Question about Quasar VV1309 13 in. Combo
How do i get to channel 3 on my tv i need to get my digital converter to work
    Sergeant:
    Champion:
  • 223 Answers
Use the remote and press 03. Check the back of the tv to see if the switch is on 03 or 04.
Posted on Jun 17, 2009
How do I get channels on my TV
If you TV is HD ready (digital), then you need to connect the antenna to the unit so the tuner can identify the channels. If your TV is an older analog unit, you will need to use an analog to digital converter. The antenna will connect to the converter, and the converter will connect to the TV. The converter will tune the channels and send them to the TV on channel 3 or 4, depending upon the converter.
Mar 02, 2015 | Televison & Video
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
Can u explain how to set up the television system with my digital television box.
The digital box should have a round threaded output connector on its back panel. These are usually marked "OUT TO TV" or "RF OUT" or something similar. There may also be a slide switch nearby to select channel 3 or 4 output to the TV. On some boxes the output channel selection is through and on-screen menu. You only need to connect the output of the digital box to the TV's antenna connector, then tune the TV to channel 3 or 4 depending on the box setting. Leave the TV on that channel all the time and do your channel changing on your digital box using its remote control.
If your TV has an AV input for connecting a device like a VCR or DVD player, you can probably connect the digital box that way. Most boxes provide stereo audio and video outputs, and you will get a clearer picture and sound if your TV has the input jacks. If your TV is not stereo and has just a single white input jack for audio (instead of red and white ones for stereo right and left), you'll need a Y-adapter to join the audio outputs from the box together to feed into the TV.
On the off chance you have a digital box with no RF output (I've never seen one since they need to work with older TV sets, but I don't know evey model), and your TV doesn't have AV inputs, you need an RF converter. The converter takes the audio and video signals from the digital box and generates the channel 3 or 4 TV signal that your set can pick up with its tuner. You can find RF converters at larger retailers and online.
Dec 12, 2010 | Disney 13" TV
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
May 30, 2009 | RCA Analog (RCA) to Digital (VGA)...
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Record to vhs with converter box
I need to leave my TV on channel 3 and set the converter to the channel I want to record. When programming for future recording, it's always from channel 3, not the channel I want the converter displaying.
Jul 17, 2008 | Samsung CXN2085TP 20 in. TV/VCR/DVD Combo
I have purchased the converter box to receive digital signals and my tv doesn't have the red/yellow/white connections. Is there a model of converter that will work on this tv which is an RCAModel F25423...
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Jun 15, 2008 | RCA Televison & Video
Digital
Nope. Not a digital Television. I'm guessing it's an older one. Most TV's sold nowdays are Digital TV ready.
Jan 02, 2008 | RCA F32665 32" TV
Quasar VV1309 13 in. Combo Logo
97 people viewed this question
Top Quasar Televison & Video Experts
 Grubhead
Grubhead
jason
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
