Question about Dryers
I bought an LG DLGX2802L and converted it to LP with the proper conversion kit. When I turned the dryer on, it sounded like a flame thrower or something! The sound of the flame is VERY LOUD! I wonder if this is normal? Has anyone else had the same symptoms?
  • mcsindustria Jun 17, 2009
    Thanks Eric! Yep, the orifice was changed and the gas valve screw was turned all the way clockwise as far as it would go to adjust the pressure to accommodate the LP gas pressure requirements. I have not tried to fire it with the cover(s) off yet, so I could actually see the flame. It sounds like the flame is so strong that it is going to blow itself out. I have seen this with old style blow torches when the fuel knob is turned too far open and the flame doesn't start at the end of the nozzle, but rather around 1 inch out and away from the nozzle, creating the very loud flame. I wonder, could I back the regulator screw out to decrease the pressure (de-rate for the 5,000 foot altitude I am at? Please advise......
  • 999 Answers
LP is higher pressure and smaller orfice so it does sound different. Make sure you did all the steps in order or you could have an over flame condition.
Eric
Posted on Jun 17, 2009
  • Eric Duda
    Eric Duda Jun 17, 2009
    The BEST solution is to use a meter to set the proper pressure. Do you have the correct orifice for your altitude? I would assume so but sometimes they are miss marked or drilled a little off. The blowtorch affect is also caused by too much air. No shutter to adjust as far as I can remember.
    Eric
I see to have too much gas pressure after converting my Neptune dryer from natural gas to LP
you should not try to adjust the flame. LP burns more yellow that NG. The gas pressure automatically regulates the airflow based on the dynamic pressure that goes through the burner chamber. If your flame is roaring and pushing forward, everything is Okay, if it is a "Lazy" and falling flame, you have a blockage of the airflow - venting system
Mar 03, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Disassembly of an LG DLGX2802L Dryer to replace gas oriface
The top must come off in order to work on orifice. remove the top and then remove the side nuts and it will slide forward after the top off.
Jun 19, 2009 | LG DLG5932W Gas Dryer
Admiral dryer
Who did the conversion to lp? Do you have the old part from the conversion still? If not you can order a kit to put it back to stock which is ng. Not hard for a guy that's handy but time consuming. 2-2.5hrs.
Feb 08, 2014 | LG DLG7188 Gas Dryer
How do I convert a gas dryer model # (DLG2302R) to LP ? Does the required Installation kit come with the unit upon delivery
Here is a link to the conversion kit you will need. It comes with the instructions you will need to do the conversion to LP gas.
Dec 01, 2010 | LG Dryers
How do I know if the appliance store actually changed my cooktop to LP with a conversion kit? I'm beginning to wonder because I found a conversion kit in a box of supplies...it's been a year since they...
You should have voiced your concerns long ago with the store you purchased it from. But if they did not convert it, you would have large, yellow flames.Proper burner flames will have no yellow in them. They should be only a blue flame.
Jan 10, 2010 | Thermador PGR366 Gas Kitchen Range
Yellow flame after an Lp conversion
I remember having a stove with an adjustable orifice in the oven. It looked like a double nut arrangement. If that is what you find, tightening them to each other shrinks the size. Should turn fairly easy, do not force. You may also find a pilot adjustment behind the oven control knob. Hope this helps.
May 19, 2009 | KitchenAid KGST307 Gas Kitchen Range
Need instructions for Natural Gas to LP Gas for GE Dryer
You can get the conversion kit. It will tell you how to convert the dryer. I recommend that you get a technician to do it though.
This gas dryer is equipped with a Valve & Burner Assembly
for use only with natural gas. Using conversion kit
WE25X0217, your local service organization can convert
this dryer for use with propane (LP) gas. ALL CONVERSIONS
MUST BE MADE BY PROPERLY TRAINED
AND QUALIFIED PERSONNEL AND IN ACCORDANCE
WITH LOCAL CODES AND ORDINANCE
REQUIREMENTS.
Good Luck and Please Rate FixYa!
Jan 19, 2009 | Dryers
I cannot seem to get an answer from Amana as to how I convert my natural gas range to LP. According to Amana no conversion kit is needed. Yet they cannot tell me how to convert it. The model number is:...
Gas ranges usually come with LP orifices attatched to them somewhere. In a small envelope or bag taped to the back or in the drawer they should be there. The natural orifices need to be removed and the LP ones installed. If the LP orifices are not installed properly you may get irratic flame and the flame can blacken the bottom of pans this needs to be remedied immediately due to the danger of the carbon monoxide being produced. I found good instructions for LP conversion at this site : www.peerlesspremier.com/faq-rangeconversion.htm
Dec 24, 2008 | Amana AGR5735QDS Gas Kitchen Range
Natural gas to propane conversion LG dryer
You posted under a combo washer / dryer WD-4343RHD.
For a gas dryer, conversion is to replace Nat gas orifice with LP one (the LP orifice has a air hole going cross ways through it) plus screwing the regulator blocker (brass slot head screw on top of the gas valve) all the way down (if you missed that step, I would expect your symptoms). Also, make sure you have a good vent with strong air flow at the outdoor outlet. If poor vent, short cycling may occur.
Nov 22, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Lg gas dryer lp conversion
On the regulator on the burner you remove cap and turn upside-down and reinstall.
Nov 18, 2007 | LG DLG5988 Stainless Steel Gas Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
409 people viewed this question
Top Dryers Experts
Marvin
Marvin
