Question about Home
Removing cabano faucet cartridge
How to remove cabano faucet cartridge
  • 68 Answers
SOURCE: cross handle hansgrohe faucet I can't remove top piece
Use a rubber glove between the strap wrench and the fixture. It is a little monkey business but keeps the strap from slipping.
Phil
Posted on Dec 17, 2008
  • 34 Answers
SOURCE: leaking Jado lavatory faucet
It is a rubber gasket that is leaking, Pull the cartridge with a cresent wrench. There will be a paking nut on the top of the cartridge where the handle connects. You should be able to remove this with a pair of pliers. There will be a rubber o-ring inside. Take that to the hardware to to find a replacement to it. It wont be hard to match they keep tons in stock at ace or lowes
Posted on Feb 04, 2009
SOURCE: Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Posted on Sep 15, 2009
SOURCE: how do you remove the cartridge from a LK2454
Call Elkay and they will give you instructions. Thanks anyway.
Posted on Jan 05, 2010
  • 25 Answers
SOURCE: took apart Moen tub faucet to replace cartridge
hi, there is a lock nut that holds the cartridge in this will need to be unscrewed, if you have already done that it should only be a matter of pulling it straight out, sometimes the cartridge gets seized in the body of the tap use mutli grips or pliers to pull it out by the shaft that the handle goes on
Posted on Jul 14, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Tip
    How to repair cartridge-type faucets
  • Cartridge faucets have only one moving part. The stem slides up and down to open and close the faucet and rotates to regulate the flow of hot and cold water. Any leaking requires replacement of the cartridge.
  • First, turn off the water. To remove the cartridge, you'll need to remove the handle. This project can be like working a puzzle. If you have the manufacturer's instruction sheet for the faucet, you're ahead of the game. Without it, look for a retainer clip at the rear of the faucet just below the handle. Or, you may have to remove a set screw or snap-in "hot-cold" button and a handle pin or screw. On some faucets the swing spout must come off first. The retainer clip may be hiding beneath the handle inside a lift-out tube. Some cartridge faucets use two retainer clips–one by the handle and another by the cartridge. Retainer clips can be pried out with a screwdriver.
  • Once the retainer clip is removed, the cartridge simply pulls out. Use pliers, as shown. Install the new cartridge by pushing it into place with the flat arrow, or other mark upward. If you use a lubricant on the cartridge, make sure it's silicone grease.
  • on Jan 16, 2010 | Plumbing
    How is the cartridge removed on the faucet?
    How To Repair Cartridge Sink Faucets at The Home Depot
    www.homedepot.com/.../project_guide_repairing_cartri...
    The Home DepotJul 22, 2013 - Quickly fix a leaky cartridge sink faucet with this detailed step-by-step ... On some models of faucet you may have to remove the cartridge with a
    Removing a moen cartridge from the faucet! If the plastic tool ...? 2:47https://www.youtube.com/watch?v=vGdExIS3b-oMar 5, 2013 - Uploaded by TheOldkid888This is a video on how to remove a moen cartridge from any moen faucet when the plastic tool does not do ...Installation Help / Animated Tutorials for Moen Faucetwww.moen.com/consumer-support/installation-help/tutorial?id...MoenUsing a Philips screwdriver, unscrew the handle screw and pull the handle up off from the faucet. Using pliers, loosen and remove the pivot retainer nut as well. Remove the washer from the cartridge and use pliers to remove the retaining clip.
    Dec 03, 2015 | Plumbing
    Ll800-BN faucet drips after water is turned off need to know how to make adjustment
    More than likely, the cartridge will need to be replaced. I am not familiar with this particular faucet. However, most faucets are very similar in the breakdown procedures.
    Be sure, first, to make sure water is turned off at the shut-off valves under the sink. Next, you should find a set screw on the handle; this is usually removed with an allen wrench. The screw is typically located on the handle of the faucet; often times, the set screw is covered by a small plug that is either red and blue, or will match the finish of the faucet.
    Once you remove the handle, you may find another screw-typically it is a #2 Phillips screw, or a nut that loosens to gain access to the cartridge. Once you remove that assembly, the cartridge will need to be removed. Also, there may be a slide clip holding the cartridge; if it has that clip, you will find it just under the stem of the cartridge and it is usually found closest to the wall side of the faucet. Manufactures make cartridge removal tools, as sometimes the cartridge can be difficult to pull out. However, more often than not, I use a pair of channel locks. If you choose that method, just be sure you do not scratch the finish on your faucet. Keep in mind, it may take some force to remove the cartridge.
    If you order a new cartridge for your faucet beforehand, the new cartridge will come with replacement instructions.
    This is a very simple procedure for a handy homeowner to tackle. If you call the services of a plumber, I expect your cost to be anywhere from $75-$125. Again, just be certain that water is turned off first.
    Apr 16, 2014 | Giagni LL800 Andante Open Trough 1-Handle...
    How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
    These faucets can leak in three different places:
    1. Internally at the valve seat
      You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
    2. Around the handle
      If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
    3. Between a pivoting spout and the body
      The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
    Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
    Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
    Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
    On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
    On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
    Reassemble the faucet according to directions.
    Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
    Sep 10, 2011 | Moen Plumbing
    Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
    Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
    Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
    How does the cartridge come out of the Kohler K 14030 single handle faucet?
    Turn the water off to your Kohler K-14030 faucet under the sink. Open the the faucet to make sure the water is completely shut off. Remove the small setscrew cover from the backside of the faucet handle. You should be able to remove it by hand. Insert an 1/8-inch hex wrench in through the opening and into the setscrew. Rotate the setscrew counterclockwise three full turns; you do not need to remove it. Lift the handle off the faucet. Unscrew the bonnet nut, or cover, from on top of the cartridge retaining nut; counterclockwise until removed. This nut should be remove by hand as well. Use a large adjustable wrench to unscrew the cartridge-retaining nut counterclockwise until removed. Grasp the cartridge stem with pliers and lift it out of the faucet body. You may need to gently rock it back and forth until the suction from the seal ring releases.
    Dec 27, 2010 | Kohler K-10430-VS Fort½ Single Lever...
    No water when valve is turned all the way to hot side
    Remove the faucet handle and trim. Close of the check valve stops on each side of the valve body with a flat screwdriver. Remove the balancing spool and Moen cartridge. Look for and mineral buildup in side the faucet and on the spool or cartridge. If there is buildup on the spool and cartridge, place them in a large bowel with a cup of vinegar and a teaspoon of baking soda. The solution will remove the buildup in a few minutes. Replace the Moen faucet parts and test the faucet. If there is buildup inside the faucet body, use a wire copper fitting brush to the remove the minerals from inside the spool and cartridge tubes of the faucet body. Turn the stop valves on just a little to wash out the debris before reinstalling the spool and moen faucet cartridge. If the is is still no pressure on the one side or the other, turn off all the water to the house and remove the check valve stops, clean them as well and the inside of the faucet. If all else fails, replace the stops, spool and cartridge. Beyond that, the water supply lines may need to be flushes with the same solution.bbfb399.jpg
    Oct 10, 2010 | Moen 3175 Legend One Handle Shower Faucet...
    Faucet is dropping it is a one handle
    First turn water supply to faucet off and remove handle. Remove cartridge from inside faucet and replace with new cartridge. Make sure you tighten cartridge to snug. Don't over tighten.
    Aug 10, 2010 | Moen & Villeta Two Handle Lavatory Faucet
    Home Logo
    266 people viewed this question
    Top Home Experts
    Donni Steen
    john h
    Are you a Home Expert? Answer questions, earn points and help others
