was like that when you got it, i'm assuming).
Posted on Jun 19, 2009
  • drolllord
    drolllord Jun 19, 2009
How to set the clock Model NN-SA651S
To set the clock, press Timer/Clock twice when the microwave is not in use. The colon between the hour and minutes should start to blink. Type the current time (12-hour clock) with the appropriate number key pads. To save the time and exit the clock set mode, press Timer/Clock once more. Note: if you take too long to begin typing the time, the microwave may exit the time set mode. In that case, the colon will stop blinking. None of the other features of the microwave will work when the colon is blinking.
This is shown on page 11 of the manual which is available on the Panasonic NN-SA651S support page: http://shop.panasonic.com/support-only/NN-SA651S.html . The direct link to the manual is currently ftp://ftp.panasonic.com/microwaveoven/om/nn-sa631_nn-sa651_nn-sa661_en_om.pdf .
I hope this helps.
Mar 16, 2018 | Microwave Ovens
How to reset time
"Clock"
once
or
"Timer/Clock"
twice
(depending
on your keypad)
The colon symbol (:) will flash.
Enter time of day.
The time appears
in the window; the colon continues
to flash.
Press
"Clock"
or
"Timer/Clock"
again - colon stops flashing; time of
day is set !
Nov 16, 2015 | Panasonic Microwave Ovens
Samsung SMH1611 microwave clock/tImer is intermittently malfunctioning. Microwave will not count down.
This is often just a bad connection on the bottom of the noise filter board. Look for burns and ring cracks. See the attached photos. For disassembly info, you can watch the video at my site, or see these text files: http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm If that doesn't fix it, it may be that the bottom door switch is bad, or its mount is loose, misaligned, or broken. See my help file on door switches here.
Also see the Fast-Track manual for model SMH1611 here.
Feel free to contact me directly (see below) if you have other questions.
.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 28, 2017 | Samsung SMH1611 1.6 cu. ft. Over-the-Range...
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
How do I change the time on my Daiwoo microwave?
  1. Touch the CLOCK pad. This will activate the 12-hour system. (To activate 24-hour system, tap once more)
  2. Enter the correct time of day by touching the time set panels.
  3. Touch CLOCK pad.
You will know that you're changing the time when your display stops blinking and and the colon starts blinking.
If you have any other questions regarding your Daewoo KOR-630A, I located an online manual for you.
Cheers!
http://dl.owneriq.net/6/64d0773e-ca06-4c23-97b1-e039cfc523aa.pdf
Mar 27, 2011 | Daewoo KOR-630A Microwave Oven
Setting the clock on a microwave what is the last action after setting the time. Everything I've tried results in the error message coming up.
According to the manual this is how to set clock.
To set the clock, press "Clock" once or "Timer/Clock" twice (depending on your keypad).
Enter time of day. The time appears in the window; the colon continues to flash.
Press "Clock" or "Timer/Clock" again - colon stops flashing; time of day is set.
If you need the manual it is on link below.
http://service.us.panasonic.com/OPERMANPDF/NNH624-SET%20UP.PDF
Good Luck
Nov 08, 2010 | Panasonic NNH965BF Microwave Oven
I cant set the clock
Is there a button that says clock or has the picture of a clock? if so... just hold it down.. and then when the colon blinks, use the number pad to type in the time.. and then press the clock button again.
hope that helps
Jun 02, 2009 | Panasonic Microwave Ovens
How do you set the microwave clock?
After setting the time push the clock button again and it should start working after a minute passes (on some models you have to hit the start button after setting thr time!
Please rate this response
thank you!
Jan 26, 2009 | Microwave Ovens
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 10, 2008 | Microwave Ovens
Fusion Digital designs Homedics SoundSpa Fusion  Clock Radio Logo
128 people viewed this question
Top Fusion Digital designs Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fusion Digital designs Audio Player and Recorder Expert? Answer questions, earn points and help others
