Question about Microsoft Windows XP Home Edition
Internal error occured
At 12:10pm I was sending out a video when the internal error occured. Have been having this issue with the server for awhile now. Also the 502 error
  • 3,267 Answers
This happens when the file to be transmitted is very long. Try breaking it into comfortable sizes and send the second after finishing the first. You may also set longer timeouts to stay in touch with the server..........sodeep
Posted on Jun 17, 2009
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
Why does it say communication error when i try to activate microsoft office 2007
This issue may occur if you configure your Internet connection to use a proxy server that requires authentication. In some situations, the Activation Wizard can not connect through the proxy server to an internal Microsoft server and show error message.
Alternatively, this issue may occur if your firewall software is blocking the attempt to connect to the server through your Internet connection.
To resolve this issue configure the firewall software to let the Activation Wizard connect to the Microsoft server or restart the computer in Windows Safe Mode With Networking, and then try to activate the software.
May 25, 2014 | Microsoft Office Word 2003 for PC
I cannot access the Enhancement thumbnail to edit my video
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator, web@youtube.com and inform them of the time the error occurred, and anything you might have done that may have caused the error.
More information about this error may be available in the server error log
Aug 27, 2012 | YouTube Videos
Failure of server APACHE bridge What does this mean?
Hi!
First of all Apache Bridge is a Plug-in which has the ability to Integrate, Application Servers such as Weblogic (Oracle's component) with the Apache servers (http or web servers).
Before solving the issue you have to specify with what component or software this error occurred. This issue is common if you have used Weblogic/ Weblogic plug-ins.
This error occurs when the Apache server is unable to communicate with Weblogic Server if you are using one.
  1. So first you must ensure Weblogic servers/plug-ins have been properly setup/configured!
  2. You have to check Apache error logs if you use an internal web server.
  3. If there are errors, you have to configure Apache properly.
  4. If you are using WL clusters configure and test.
  5. Apache logs are located in /apache/logs. Check logs under Managed Instance or Admin Server.
  6. Make sure your plug-ins are compatible with Apache.
  7. If you are using Weblogic, please read the manual at Oracle.
These are highly technical issues and Fixya experts spend their time to provide the best possible answer. So please be kind enough to rate and or pay if their is a bid set up. That will encourage our experts.
Sep 03, 2010 | Computers & Internet
Opened an email and it said http/1.1 500 internal server error
That is a rather general error from an internet server. They usually occur when you are visiting a web page that can't be displayed properly due to errors in the code, in this case, they were trying to display HTML code from their system directly in your email. If it came in a spam email, you don't need to worry about it.
If it came from a company or person that you needed to see what they were sending you, contact them and tell them you got a 500 server error, and forward them the email so they can figure it out. It will have to be fixed on their end
Oct 28, 2009 | Apple iMac G5 Desktop
just refresh...if that doesnt work Re-type the youtube address if that doesnt work try a different brower...if u dont have another browser download some
konquerer, opera, firefox, flock, chrome
May 16, 2009 | YouTube Videos
Apache Server Port 80
This is a problem at their end, try again later. You may want to try restarting what you were doing.
Feb 14, 2009 | YouTube Videos
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Internal Server Error 500
Start Internet Explorer. 2. On the Tools menu, point to Pop-up Blocker, and then click Pop-up Blocker Settings. 3. In the Address of Web site to allow box, type http://v5.windowsupdate.microsoft.com, and then click Add. 4. Click Close to close the Pop-up Blocker Settings dialog box.
Feb 13, 2008 | Office Equipment & Supplies
Microsoft Windows XP Home Edition Logo
142 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
