Question about Poulan "Poulan" Push Mower
How to adjust correct height front and rear wheels. where to place holding clamp, on pin or between pins? What setting on rear wheels, what setting on front wheels?
  • 376 Answers
It doesn't matter if it's between the pin or on the pin as long as the front wheels are the same and the rear are the same. Where to set them depends on how high or low you want to mow. Does that answer your question?
Posted on Jun 18, 2009
How do I repair height adjustment on a CMM1200?
The front wheels link to the height adjustment controlled at the right rear wheel. The spring loaded link arm attaches to a pin on the height adjustment control. The link arm has come off the pin.
Tools: Long shaft bladed screwdriver and a pry bar.
Adjust the rear height adjustment so the second to last notch is engaged.
Position yourself with one knee on the front deck. This will allow you to control the height of the front and the back-n-forth movement of the link arm.
Position the pry bar with the short "L" section upwards, under the lawnmower. This will allow you to control the side-to-side position of the link arm.
Insert the screwdriver from the rear of the lawnmower. The rear wheel axle can be used for leverage This will allow you to control the up-and-down position of the control arm.
A little perseverance and you will be able to position the link arm back on the pin. It may be useful to remove the plastic cover of the lawnmower to allow a better view of the mechanism and link arm
Aug 05, 2012 | Black & Decker Cmm1200 24v 19" Cordless...
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I get the rear spindle off so I can replace the emergency brake shoes on my 2006 chrysler pacifica?
Adjustment
  1. Place parking brake lever in -full released- position.
  2. Raise and support vehicle.
  3. Remove plug in parking brake shoe support to access adjuster star-wheel.
  4. Through the access hole, rotate the adjuster star wheel in the following direction to expand the shoes outward against the drum:
    1. Left brake - Rotate star-wheel toward rear of vehicle.
    2. Right brake - Rotate star-wheel toward front of vehicle.
  5. Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
  6. Back off adjuster six detents (teeth).
  7. Rotate wheel, checking for light drag. If drag is too heavy, continue to back off adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
  8. Install access plug.
  9. Adjust opposite wheel parking brake shoes using same method.
  10. Lower vehicle.
  11. Apply and release parking brake lever once to ensure proper operation of parking brakes.
Removal & Installation NOTE The following procedure may be used to remove shoes on either side of the vehicle.
  1. Lock out automatic adjuster in parking brake lever.
  3. Access and remove rear hub and bearing.
  4. Remove parking brake cable bolt at knuckle.
  5. Completely back off parking brake shoe adjustment.
  6. Remove parking brake shoe adjuster spring.
  7. Remove shoe adjuster.
  8. Remove upper brake shoe hold-down clip and pin.
  9. Remove lower brake shoe hold-down clip and pin.
  10. Remove upper and lower shoes with return spring from shoe actuator.
  11. Remove return spring from shoes.
    Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
To install:
  1. Install return spring between upper and lower shoes.
    NOTE Before installing shoes on actuator, make sure actuator hooked to rear cable is positioned with word -UP- facing outward.
  2. Install upper and lower shoes with return spring on shoe actuator located on parking brake cable.
  3. Install lower brake shoe hold-down pin through rear of support and lower shoe, then install hold-down clip.
  4. Install upper brake shoe hold-down pin through rear of support and upper shoe, then install hold-down clip.
  5. Install shoe adjuster. Place end of adjuster with star wheel upward.
  6. Install parking brake shoe adjuster spring.
  7. Install bolt securing parking brake cable to knuckle and tighten bolt to 21 ft. lbs. (28 Nm).
  8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure inside diameter of parking brake drum portion of rotor.
  9. Place Gauge over parking brake shoes at widest point.
  10. Using adjuster star wheel, adjust parking brake shoes until linings on both park brake shoes just touch jaws on gauge. This will give a good preliminary adjustment of parking brake shoes, before a final adjustment is made at end of this procedure.
