Question about Brother HL 5170DN Laser Printer
Toner what needs to be done when toner light comes on?
  • 526 Answers
When the toner light comes in and the status is red, it usually indicates that the toner is about to be empty or is empty.
if status is green and the toner light is blinking it means its low
Posted on Jun 19, 2009
Toner light comes on and it won't print
WHen the toner light comes on this means you need to replace the toner cartridge because its empty. The toner its the powder that is used to put on the paper, you will no longer be able to print until you replace it with a new one.
Jun 24, 2010 | Brother HL-5240 Laser Printer
Printer won't work, power light is off, but yellow toner light is on. Tried re-starting, refreshing, still no printing........
Needs new manufactures toner fitted to machine to allow it to reset toner counter, after market toners a lot of time and sometime even the real ones, do not reset the counter they will trick the machine for a bit, untill the page count gets to a value preset to stop your machine from working unless the reset is activared.
.., if your real clever and like fiddly chalanges, one can get the reset device that is attached to the toner cartridge, pull it apart and place the reset lever back into new position, but it takes some doin to get it right, but it has been done;)
White lever in black semi circle shroud on toner cart, lever falls toward the machine after it has reseted. In new position it sits about 45 deg forward
Activating switch in machine permany dont work, can be removed and done via a flick of it, but best bet, buy gen toner or get good with fiddly springy bits;)
Nov 10, 2009 | Brother HL-2170W Laser Printer
Toner light will not go off
open the front of the printer as if you were going to replace the toner and hold the button down on top of the printer keep holding it until all the lights on the printer have lit up (they may then start to flash.
Once you have done this close the lid on the front of the printer (it should at this point clear the toner light).
Is it a recycled toner cartridge as some of the are badly refurbished and they don't always reset the Toner empty indicator on them, (its a mechanical gear on the side of the cartridge itself). and this can sometimes cause it to come on.
hope this helps
Aug 06, 2009 | Brother HL-2030 Laser Printer
Have a problem with a Sharp AR152. The toner
Once the toner lite comes on it blows the chip in the toner cartridge, a new toner will fix your problem.
May 04, 2009 | Office Equipment & Supplies
Copies are printing out light on the top half of page
The developer needs to be changed in your copier. It should be done by a service technician since the the toner developer sensor has to be recalibrated and all developer has to be removed out of the machine including the mag roller. If it isn't done properly the problem will continue.
Mar 19, 2009 | Gestetner Copier
Toner light still on with new toner
Is the printer still asking for a new toner..?
If it is the there is a gear that can be reset on the toner cartridge2_bing.gif to tell the machine its a new toner cartridge. This is normally done by an engineer, but is quite easy to do if you know how. And I do :0
Feb 11, 2009 | Brother HL 5250DN Laser Printer
Toner light on replaced toner
probably broken toner motorshaft remove toner cartridge look to back of machine if you find a white collar and a spring laying on the bottom thats it
Mar 21, 2008 | Sharp AL 1631 Copier
Drum light flash Brother HL 2070N
You need to have the front of the printer open, when you press and hold the 'Go' button. All four lights will come on, in sequence. Release the button, and close the front cover. Done...
Feb 27, 2008 | Brother HL-2040 Laser Printer
Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Dec 01, 2007 | Sharp AL 800 Copier
Brother 5240 laser printer changed toner still wont work.
This works on several different Brother Printers to get rid of toner/drum empty errors:
1. Open the front cover and leave open while completing the following steps.
2. Turn the printer off.
3. Hold the 'go' button while turning the printer on. All panel lights should be on.
4. Release the 'go' button.
5. Press the 'go' button 2 times.
6. Pause.
7. Press the 'go' button 5 times.
8. The toner light should be off.
9. The paper light should be on or flashing [doesn't happen on all].
10. Close cover. The ready light should be the only light on.
Oct 20, 2007 | Brother HL-5240 Laser Printer
Brother HL 5170DN Laser Printer Logo
336 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
