Question about Samsung SyncMaster 17" TFT LCD Monitor
Samsung 170 MP LCD Monitor Disassembly
I'm trying to take this monitor apart so I can repair a TV cable antenna connector on the back. There are 5 screws on the back and two on the bottom, but when thes are taken out, nothing seems to release the outside casing so that I can see the inside components.
Anyone have any knowledge of this monitor? What's the trick to getting it open?
  • Samsung Master
  • 1,684 Answers
The plastic case also has latches along the sides, top and bottom. Take a small flat blade screwdriver and go between the 2 halves of the case. The 2 pieces should open just a bit, now move the screwdrivers along the seam between the 2 halves. about every 2-4 inches there is a clip that needs to be released. You can release it by applying a small amount of pressure by each clip and moving down to the next one while pulling the case apart.
Buddy
Corporate Compuer
over 21 years repairing PCs and printers
Posted on Jun 17, 2009
Samsung s42ax-yd01 - No picture / Sound OK problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 22, 2015 | Samsung Televison & Video
Samsung ln22a450 no picture just audio in the back
- Flickering screen
- Dim screen
- Slow start
May 03, 2014 | Samsung LN22A450 22 in. LCD HDTV
Samsung ln22a450 red light indicator blinking 5 times also sound like initial screen but no picture no audio after that. 10 min later the tv it shut off by it self
- Flickering screen
- Dim screen
- Slow start
May 02, 2014 | Televison & Video
Samsung powers itself off and back on
- Flickering screen
- Dim screen
- Slow start
Apr 21, 2014 | Samsung PN64E550
TV turns on for about 5 minutes the the picture cuts out but sound stays on. Its a Proview 19 inch LCD TV
mrhackshack, Part of "switch-mode-power-supply" is going into SHUTDOWN mode having detected FAULT with other circuit (INVERTER) maybe???? Inverter lights-up the "cold-cathode-fluorescent-lamps" that provide RAW WHITE LIGHT so you can see all the pretty colors on the LCD GLASS PANEL. Technician will need to evaluate it!! Try YOUTUBE for vids on LCD TV repair and see if you can pull-off a DIY repair. Also see vids of LCD monitor repair and LCD monitor disassembly FYI. 12fixlouie Hope this points you in direction you need to go?????
Dec 10, 2009 | Proview PL926WBi 19" LCD Monitor
Subject: Trouble shoot Samsung Synmaster 151 MP LCD monitor Hello, I have a NTSC compatible DVD player, (pioneer DVH-P7000) linked, pictured communication via S-video to the sumsung LCD, also NTSC. It is...
S-Video connectors have separate luminance (B&W) and chrominance signals.
Your symptoms are those of a bad connection on either pin 2 or 4, those responsible for chrominance signals. Check the connections and the cable. Try gently wiggling the connectors when the image is displaying. A flash of color imagery indicates that it is indeed a bad contact, hopefully in the cable (which can be replaced cheaply).
http://en.wikipedia.org/wiki/S-Video
Nov 02, 2009 | Samsung SyncMaster 151 MP (Silver) 15" LCD...
Westinghouse lcd monitor 19" - screen turns white
I have the same problem with my LCD tv... The DVI-D (white connector in the back) and the D-SUB (connector on main-board next to the DVI-D) work great for my computer. However, the antenna returns only a white screen no matter what I plug into with it using a coaxial cable. Judging by the modular configuration on the TV (1 main board with LCD monitor attached to it and the 2 computer inputs, and a smalled board on the back with the antenna, component video, S-video, mini-jack out, and composite video.) I think the smaller board which I believe is called a "NR Unit" is what has failed. I took off the back mini-panel of the TV off, which just slides off when you press down 2 tabs. And, I found the small board which is only held down by 5 small screws, and it pops right off. So, if you can find a NR board from westinghouse that works, it's a quick and easy (hopefully inexspensive) replacement. Hope this helped.
Oct 13, 2007 | Westinghouse LCM-19v1 Monitor
Computers & Internet Logo
971 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