  11. Install hub and bearing with wheel speed sensor as well as all components necessary to access it.
  12. Lower vehicle.
  13. Unlock automatic adjuster in parking brake lever.
  14. Perform final adjustment of parking brake shoes
  15. Adjustment This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
    1. Raise and support vehicle.
    2. Remove wheel mounting nuts, then tire and wheel assembly.
    3. If equipped with AWD:
      1. Remove cotter pin, nut lock and spring washer from half shaft.
      2. While a helper applies brakes to keep hub from turning, remove hub nut and washer.
    4. Remove brake caliper and rotor from hub and bearing assembly.
      Fig. Hub assembly
    5. Disconnect vehicle wiring harness connector at wheel speed sensor connector.
    6. Unclip wheel speed sensor connector from spare tire mounting support.
    7. Disconnect two sensor cable routing clips on rear suspension crossmember.
    8. Disconnect two sensor cable routing clips along toe link.
    9. Disconnect sensor cable from bracket on brake support.
    10. Completely loosen, but do not remove four bolts fastening hub and bearing in place. Once loosened from threads in hub and bearing, push bolts up against rear of hub and bearing to keep brake support plate in place when hub and bearing is removed.
      Fig. Rear hub and bearing mounting bolts
    11. Pull hub and bearing off knuckle and half shaft (if equipped with AWD), then thread wheel speed sensor cable through hole in brake support plate as it is removed with hub and bearing.
    To install:
    1. Position hub and bearing bolts though rear of knuckle and parking brake support just enough to hold support in place as hub and bearing is installed.
    2. Install hub and bearing by first feeding end of wheel speed sensor cable through hole in bottom of parking brake support. As this is being done, if equipped with AWD, slide hub and bearing onto half shaft. Place hub and bearing through brake support, onto knuckle, lining up mounting bolt holes with bolts and placing wheel speed sensor head at bottom.
    3. Install four bolts fastening hub and bearing in place. Tighten mounting bolts to 60 ft. lbs. (81 Nm).
    4. Place wheel speed sensor cable routing grommet into bracket on parking brake support.
    5. Route wheel speed sensor cable along toe link and rear suspension crossmember connecting routing clips where shown.
    1. Connect vehicle wiring harness to wheel speed sensor connector.
    2. Install brake rotor and caliper.
      1. Install washer and hub nut on end of half shaft.
      2. While a helper applies brakes to keep hub from turning, tighten hub nut to 180 ft. lbs. (244 Nm).
      3. Install spring washer, nut lock and cotter pin on end of half shaft.
    4. Install tire and wheel assembly. Install and tighten wheel mounting nuts to 100 ft. lbs. (135 Nm).
May 18, 2011 | 2006 Chrysler Pacifica
I want to know how to fix the alignment on my 1995 honda accord ex.
Before making wheel alignment adjustment, perform the following checks:
  1. Tires should be equal in size and runout must not be excessive. Tires and wheels should be in balance, and inflated to manufacturer's specifications.
  2. Wheel bearings must be properly adjusted. Steering linkage and suspension must not have excessive looseness. Check for wear in tie rod ends and ball joints.
  3. Steering gear box must not have excessive play. Check and adjust to manufacturer's specifications.
  4. Vehicle must be at curb height with full fuel load and spare tire in vehicle. No extra load should be on vehicle.
  5. Vehicle must be level with floor and with suspension settled. Jounce front and rear of vehicle several times and allow it to settle to normal curb height.
  6. If steering wheel is not centered with front wheels in straight-ahead position, correct by shortening one tie rod adjusting sleeve and lengthening opposite sleeve equal amounts.
  7. Ensure wheel lug nuts are tightened to torque specifications
Ride Height Adjustment
Before adjusting alignment, check riding height. Riding height must be checked with vehicle on level floor and tires properly inflated. Passenger and luggage compartments must be unloaded. Bounce vehicle several times, and allow suspension to settle. Visually inspect vehicle from front to rear and from side to side for signs of abnormal height.
Measure riding height. See figure. Riding height between left and right sides of vehicle should vary less than 1′ (25.4 mm). If riding height is not within specification, check suspension components and repair or replace them as necessary.
Wheel Alignment Procedures
Honda recommends using commercially available computerized 4-wheel alignment equipment. Follow equipment manufacturer instructions to obtain vehicle alignment settings. Use following procedures for necessary adjustments.
Civic Camber Adjustment
Compare camber settings with vehicle manufacturer recommendations. If camber is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck camber.
Civic Caster Adjustment
DO NOT use more than 2 shims. If more than 2 shims are required to adjust caster angle, check for bent or damaged suspension components.
Compare caster settings with vehicle manufacturer recommendations. If caster is incorrect, check for bent or damaged front suspension components. Replace faulty components. Recheck caster.
