Question about Casio FX-300MS Calculator
How to turn off rounding decimal answers? - Casio FX-300MS Calculator
  • 241 Answers
Www.roseindia.net/tutorialsearch/?t=Round%20off%20Decimal
Posted on Jun 22, 2009
t0pc4t
  • 132 Answers
SOURCE: MS-80TV AUTOMATICALLY ROUNDS UP TO 1 DECIMAL DIGIT
The [MODE] key can be used to select the modes described below.
Important! The following is a general explanation of Scientific Calculator modes. Note that your calculator may not include all of the modes described here.
1) Calculation Modes
Before performing a calculation, you first need to select the appropriate calculation mode.
COMP: Basic arithmetric calculations
(arithmetic operations, trigonometric functions, etc.)
COMPLEX: Complex number calculations
SD: Single-variable statistical calculations
(sample standard deviation, etc.)
LR or REG: Paired-variable statistical calculations
(linear regression statistical calculations, etc.)
BASE or BASE-n: Binary, octal, decimal, hexadecimal number system calculations
MAT: Matrix calculations (determinants, etc.)
VCT: Vector calculations
EQU: nth degree equations, simultaneous equations
2) Display Settings
Use these settings to control how calculation results are displayed.
Note that changing the Fix and Sci settings does not affect internal calculation results.
Norm: Exponential display format and cancels the currently configured Fix and Sci settings.
Fix: Specifies a fixed number of digits to the right of the decimal place.
Sci: Specifies a fixed number of significant digits.
3) Angle Unit Setting
(90°=?/2 radians=100 grads)
Deg: Degrees
Rad: Radians
Gra: Grads
4) Engineering Mode
Use this mode when you want to input and perform calculations using engineering symbols.
Please rate this response . .
Posted on Sep 08, 2009
  • 8073 Answers
SOURCE: Everytime I put decimals into my calculator, it
Increase the number of decimal digits in display.
  1. Press [SHIFT][MODE] to access the {SETUP)
  2. Enter the number (6) corresponding to option [6:FIX]
  3. In screen that is displyaed, enter the number of decimal digits you want (2, 3, or 4). If you enter 0, all decimal numbers will be displayed as integers (rounded). If you enter 9, you will have long numbers but that is hardly ever necessary.
Posted on Feb 22, 2010
  • 8073 Answers
SOURCE: all of my answers show up rounded to the nearest
  1. Press [MODE].
  2. Highlight Normal, it is not highlighted already, and press [ENTER].
  3. Use DownArrow to move cursor to the second line.
  4. If you want to keep all possible decimals digits highlight float and press [ENTER], then press [2nd][MODE] (QUIT) to exit configuration screen.
  5. f you want a limited number of decimal digits (2,3, 4 or 5), highlight the corresponding number on 2nd line an press [ENTER], then [2nd][QUIT] to exit configuration screen.
Posted on Mar 02, 2010
  • 8073 Answers
SOURCE: I have Casio fx-83ES. I'm using it in Mode 2 -
You can configure it as you wish. Press [SHIFT][MODE] to access the (SETUP) configuration screen, then select [8:Norm].
You will be prompted to choose Norm1 or Norm2. To help you find out which is more appropriate to meet your concerns, I am inserting a screen capture from the manual.
Posted on Jul 18, 2010
  • 102366 Answers
SOURCE: I have a problem with
Press the [SET UP] key, followed by the 0 key to bring up the display menu. You can select "FIX" followed by the number of digits to the right of the decimal point, or press cursor-down and select one of the NORM modes. Press [ON/C] to exit the menu.
Be aware that some numbers cannot be displayed exactly. For example, 1/3 is a 0.3 followed by an infinite number of 3s.
Posted on Jun 25, 2011
How i fad the one decimal place the answer of this question 0.7844 correct to 1 decimal place
You haven't made the purpose of the question very clear Miriam so I am only guessing that it is an exercise in rounding or shortening decimal fractions to make them easier to work with which is often convenient when approximations do not matter.
The general rule of rounding is to take the last figure and if it is less than 5 it is erased and if it is 5 or more it is erased but 1 is added to the next or the new last figure and the process is repeated until the fraction is shortened to the required length.
If you take the decimal fraction 0.8745, after the first stage of rounding it would become 0.875 and then after the second stage of rounding it would become 0.88 and then finally rounding to one decimal place the result would be 0.9.
I hope this helps you deal with your fraction. I apologise in advance if I have misunderstood the question.
Mar 01, 2015 | Office Equipment & Supplies
How do I round a decimal when you have a lot of numbers after the decimal point?
You first have to decide what accuracy, that is how many decimals, are needed in the answer. There is a rule of thumb which says you should not quote more decimals than the accuracy of the data used in the calculation. Money calcs of course would usually use just 2 decimals.
So when dropping decimals round up the last remaining of the dropped decimal is 5 or over, otherwise it is unaltered. So 2.2361 rounded off to 3 dec is 2.236, and rounded to 2 dec it is 2.24.
Feb 15, 2015 | Computers & Internet
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Decimal answers
There are no decimal digits in this number. You can put a decimal mark in 8 537 000. and append two zeros, or more. But I would not call that rounding 8 537 000.00
Feb 20, 2014 | Office Equipment & Supplies
I don't know if maybe my calculator has a function turned on that rounds the answer to a whole number? But here is an example: 106 x 6.32 = 670 according to my calculator, which is wrong. The real answer...
Your calculator is set to display no digits after the decimal point. To change this, you have two options: press 2nd [SCI/ENG] then select "FLO" for floating decimal or press 2nd [FIX] then select the desired number of digits after the decimal point (or F for floating).
Feb 14, 2014 | Texas Instruments TI 30XIIS Scientific...
My calculator is returning an answer with a 7 for division
You need to set the number of decimal places to 1 or more.
• Press [2nd] [MODE] and scroll to FLOAT.
• Press the right arrow key until the number of decimal places needed is highlighted.
• Press the [ENTER] key.
For 2 decimal places, 2 should be highlighted. All answers will then be rounded to 2 decimal places.
• Press [2nd] [QUIT] to return to the home screen.
May 03, 2010 | Texas Instruments TI-30X-IISTK Scientific...
Everytime I put decimals into my calculator, it just rounds the answer to the nearest whole number.
Feb 21, 2010 | Casio FX-115ES Scientific Calculator
How to round up to 2 decimal places?
can you tell me the answer to this question
round 618 to two decimal places
Sep 19, 2009 | Casio FX-115MS Plus Calculator
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Mar 25, 2009 | HP 12c Calculator
Casio FX-300MS Calculator Logo
544 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
