Question about Sony DVP-FX820 DVD Player
Portable DVD player is stuck on loading. I dropped the Sony DVD player and now when I put a dvd in it just spins the disc and does not play. Is it broken?
  • Ranjith Kolary May 11, 2010
    Is there any error message appears on the front panel of the DVD Player?
    Please let me know the type of disc that you're using.
silly girl
  • 513 Answers
SOURCE: reading but DVD is not spinning in portable dvd player
Some suggestions assuming you know you're using good discs, and have this problem with more then 1 disc. In anything that requires you to open the player and play around in it, I also assume you're not too akward with electronics, and out of warranty: spindle motor problems - you could either fix that by changing the motor, or occasionaly by dropping a little bit of 3 in 1 oil on the shaft. Just dont start it as a hobby if you can still go complain at the store... Good luck
Posted on Jan 30, 2006
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
dankind38
  • 6 Answers
SOURCE: SONY SLV-350P DVD PLAYER/VCR COMBO
I'm afraid you are dealing with a weakened Laser on the unit. The cost vs. benefit ratio of fixing this unit is not worthwhile.
You will find that there are newer versions of this device on the market less expensive than what you paid for the unit you have now.
Posted on Dec 30, 2007
SOURCE: GPX Portable D.V.D Player : No Disc/ DIsc Error
I check the motor. for sping its good. clean the liner eye it's good also check for bad hardness connection it,s with um meter. ok what can it be
Posted on Nov 18, 2008
ginko
  • 19396 Answers
SOURCE: PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If that does not work, the unit must be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Posted on Feb 10, 2009
Everytime i put in a DVD it says "Loading" on the
There is problem with Optical block need to replaced.This Model is new and still come in under Warranty.SO check your Warranty card and calim your near Sony service centre.
Nov 15, 2010 | Sony DVP-FX930 Portable DVD Player
Sony 5 disc DVD Players tray getting stuck
Hi Tysonwalker,
The mechanical of the try path is misalligned. And it needs proper mechanical adjustment, and dont try to pull it out because if you do so, this could be made damadges of cam gares, and this could be increase of expens to solve. Therefore contact any expert for mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jun 21, 2009 | Mintek DVD-1710 Portable DVD Player
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Sony dvd player dvp-fx810 stuck on "disk loading"
Make sure the switch on the side is set to video out not video in hopefully this helps out
May 16, 2009 | Sony DVP-FX810 Portable DVD Player
Mintek portable dvd player
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 08, 2009 | Mintek MDP-1815 Portable DVD Player
Disc does not spin and shows on screen that there is no disc
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Disc gets stuck on "loading"
laser lens may need cleaned or realind! claen and try again
Dec 12, 2008 | Televison & Video
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Won't load
My player was doing the same thing and I noticed that the lens arm was stuck near where the disc snaps into place. I gently pushed the arm away from the center (being careful not to touch the lens). I restarted the dvd player and put a disc in...started right away.
Aug 13, 2008 | Sony DVP-FX810 Portable DVD Player
Disc not spinning
It could depend on the type of media you're using. I noticed that certain types of self made dvd's don't play in this player.
Apr 01, 2007 | Polaroid PDV-0823A Portable DVD Player
Sony DVP-FX820 DVD Player Logo
148 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
