Question about Philips 190V6FB 19" LCD Monitor
Picture fires up for a second then goes dark
My guess is the backlight starter has gone. Has it? How to repair?
  • 1,684 Answers
Hello Chris,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the strip on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
Picture has gone very dark will not adjust brighter
Could be your backlights are bad. Don't know how old your set is. May check your backlight setting up and down to see if it changes the brightness. Not a cheap fix at repair shop. You can order online and change yourself with the help of you tube videos.
Aug 02, 2017 | Televison & Video
Picture shuts off
Is there a dark patch when you see the picture, easiest way to check is on the tv tuner with no cable attached, this way you have a grey static screen, if there is a darkness across the screen when it lights for that breif moment, then it may have a broken backlight tube. Had the same problem with my 32" LG.
Jul 29, 2010 | Astar LTV-32ASB 32 in. LCD Television
How do I fix a screen thats has gone dark
Ths is usually the backlight and we commonly see failed capacitors as the cause. Take it to a qualified repair facility as mis-repair can result in fire and/or an electrocution hazard.
Jun 17, 2010 | Computers & Internet
Dell Latituse D600 display goes dark
The picture board on your monitor is faulty or bad, since it goes black after few seconds, it means the picture board of your laptop has developed fault.
The best thing for you to do now is to take the laptop to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Dell Latitude D600 Notebook
SyncMaster 940N - screen has gone dark when turned on and computer booted up. If I get close to the screen I can just about see something on the screen. I have brought up the service menu and all the...
Your problem is usually caused by a bad power supply. You should be able to do the repair yourself, if just requires replacing 6 capacitors on the power supply board. Here is a link to a repair guide that shows how to disassemble the monitor and repair the power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is the a picture of the power supply board.
BuddyMc
Apr 16, 2010 | Samsung SyncMaster 940N Flat panel Monitor
Picture goes off after a few minutes but sound remains. what is the problem?
There are a number reasons why this might happen:
  • The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  • The panel has died - Need a new panel
  • A cable has worked itself loose or is broken
  • The inverter has gone - Need new inverter
  • The driver board is faulty
Thanks
Oct 02, 2009 | Samsung LA40A550 40 in. HD-Ready LCD TV
Wont turn on It won't get past the start up page. It goes black
There are approx 6 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 10, 2009 | ASUS Eee PC 900 Notebook
L13V36 Dark Screen, picture can be seen in bright light.
If the backlight lights up for a second it's probably fine - It lay odds on the display inverter in the screen. Actually finding parts for anything made by gateway may be difficult, however. They do not sell spare parts. Considering the size of the LCD i bet it would almost exceed the replacement cost of the screen to repair it
Dec 30, 2007 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor picture goes extremely dark
sounds like the backlight is defective. You can probably get a new backlight online if your comfortable taking apart sensitive electronic equipment BUT you must be very very carefull and handle the lcd with care as you can easyly damage it. Oh one more thing the power supply may also be defective for the backlight. I would contact the manufacture to see about the repair or replacement parts as they should be listed in your operators manual. Good Luck
Apr 22, 2006 | AOC LM-727 17" LCD Monitor
Philips 190V6FB 19" LCD Monitor Logo
791 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
