Question about RCA 20F512T 20" TV
Similar issue with Vizio 32" plasma - turning on and off repeats
Recently when turning on the tv, it will turn off...then back on, and off, and on, up to 5-6-7 times, before the tv finally comes on. Then no problem shutting off, but when starting up cold...same thing...on/off/on/off. Tv is less than a year old.'
thanks.
  • 55 Answers
Possibly startup circuitry or microproc that handles turn on
Posted on Jun 17, 2009
I have a 50" Vizio plasma tv that is about 5 years old. Recently when I turn it on it cuts off or blinks. I have to turn it off and back on several times in order to get the picture to come on. I am s
Yes it's. Just bring it 2the nearst electronic shop for repair. T power my be spoile or some insect get inside n make it burn. It's ever happen 2 my tv also.
Dec 04, 2012 | Vizio P50HDTV20A 50 in. Plasma HDTV
When I go to turn on my Vizio 32' Model VP322 HDTV10A, it half turns on then back off, repeatedly for 3 minutes before turning on. How can I fix this problem?
If you are not able to hear sound during the this process, the power supply of the TV is likely failing.
If you are able to hear sound during the 3 minute ordeal, then likely the inverter for the backlight is failing, which can also be caused by a failing lamp as well.
Try this: turn the TV on, wait for it to do its thing. Goto the menus, picture settings, and turn the brightness *down* as far as it will go. Exit out of the menu (save if prompted). Turn the TV off, wait a bit, then back on. If still same issue, it could be the power supply or inverter / lamp assembly. But, if the cycle is shorter, or comes on right away, then it is likely the lamp / inverter.
Jun 23, 2010 | Vizio VP322 32 in. Plasma TV
Hey guys, got 32" Vizio plasma. Having issue with the tv going through this cycle where it's having a hard time turning on, the amber light will kick on and off several times before the tv turns on. ...
If you feel good about it, take off the back and examine the capacitors on your power supply. It should be located near the center of your set. In the event you can't find it, locate where you plug in your power cord and follow the path of wires until you find the circuit board where they plug in.
That's your power supply. The capacitors are the cylindrical objects on the board. They range in size and can be very small, to quite large. Look at the tops of them. They should be flat. If you see any that are raised in the center, those capacitors are no good.
That cycle you are describing is reminiscent of other sets having a similar problem. In those cases, it is the capacitors on the power supply that cause the issue. You can replace them with higher rated capacitors, if you prefer, or you may replace the power supply.
Hope that helps.
Jan 21, 2010 | Vizio L32 32 in. LCD HDTV
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
TV WILL NOT TURN ON BUT VIZIO LIGHT IS ON
The Service Plan from Walmart is an "extended plan" on top of the manufacture warranty. Your Tv is still under warranty from the manufacture.
Here's a link to get the info you need to get started on a warranty claim:
http://www.vizio.com/support.aspx?id=1588
Jun 27, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 32" Plasma Freezes up
A lot of picture freezing issues are signal based. Check the signal strength and quality.
Jul 24, 2017 | Vizio L32 32 in. LCD HDTV
RCA 20F512T 20" TV Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
