Question about Masterbuilt ESQ30B Smoker
Temperature gauge The smoker is 4 months old and still heats up, but it doesn't show the correct temperature on the digital readout like it used too. Is it covered up or does it need a new one? Where would we find this at?
Min went haywire after 3-4 months. These gauges aleays sem to be off. I have a variance of 20-30 degrees. I would order a new if I were you
Posted on Dec 24, 2007
I have a 3 month old corolla 2012 le automatic. The engine temperature stays below C when I start the car in the morning and heating doesn't work. Even letting the engine run on idle for a few min
You need to have the dealer look at this, if you fool around with it you can void your warranty. Toyota looks for any legal excuse to void the warranty.
Dec 06, 2012 | 2012 Toyota Corolla L Sedan 1.8L 4-cyl....
Grill doesn't heat to high temperature.
try cleaning the injectors they could be blocked
Aug 13, 2012 | Ducane 30400040 Stainless Steel Grill
I couldn't get the temperature to regulate. The digital readout showed it getting hotter and hotter, then the GFCI would blow. I finally got it to work but I don't know how I did it. The next day I tried...
I answer quite a few questions about Traeger Pellet Grill/Smokers, but this is a new one. My best advice is to contact Traeger's Technical Support Dept @ (800) 872-3437 and let them sort it out.
Apr 04, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Upon start up the digital readout shows EAAR and its not heating up
Sounds like the control unit is malfunctioning, possibly the circut board in the controller.
You can try a full reset. Turn off the unit and unplug it from the outlet completely, wait for a minute or 2 so the controller can power down completely.
If you get the same result when you plug it in and try again you might need to replace the controller.
Masterbuilt recommends contacting them directly at 1-800-489-1581
Jan 01, 2011 | Masterbuilt 20070106 Electric Smoker
Tyre pressures zx12r
It should show the maximum tire pressure right on the tires.If you fill them at a gas station,I would bring my own gauge as they are rarely correct at the gas station.I would use the maximum or probably no more than 2 psi under maximum.This rating is usually for optimum performance.If you live where there is a lot of variation in temperature outside,I would check them 2-4 times per month.I live in FL and check mine every other week or once a month due to consistency in temperature.
Jul 22, 2010 | 2002 kawasaki ZX-12R
Digital readout says eaaf
The unit will not turn on if the internal temp sensor is below 40 degrees. Warm it with a hot rag or hair dryer, or bring the unit inside to warm up and it will turn on. Once the unit turns on for a minute or so, it will work fine outside.
This isn't the ideal solution, but it will work. I don't know why they don't want the smoker to turn on when it is cold out (unless they are worried that the quick change in temp will damage the heating coil).
Nov 26, 2009 | Masterbuilt 20070106 Electric Smoker
Masterbuilt Smoker Model 20070108 Digitial Controller not working. Worked the first time, then no power. I hear a beep when I plug it in, but no display.
I had the same problem this morning. I seasoned it two days agao with an outside temp. of 50. This morning it was 8 degrees and when I pluged it in there was no readout. I removed the digital unit from the top and heated it with a hair drier and it worked when I reinstalled it. I think it had some moisture in it although the unit has been covered the whole time. I am going to call Masterbuilt tomarrow and see what their answer is to this problem.
Jan 17, 2009 | Masterbuilt 20070106 Electric Smoker
Very slow getting heat up to preset temp
Remove the back sheet metal cover and check to see if the wire connections to the element are good ad tight with no corrosion, if burnt or corroded there is too much resistance and the element will not heat up fast as it should and will very soon not heat up at all.
Aug 08, 2008 | Masterbuilt ESQ30B Smoker
Won't heat
I have the same smoker with the same problem. I checked the heat element with an ohm meter, it was good so just cleaned the burnt residue from the male spade connectors attached to the element with a dremel tool. Slipped two new female spade connectors over the ones on the element and soldered them with the wires attached with a 1/16' silver bearing electronics solder. Now the connections cannot become loose and burn up again. I tested everything out and then wrapped the exposed connectores with non conductive fiberglass electrical tape and covered everything with expanding foam that comes in a spray can. Easy fix for me after reading all the posts from you guys here. Good luck and go for it! All I had to buy was the foam insulation.
Corpus Christi TX
Jul 13, 2008 | Masterbuilt ESQ30B Smoker
Masterbuilt ESQ30B Smoker Logo
311 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