Civic Toe-In Adjustment
  1. Secure steering wheel in straight-ahead position. Measure front wheel toe-in. If adjustment is needed, loosen tie rod lock nuts. Turn both tie rods equally in the same direction until front wheels are in straight-ahead position and toe-in reading is correct. Tighten tie rod lock nuts. Reposition tie rod boots if twisted.
  2. Ensure parking brake is released. Check rear wheel toe-in. If adjustment is needed, hold adjusting bolt on rear compensator arm and loosen lock nut. See figure. Adjust rear toe-in by sliding rear control arm until rear toe-in is correct. Install NEW lock nut, and tighten it while holding adjusting bolt.
Wheel Alignment Specifications
  • Camber - Measurement in degrees.
    • Front: 0 (range -1 to 1)
    • Rear: 0.33 (range -1.33 to 0.67)
  • Caster - Measurement in degrees.
    • 1.17 (range 0.17 to 2.17)
  • Toe-In - Measurement in inches (mm).
    • Front: -0 (0)
    • Rear: 0.08 (2.0)
  • Toe-In - Measurement in degrees.
    • Front: 0.00 (range - 0.16 to 0.16)
  • Toe-Out On Turns - Measurement in degrees.
    • Inner: 41.00
    • Outer: 33.50
Torque Specifications Ft. Lbs (N.m)
  • Rear Control Arm Adjusting Bolt: 48 (65)
  • Spindle Nut: 136 (185)
  • Tie Rod Lock Nut: 41 (55)
  • Wheel Lug Nuts: 80 (108)
hope this helps you out.
May 09, 2011 | 1995 Honda Accord
How do you adjust seat height?
Adjusting your seat height ....
1) Locate your Lock Tab ,this will be located under the front of your seat.
2) Flip the Tab of your lock tab,this will unlock your seat and make it feel rocky
3) Lift your seat off the bottom part of your Jet3, set the seat right next to your Jet3
4) Locate the four seat Post,two in the front two in the back.These post will have at least five holes,the holes are your adjustment
5) Locate the four Pins,two in the front two in the back.These pins are in one of the five holes on the seat posts.
Now that we know where everything is .....
6) Pull the two front pins located on the front seat post,putting the pins in a bottom hole will raise the font of the seat ,putting the pins in the top holes will lower the font of the seat."the same goes for the rear of the seat''.
Adjust your seat accordingly....
be sure everything lines up when putting your seat back on ,also before driving make sure your seat is locked .. Happy Riding..
Jan 26, 2011 | Jet 3 Ultra Power Chair
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
Will I need a caliper reset tool kit to change the brakes on my 2007 toyota sienna or will a standard c-clamp do the job? And since it is an ABS system, I assume that brakes must be bled, correct?
Brake Pads Removal & Installation Front To Remove:
  1. Remove the front wheels. Front brake caliper (exploded view) toyota-09-00-5838.gif
  2. Loosen the caliper bleeder.
  3. Hold the slide pin; remove the 2 mounting bolts and remove the brake caliper from the support.
  4. Support the caliper.
  5. Open the brake bleeder. Press the caliper piston into the bore.
  6. Close the bleeder after the piston has reached the bottom of the caliper bore.
  7. Remove the brake pads, support plates, wear indicators and anti squeal shims.
  8. Remove the slide pins and bushings from the caliper support.
To Install:
  1. Lubricate the slide pins and bushings with brake grease.
  2. Install the bushing on the slide pin.
  3. Install the slide pin on the caliper support.
  4. Install the brake pad support plates on the caliper supports.
  5. Lubricate the anti squeal shims with brake grease.
  6. Install the anti squeal shims on the brake pads.
  7. Install the pad wear indicator facing upward and install the pads on the caliper support.
  8. Install the caliper on the support.
  9. Install the 2 mounting bolts, hold the slide pins and tighten 25 ft-lb (34 Nm).
  10. Fill the reservoir and bleed the brakes.
  11. Install the front wheels.
Rear To Remove:
