Question about 2wire 2700HG-B Router (2700HGB)
Red light I have the same problem. My modem was working until AT&T came out to fix my line then suddenly the red light came on. AT&T said I was out of luck and had to buy a new one. The unit was only 2 years old. AT&T is the worst company I have ever had to deal with.
  • 428 Answers
May be the power came through the line was bit high. Haven't they check it before connecting the things?
Posted on Jun 17, 2009
I have my router hooked to my cable modem. Its been working great. Then all of a sudden i have no wireless, then no cable modem. The router an orange or red color. When i unhook the router my cable modem...
Hi Jason
To get the connection back all you need to do is just connect the modem to the router to the yello port & computer to any gray port on the router.
& unplugg the power from the router first & then from the cable modem. Wait 30sec & plug the power to the cable modem first & then once the modem is on completly plug the power to the belkin router.
The light will turn green & start working.
This is an intermittent connection.
To avoid this happening over & over kindly update the firmware in the router.
you can login to the belkin.com/support web site to download & know the procedures to update the firmware in the router.
Thanks
Dec 28, 2010 | Belkin Connect N150 Wireless Router...
Red light blinking on my zte relince net connect modem
That's got nothing to do with windows 7. You have a problem with that modem. Oh & if you're trying to use windows 7 on a dial-up connection,it's not going to work well. Microsoft pretty much stopped any support for dial-up on the newer operating systems. So if this is your situation,I'd downgrade to xp, vista won't do well either. Now if the modem you refer to is a dsl or cable modem, try "power cycling" it by unplugging it for 30 seconds & plugging it back in. Do this with the pc off until the lights on the modem are normal again. Then plug the pc back in & see if it's ok. If not,call your ISP & talk to tech support. It'll be on thier end.
May 16, 2010 | Computers & Internet
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
Jan 28, 2010 | AT&T High Speed DSL Modem
Modem power light is red, suddenly it completely turns off while connected to the power line. Could it be the adapter that is not working anymore?
Your modem might be overheated try putting in the fridge for half an hour and resetting if it doesn't work your modem will need replacing
Aug 23, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
Fax has stopped working on Gestenter DSC525
The modem card is faulty. It needs to be replaced.
Aug 11, 2009 | Gestetner DSc525 All-In-One Laser Printer
I have a Qwest Actiontec modem that has worked fine until today. Now the DSL light is blinking and the Internet light does not come on. I have rebooted, but no fix. thanks!
If the DSL light is blinking it means that there is no DSL carrier signal to your modem. Check the phone line and make sure you have no open lines and filters are on all the devices hooked up to your phone system except your modem. You can check for an open line by hooking up a phone to the phone line going into your modem and listen for a dial tone.
May 07, 2009 | Actiontec (GT701) Modem
Siemens Speedstreem 4100 ethernet adsl Modem red power light
Hi frisko.... you will have to Reset your router, there would be a small hole behind the router, you can ***** a pen or pin , for 5 sec, an then check, you may have to reconfigre the router from. 192.168.1.1,
Jul 24, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
2Wire-3700 dsl red light blinking after a thunderstorm
If you are att customer, you will be charged $60 only if there is problem inside your premises, otherwise they wont charge you.
Is there any phone connected with your DSL line? if so is it working? if its not working, contact customer support and tell them its not working
If the phone is working, you have to check the connections between the phone line to the modem. As the DSL light is blinking red, its the problem with line and not the modem.
Take care
Jun 07, 2008 | 2wire (1000-000057-000) Modem
Cant connect to the internet
red light means moden is out of sync with the isp. Power cycle. by unpluging the power from the back of yoru modem, unplug Your router and also turn off your computer. Turn on your modem frist wait until all lights are green>If they dont turn green. CHeck your cables. make sure telephone line is plugged into it or cable line. . There should be a cable pluged in from your modem to your wan port. Then from your router to your computer. Is this a wired or wireless connection. If its a wireless connection i need to know what what os your using. so i can help you set it up.
Feb 05, 2008 | Arris WR850G Router (DHWR850G)
Not working ,just red light
If you have all red lights, this indicates a problem with the router. Please contact your ISP to make sure that your internet connection is working correctly. Did you receive this router from your ISP or did you purchase it directly? Has it worked in the past and just suddenly stopped working? Please provide more details for me to provide you with further options.
Oct 29, 2006 | Efficient Networks SpeedStream 5260...
2wire 2700HG-B Router (2700HGB) Logo
54 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
