Question about Dell Dimension 5150 Intel Pentium 4 w/HT Technology 3.0GHz,800FSB,80GB HD,512MB DDR2 RAM, CD-RW/DVD ... (D5150) PC Desktop
'No rgb signal' to second (old) monitor
Main monitor (NEC Multisync EAQ231WMi) works fine. Second monitor (on blue 15(14)pin socket) shows 'Dell' and other info on immediate start-up so there is s signal initially but not after Windows XP is booted.
    Master:
  • 569 Answers
Try restarting the pc in safe mode
uninstall the graphic driver restart the pc and again restart the pc
this is problem of screen resolution
Posted on Nov 06, 2015
SOURCE:
tom19511
  • 1601 Answers
SOURCE: DELL MASTER RESET?????
When booting up to Win XP you may get a error that reads "Unmountable Boot Volume". This is probably because your boot.ini file is messed up.
You should be able to restore your windows installation.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&l=en&s=gen&docid=35F157CB59994ED7E040A68F5B2813E3&journalid=4391620012FE791FE040A68F73281D77&Query=dW5tb3VudGFibGU=&SystemID=DIM_CEL_1100&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Posted on Jan 13, 2008
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Posted on Mar 25, 2008
techniwiz
  • 275 Answers
SOURCE: ''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Posted on Nov 11, 2008
linktriscuit
  • 89 Answers
SOURCE: My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Posted on Nov 27, 2008
Geekman
  • 32281 Answers
SOURCE: Dell Dimension 2400 - Adding second HD
I presume that the hard drives are ATA drives, and if the WD and Maxtor are installed on the same IDE cable then the boot drive, the WD HD needs to have the jumper set to Master or Master with Slave drive, and the Maxtor needs the jumper set to Slave drive.
If the computer on boot up doesn't recognise the boot drive the move the jumper to the CSL setting.
If the Maxtor is on the second IDE cable it does not matter if the jumper to either Master or Slave provided you do not have anything else connected to this cable. If you have a CD or DVD connected to the second IDE cable as well as the Maxtor HD then you need to check the devices on this cable (ie. the jumpers) are not set the same on both devices.
On boot up go into the BIOS and check that the master and slave devices are set to Auto (detect).
You should after booting up now see both hard drives and any CD/DVD.
The data on the Maxtor drive would include your original Windows and programs and data, you would need to remove these redundant files and programs to recover disk space.
If you can see on boot up all the hard drives and CD/DVD (as master and slave drives) but if you do not see the Maxtor drive from My Computer, then you need to delete the partition on the Maxtor drive, create a new partition, and format the drive, in this case you will not recover any of your original data.
To do this, you need to go to the Control Panel, Then Administrative Tools, then Computer Management then Disk Management. Right Click on Disk 1 (it should show a 80 Gb hard drive), delete the partition, then it would show this as an unallocated drive.
Right Click on this drive again and create a primary partition, follow the instructions and format the drive in NTFS file format.
Posted on Nov 29, 2008
The orange light continuously blinks on my NEC MultiSync FE990. I'm thinking it might possibly be the video cable which is attached to the monitor. If this sounds like the problem, how would I...
It could either be the Monitor has gone bad, the video card in your tower, or the cable connecting the two, the orange light signifies that the system is not getting the signal from the tower. Try replacing the VGA cable, if this is not an option try using the monitor on a different computer, if still no picture then the monitor is no good, if you get a picture try a second monitor with your desktop. If you get no picture then it is time for a new motherboard or graphics card. As far as replacing the cable if it is one piece with the monitor, it isn't recommended unless you a very comfortable opening the monitor up, in which case you risk causing more damage.
Aug 01, 2011 | NEC-Mitsubishi NEC Display Solutions...
In a move my NEC MultiSync 5FG monitor got disconnected from its BNC cable (5 BNC). Now I don't know which leads connects to which ports. Can anyone help?
The cable should be labeled with R (RED video signal), G (GREEN video signal), B (BLUE video signal), V (Vertical Sync signal), and H (Horizontal Sync signal), so you just have to match the plug to the sockets.
I hope it is clear explanations.
Dec 31, 2010 | NEC MultiSync 5FG (White) 17" CRT Monitor
Hi I just bought 7 NEC Multisync LCD1550v monitors and they all have the same problem. when plugged in all i get is a blinking power light. 1 of them showed signs of life for just a second but that was it....
You buy a new LCD Monitors, now still not working., if that new LCD Monitor is OK, then check your VGA Card, its inside the CPU maybe its broke or not connect properly inside. This are the cause of not displaying in your LCD Monitors.
If you here some beeps of your CPU then find out how many beeps and tell us here immediately.
Aug 03, 2009 | NEC-Mitsubishi MultiSync LCD2170NX (Black)...
Multisync 1735nxm screen dosent work
Your video card may be the issue. Can you try another monitor or try this one on another PC? This will eliminate or verify the monitor.
Mar 18, 2009 | NEC MultiSync LCD1735NXM (Silver, Grey)...
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
NEC-Mitsubishi MultiSync 1735NXM
is is power related problem see the adoptor is ok or show it service center. bye
Sep 24, 2007 | NEC-Mitsubishi MultiSync 1735NXM Monitor
Open Questions:
See all Dell Dimension 5150 Intel Pentium 4 w/HT Questions
Computers & Internet Logo
51 people viewed this question
Clive
Clive
Alun Cox
