Question about Lexmark T640 Laser Printer
Resetting Printer We are not getting print. We are attempting to reset the printer. How long does that normally take. It's been about 5 minutes now?
    Problem Solver:
  • 11 Answers
Can you print internal pages? If yes then you know the printer is okay.
Is this a new setup or had it worked before? Will it print from a different program? If yes, then you know it is either the program you're using or the specific document.
How is it attached (e.g. USB, Network, etc)? If USB make sure it's directly attached (i.e. not going through a hub, keyboard, etc.) If it works directly attached then the problem lies with whatever you had it plugged into.
Posted on Jun 17, 2009
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Prior to past few days printer worked fine. Now it prints a few postcards then gives a print buffer message on printer screen and from there on it prints gobbledy gook. Now it won't even print a test...
Sounds like you cover all the bases. I just wonder if you reset the unit via the service mode?
resetting the printer should have cleared the memory.
Hold down select and return while powering on machine, hold until self test comes up on display then press go, this will get you into service mode.
Run the memory diagnostics.
Nov 23, 2010 | Lexmark T642 Laser Printer
When I print the paper comes out blank.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip4000#ServiceAndSupport
Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
Also, check that the plastic is not on the print head.
Aug 03, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Officejet 6500 error code 0x61011beb when attempting to install new printer. How to fix?
Your OfficeJet 6500 may need resetting. With the printer power on:
1) Disconnect the USB cable from your computer
2) Remove the ink cartridges
3) Unplug the power cord. Wait for at least 1 minute. Plug the unit back in (press the power button if necessary)
4) Wait for the "Insert Cartridges" message. Reinstall the cartridges
5) Close the product doors
6) If you receive a recalibration message, allow the printer to complete this task
7) Reconnect the USB cable
8) Try your print job again
If problems still exist, your product may need servicing by an authorised HP technician.
Dec 20, 2009 | HP Officejet 6500 Wireless All-in-One...
My printer/scanner is not scanning or printing there is a flashing orange light which i believe is indicating that i need more ink, however this shouldnt be effecting the scanner but is
Try resetting the printer, by closing any print jobs that may have already started. There is usually a printer icon on the bottom right of your screen. If there is print jobs waiting, cancel them all. Switch of your printer, when the printer has cooled down inside (they get very very hot inside), check that the ink levels are exactly as they should be, even if they're not seated properly this can cause the printer/scanner to go sick.
When you are happy all is well, switch on as normal, wait for the printer to warm up properly before you attempt to do anything else. Good luck.
Oct 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Used ink ?
From CANON FAQs:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i350
Ink Absorber Replacement Options This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Solution: Reset the printer
Aug 13, 2009 | Canon i350 InkJet Printer
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
Error 6a00 message
Jan 03, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6000D Inkjet Photo Printer
this is all i could find out
ssue: ERROR LCD: Error code (5xxx through 9xxx)
Feb 19, 2007 | Canon Pixma iP6000D InkJet Photo Printer
Lexmark T640 Laser Printer Logo
382 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
