Whirlpool top loader over flowing
The screen on the inlet valve was removed and the valve stuck so I replaced the inlet valve but the machine still overflows. My next step is to check the water level switch, but I don't know how to test to see if it's bad or not?
  • 111 Answers
Just blow on it and if it clicks 99% of the time its good , but make sure to blow in the hose that connects to the pressure switch to see if is not blocked
Posted on Jun 17, 2009
Code f 20 what does that mean and how can I fix it.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
Oct 16, 2014 | Whirlpool duet Washing Machines
How do I fix F20 code
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.2RAhsfLg.dpuf
Sep 19, 2014 | Whirlpool duet Washing Machines
Water continues to flow into my whirlpool top loader serial #2dwtw4740yq0
Your inlet water valve likely needs replaced. The water supply hoses behind the machine attach to the the water valve on the machine. You will need full model number usually found around inner door to find correct valve.
Jan 11, 2013 | Washing Machines
What does F20 on the washer mean?
Nov 26, 2012 | Roper RAS8445KQ Top Load Washer
Whirlpool duet washer LF error
LF error means "Long Fill". Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the LF error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
One last thing to check is the fill hoses. These front load washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses. If the hoses are good and you haven't found anything slowing down the flow of the water, your electronic inlet water valve is just faulty on the back of your washer and will need to be replaced because it's just not allowing water flow into the washer correctly.
Nov 24, 2012 | Washing Machines
LF COMES ON MY FRONT LOADER LED SCREEN
Here is the valve to order in case it is faulty.
Nov 09, 2012 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
I have a kenmore elite and the code f20 error keeps coming on and it will not get warm
Nov 04, 2012 | Washing Machines
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
