Harman Kardon AVR 240 Receiver Logo
Santosh Kolge Posted on Apr 10, 2014
Wont turn on
Reciver wont turn on in standby mode.I reset the system reciver turn on but no sound in tuner and cd in but direct 8 channel input got sound
jeff knowles
Level 1:
  • Contributor 66 Answers
  • Posted on Apr 19, 2014
jeff  knowles
Contributor
Level 1:
Answers
66
Questions
0
Helped
15218
Points
83
Tuner setting might be default only in stereo only. do you have passive or active speakers?
1 Related Answer
Joaquim Martins
  • 1128 Answers
  • Posted on Jun 06, 2010
SOURCE: Reciver is going to protection mode and sound turns off
is some speakers is defective, or not present (connected), check all cables
2answers
How to do channel search
go to the Menu and you should find it.
No display but have sound
HI
Try resetting the system . if this doesn't work.
"Service" is needed .
To clear the AVR's entire system memory including
tuner presets, output level settings, delay
times and speaker configuration data.
1: first put the unit in Standby by pressing the System
Power Control button
2. Next press and hold the Tone Mode button 8 for three seconds.
The unit will turn on automatically.
this will clear all the proccessor.
Note that
once you have cleared the memory in this manner,
it is necessary to re-establish all system configuration
settings and tuner presets.
Good luck
Kind Regards
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
1helpful
My Harmon Kardon AVR 430 will not play sound and displays "unlock" when optical is selected
Try resetting the system. While unit is in standby mode press and hold the tone button on the receiver untill the unit turn on. This should reset the system to brand new out of box condition.
1helpful
2answers
I can't program my tv to regular antenna channels
You can program to regular (analog) antenna channels. To do so you must use the original remote which has a TV/DTV switch in the top right corner of the remote. Choose the appropriate mode for the type of channel you want to see or scan for. Here is a link to the owners manual and a picture of the remote swithc. The info on the signal switching is on pg.13.
http://tv.manualsonline.com/manuals/mfg/funai/cr130dr8.html?idRes=707655
1helpful
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
2answers
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
2answers
2answers
Koss KS3102 - Audio Problems
I think I have had the same problem. It seems like the system resets itself randomly. I think if you first turn it on in AV-1 or AV-2 mode, then hit the menu button on the remote, then scroll to ihe 'input'option, hit that then pick 'digital'. Do this for both AV-1&2. UI hope this fixes your problem!
Top Harman Kardon Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Sean Wright
Sean Wright
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
