Question about Cell Phones
My ansuring machine was working--but the backup battery was dead--and somone pulled the wall connection out--and i would love to find out if i could ever retrive 2 saved messages. ??
    Genius:
  • 1,847 Answers
If this a digital one then it goes till it fills up the digital memory. If I want to replay those messages I hold down the play button till it restarts from the beginning if the memory. If you already hit the delete button it goes back to the beginning and reuses the memory space. So if it deleted then it gone
but you try going to the manufacturer and retrieve the message (Only Option)
But from the Question that you posted it tells me the phone didn't had any power when the call came. So the message was not recorded at all at the first place. If i got you correct.
Thanks
K
Posted on Jun 17, 2009
Display will not come on plugged in or not
The UPS needs to have a good DC Buss for it to work. Before you buy the new battery disconnect the battery & unplug it from the wall. Push the on button to reset the logic. You may see the display flash breifly. Install the new battery. Then plug in the UPS and turn it on and enjoy
Oct 20, 2011 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
Have a brand new TE-2200. The machine hung up in the middle of programming and would not allow a reset. I unplugged it from the wall and removed the backup batteries in an attempt to reboot. After...
Firstly, try this:
Turn key to PROGRAM mode Turn power off at wall Hold RECEIPT FEED down - keep holding it Turn power on at wall. Wait 10 seconds Let go of receipt feed. Press SUBTOTAL once
If display does not come on,
Turn power off at wall Turn key to REG mode Take one battery out. Wait at least an hour. Turn power back on at wall (you will now need to fully reprogram it at this stage)
If it is still dead, let me know
Feb 06, 2011 | Casio Parts Cash Register PC Desktop
The battery backup side is not working other side works
Its most likely caused by a dead, failed battery or a bad connection with the battery inside the unit.
Double check the connections inside the unit to ensure the battery is connected properly. If it is, take a volt meter and measure the strength of the battery. A 12v ups battery should read about 13 volts.
Mar 27, 2010 | Computers & Internet
DEAD. MAYBE INTERNAL BATTERY IS DEAD? DONT THINK ITS THE WALL CHARGER...WUT CAN IT BE???
Wall charger's go bad. Measure it's output with a volt-meter, to make sure it's working. I killed one watching too many dvds on the computer and overworking it.
Mar 21, 2010 | Toshiba Satellite A135-S4527 Notebook
Need battery backup for xerox phaser 8560 mfd
A good rule of thumb is
Volts x Amps= Watts
For example, at 15amps at 110V, you will need 1650 watts
Or 7.5 amps at 220V, gives the same answer.
May 03, 2009 | Xerox Phaser 8560MFP Laser Printer
APC Back UPS 350 ES won't run on battery power.
>> I'm having the same problem with mine. I get 122 volts when plugged into the wall, and it tells me that I get less than 1 min of use once I unplug, and it actually lasts for 10 seconds before getting a screeching sound.
The screeching sound is normal. Its telling you "HEY, I HAVE NO POWER. THIS IS A PROBLEM." and trying to attract as much attention as possible. It will also do that if you run a self test with the software and the test fails.
Its been a while since I worked on these during an outage, but I believe there is a way to use the software (PowerChute business edition, if you're using a SmartUPS. There is a personal version with less features for other home models) to silence the alarm. I think some of them had a button you could push on the unit to silence it as well, but look this up first. Push the wrong one and it powers everything down.
Feb 17, 2009 | APC (BE500U-WEB) (BE500UWEB) UPS System
Electrical
If you have a volt meter check to see if there is a drain on the battery when the car is off, you can then pull each fuse to see which circuit is causing the draining. Sounds easy, but I have also seen cases where somone left change (a penny) in the cigarette lighter causing a short cirucit.
Dec 27, 2008 | Ford Fairmont Cars & Trucks
Not working
Some UPS have "Battery backup" and "Surge only" outlets. I don't know if it is the case for your model. The "Surge only" outlets are not connected to the battery and will go off during a power outage. Make sure that the equipement that need to keep running during the outage are connected to the "Battery backup".
Important: Never connect a laser printer to the "Battery backup" outlets because to power draw is just too high.
Have you made sure that the battery is connected inside the UPS? (If the battery is user-replacable)
You may do a simple experiment. Connect you UPS you a wall outlet and plug a conventionnal lamp to a battery backup outlet. Then, unplug the UPS from the wall. If the light goes off, then you may have a problem with your UPS.
Apr 19, 2008 | Belkin Home Office 350VA (f6h350-usb-dl)...
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