  1. Remove the rear wheels.
  2. Loosen the caliper bleeder. Rear brake caliper (exploded view) toyota-09-00-5842.gif
  3. Hold the slide pin; remove the 2 mounting bolts and rear brake caliper assembly from the support.
  7. Remove the brake pads, support plates, and anti squeal shims.
  8. Remove the slide pins from the caliper support.
To Install:
  1. Lubricate the slide pins with brake grease.
  2. Install the slide pin on the caliper support.
  3. Install the brake pad support plates on the caliper supports.
  4. Lubricate the anti squeal shims with brake grease.
  5. Install the anti squeal shims on the brake pads.
  6. Install the rear pads on the caliper support.
  7. Install the rear caliper on the support.
  8. Install the 2 mounting bolts, hold the slide pins and tighten 25 ft-lb (34 Nm).
  9. Fill the reservoir and bleed the brakes.
  10. Install the front wheels.
Sep 18, 2010 | 2007 Toyota Sienna
Are motorcyles usually this cantankerous? Now the chain came off. I put it back on, but need to know how to take out the slack so it can be driven safely to town (30 miles) to get a new rear tire.
Loosen the bolt on the rear axle after removing the cotter pin holding the bolt in place. Adjust the chain tension by rotating the adjuster cams on the left and right side of the wheel. See diagram below. Set the two adjusters evenly to keep the wheel inline on the swingarm. Retighten the axle nut and put the cotter pin back in place. Have the parts department look at the rear sprocket. Chances are the sprocket is worn out also. If it is, the front sprocket will be worn out also. Worn out sprockets will cause your new chain to wear out quickly. Please rate my answer. Thanks.
Aug 15, 2010 | 2004 Suzuki DR 200 SE
The blower wheel is making a lot of noise. How do
Remove the front face of the dryer and continue to disassemble the dryer until you have access to the blower wheel. The blower wheel is manufactured with a D shaped hole in the middle. If the whole on the inside of the blower wheel become rounded, then the wheel rotates at a different speed than your motor, causing the loud vibrations you have been hearing.
Using the pliers, remove the holding pin & blower wheel clamp. The clamp is the green ring and the pin is the small horse-shoe shaped pin with an arrow pointing to it.
Pull the old blower wheel off. You should see that the whole in the center is round rather than D-shaped.
Put the new blower wheel in place.
Replace the ring clamp & holding pin.
Re-assemble the dryer.
Sep 01, 2009 | Amana Dryers
Change drum brakes
Brake Shoe: Service and Repair
REMOVAL
1. Raise vehicle and remove rear wheels.
2. Remove and discard spring nuts securing drums to wheel studs.
3. Remove brake drums.
NOTE: If drums prove difficult to remove, retract brake shoes. Remove access plug at the rear of backing plate and back off adjuster screw with
brake tool and screwdriver.
4. Remove U-clip and washer securing adjuster cable to parking brake lever.
5. Remove primary and secondary return springs from anchor pin with brake spring pliers.
6. Remove hold-down springs, retainers and pins with standard retaining spring tool.
7. Install spring clamps on wheel cylinders to hold pistons in place.
8. Remove adjuster lever, adjuster screw and spring.
9. Remove adjuster cable and cable guide.
10. Remove brake shoes and parking brake strut.
11. Disconnect cable from parking brake lever and remove lever.
INSTALLATION
1. Clean support plate with brake cleaner.
2. If new drums are being installed, remove protective coating with carburetor cleaner or brake cleaner.
3. Clean and lubricate anchor pin with light coat of Mopar multi-mileage grease.
4. Apply multi-purpose grease to brake shoe contact surfaces of support plate.
5. Lubricate adjuster screw threads and pivot with spray lube.
6. Attach parking brake lever to secondary brake shoe. Use new washer and U-clip to secure lever.
7. Remove wheel cylinder clamps.
8. Attach parking brake cable to lever.
9. Install brake shoes on support plate. Secure shoes with new hold-down springs, pins and retainers.
10. Install parking brake strut and spring.
11. Install guide plate and adjuster cable on anchor pin.
12. Install primary and secondary return springs.
13. Install adjuster cable guide on secondary shoe.
14. Lubricate and assemble adjuster screw.
15. Install adjuster screw, spring and lever and connect to adjuster cable.
16. Adjust shoes to drum.
17. Install wheel/tire assemblies and lower vehicle.
18. Verify firm brake pedal before moving vehicle.
Aug 12, 2009 | 1997 Jeep Cherokee Country
Poulan "Poulan" Push Mower Logo
160 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
