Question about Canon MP-11DX Calculator
MP11DX time and date will not set
I can display the time and calendar and know that I need to hold it for 3 sec and then = and change the date 06172009 but when I hit the divid I thought it set then returned to calculation mode but it is not setting properly...HELP!
I just did it over and over again, I think I may have even hit the = afterl. To change the AM hold down the calendar key, then the div
Posted on Jul 14, 2009
How do I set the date for this Canon MP11dx? I
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Enjoy!
Apr 09, 2010 | Canon MP-11DX Calculator
Canon P200 DHIII calculator needs to be changed the date. Can you tell me how?
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 22, 2010 | Canon P200-DHIII Calculator
How do i change the time and date
Setting the date:
Setting the time:
displayed.
Jan 22, 2010 | Casio DR-T220 Calculator
Cant change the date
Setting the date:
Setting the time:
displayed.
Jan 17, 2010 | Canon LS-100TS Calculator
Changing the date.
Setting the date:
Setting the time:
displayed.
Jan 15, 2010 | Casio DR-T120 Calculator
Set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Feb 26, 2009 | Canon MP-25DV Calculator
I have the same problem I can not change date and time
Setting the date:
Setting the time:
displayed.
NOTE: If unsuccessful attempts to set the date and time have been made,
please first confirm that the piece of paper/plastic in the battery
compartment on the bottom of the unit has been removed. Then reset the
unit by inserting the tip of a ball point pen into the "RESET" hole on
the bottom of the calculator. The calculator should be on and in the
"Print" mode so that you can hear the calculator reset.
Aug 09, 2008 | Canon MP-25DV Calculator
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
Canon P170-DH
I played around with mine and found the keys that you change the time and date with by looking over the top of the keyboard. On my model there is a time and date key that has a little calendar and clock actually on the key. That key allows you to switch between date and calendar. After you click on that button you will either see a date or time. To change those numbers use the following keys: The equal (=) key will change date and time by holding the key down till the numbers on the display start to flash. Once they start to flash use the number keys to make your changes. The multiplication (X) key you can use to change am and pm. If you want military time use the division key. If you are changing the date there is an additional key that lets you change the format. What this means is the sequence on the display by the way you view the month, date and year. You can change it so year shows first then month and date or interchange day and month. Once I found those keys it was easy.
Jan 28, 2007 | Canon P170-DH Calculator
How do you set the clock/calendar on the Canon MP25DV?
on the bottom of your calculator is a reset button, with a paperclip or a pen press that button. Then, press the calendar, clock key. next, press the equal sign key until the date is flashing type in the date using 11172006. press the equal sign again and the date is set. Next press the calendar, clock key again the time should show up (12-00-00)press the equal sign again until the time starts to flash. enter in the time using 0903 (9:03) press the equal sign again. Time is set. to display the date and time when not using the calculator, press the calculator, clock key 2x's. to go to compute mode press the red CE/C button.
Nov 04, 2006 | Canon MP-25DV Calculator
Canon MP-11DX Calculator Logo
1,271 people viewed this question
old marine
old marine
