Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Only 1 string trimmer /// string keeps feeding when running
B&d grasshog 14" string feeds all time
  • 1,041 Answers
You have the string wound the wrong way on the spool.
Jim
Posted on Jun 17, 2009
  • Jim Parker
    Jim Parker Jun 21, 2009
    Did this solution solve the problem?
    Jim
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Grasshog gh600
grasshog gh600 I'm not a pro; by know means but could be that it could be warp in the wrong direction,frist or may be a spring or something was left out.
Sep 03, 2012 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
The auto feed on the grasshogs don't work
Replace the line with a star-shaped .065" line (I use Rino-Tuff from Home Depot online). I have the GH700 (2 line) model and it fixed the problem for me. Other people have fixed the problem with different shaped lines - apparently there is one at Walmart that works well on electric trimmers. Just don't use the smooth round line. I tried the manual advice and it was bunk.
Jul 13, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
543 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
