Question about KitchenAid Kitchen Ranges
I want to replace electrodes on my KitchenAid Range Model No. KDDT207B. Any suggestions as to how to go about replacing these parts. Also, I would welcome any suggestions as to how to lift the glass top and assembly to get underneath the glass top.
SOURCE: Kitchenaid glass top electric range
That error code is for the "open oven sensor". You probably just need a new sensor.
Posted on Jun 07, 2007
watugot
  • 290 Answers
SOURCE: my range electrodes keep firing
If you cleaned it with soap and water or a household cleaning solution, some of it has probably gotten down to one of the switches that control the surface ignitors. Very common problem. Leave it unplugged when you are not using it and they will dry out and return to normal. You can pull the knobs off and try using a hair dryer, it may help a little, but it basicly is just a matter of time.
There are different variations of this model. If you will post the complete model number I can probably tell you how to remove the top, but there usually is little reason to take it off unless something needs repairing.
Thanks/Mike
Posted on Dec 24, 2007
FreeTech
  • 426 Answers
SOURCE: broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Posted on Jun 13, 2008
reg501
  • 413 Answers
SOURCE: How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Posted on Jun 16, 2008
ginko
  • 19396 Answers
SOURCE: replace ceramic glass top maytag eletric range
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 01, 2009
How do I remove the top on a Kitchenaid Superba (KGST307GWHO) slide in range? I need to access the igniter electrode that seems to be shot.
Hello Barry;
My name is peter. I am a retired field service appliance technician.
Are you sure that it is the ignitor? It could be the ignitor spark module located behind the gas burner nob.
To determine which one is bad and save money, replace these components with good components on your range that are working.
Go into the following websites. In the sears website plug in you model number to get diagrams and part numbers. Search the internet for less expensive part cost.
Gas Stove Ignitor and Burner Not Lighting Water Filters Lawn Garden Appliance Parts
Mar 03, 2016 | KitchenAid Kitchen Ranges
Kgra 806 top oven burner only works on broil, not convect, I already replaced the spark electrode
I think there might also be a thermocouple involved that keeps the burner /gas valve open when hot .
Jan 01, 2015 | KitchenAid KGRA806PSS Gas Kitchen Range
I have a kitchenaid gas range model kgcu462vss. the burners click after the gas has lit. new burners spark module. all switches and wires have been check. what is wrong with my cooktop. kitchenaid sent a...
if all of the wires from the spark module to the electrodes are correct and the burner heads are clean. make sure that all orifices are clean, splills, spider webs may prevent the flame from touching the electrode. this must be performed by a professional appliance repair technician.
Jul 07, 2014 | Cooktops
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchenaid kgss907sss neither the broiler nor the oven will heat with fire. the elecricburner does work however but does not heat well enough. i can hear the igniter click once after turning it on but...
For broil burner ignition an oven broiler burner spark electrode is used to ignite the gas. The electrode is a device that sits right next to the broil burner. It functions like a spark plug. As power is applied to it a spark jumps from the spark electrode tip to the to the electrode shield, igniting the gas. If the electrode is broken or worn out the spark may not occur or be intermittent. Visually inspect the electrode assembly for cracks in the porcelain housing or damage to the electrode tip itself. Be aware that a proper ground and the correct polarity of the incoming voltage to the range is necessary for the electrode control to sense the presence of a flame once the burner is ignited.
there is also a spark control module but I don't think that's it usually no spark when bad.
if you need or want parts ck here for your unit.
hope this helps a little
https://www.repairclinic.com/Shop-For-Parts/-x6b677373393037737373/Kgss907sss-Parts
Jan 05, 2018 | KitchenAid KGSS907SSS Gas Kitchen Range
How do i remove the glass top to replace a burner?? it is to a kitchenaid electric range suberba, model KESC307HBS0. Thanks!!
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Range-Parts/Model-KESC307HBS0/0593/0124160/W0105111/00001?blt=06&prst=0&shdMod=KESC307HBS0 this parts breakdown gives you an idea of what pieces you need to remove to get to the burners. Start off by removed the trim pieces (careful they scratch easily). Then you should be able to raise remove the glass top - careful that you secure it somewhere that it doesn't fall over and break.
Jul 02, 2011 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid Gas Range Model KGRT: Oven temp won't go past 260 degrees. When a higher temp is typed into keypad, it gives me an "err" mesage.
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
Mar 27, 2011 | KitchenAid KGRT607 Gas Kitchen Range
Igniter electrode does not light burner
As the igniters age from repeated use, they can become weak and no longer function properly. Just because they glow or spark, does not necessarily mean they are good. If you are experiencing ignition problems, the following link explains a little theory about how these igniters work and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. If the surface burners work, but the oven does not, the problem is usually not a gas related issue. If the broiler is still working, more than likely, this is not a control board issue. Check the igniter connections to ensure you don't have any broken wires, first. Make sure you UNPLUG the range before servicing.
Replacement parts (if required) can be purchased at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. If the model number you have listred is correct, the bake burner igniter part number is 8191123.
If you have any questions please post back and let me know. I hope this helps you.
Aug 12, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
I'm looking at a KitchenAide KDDT207B duel-fuel used stove to purchase used from a private party I don't know. Are there reliability concerns?
I have this same oven. It began to intermittently fail when using the oven. The error code suggested it was a problem with the keypad. I suspected it was because the electronics was overheating. The electronics for this model is approximately underneath the right front gas top range. What I found was that the failure occured when both the oven and the right front gas range were being used simultaneously. This caused overheating since the electronics has not fan in this model and the heat radiating down from the pan above the gas range is added to the heat coming from the oven below. The electronics is sandwiched between these two heat sources.
Nov 16, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
1991 KDDT207B
You can buy one at kitchenaid. Here is there 800 #. 800-541-6390
Or you can call this # for partselectlogo.gif 1-888-895-1535
Good Luck and Please Rate FixYa!
Jan 08, 2009 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Kitchen Ranges Logo
63 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
