Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I am able to read a Word file from the external hard disk, but when I edit it and try to save it as the same file I get the message that the document is read only. The same happens when I try to save it using another name.
  • dennis_crawl Jun 17, 2009
    Thank you very much for your help. That appears to have fixed the problem on that document. But I think it means I will have to do that with any document I want to edit on the external hard disk. The fuller story is that the external disk - a Maxtors Basics Portable - was used as a back up to my last laptop, which operated on XP Pro. It operated perfectly well there, allowing me to edit as I wished. The new laptop operates on Vista Premium. If the new software is causing the problem, can anything be done?
  • 72 Answers
Try right clicking on the folder that document is in and select PROPERTIES. See if the read only box is ticked. It could be that the entire folder is set to read only.
Posted on Jun 17, 2009
  • blu scarab Jun 17, 2009
    If you go into MY COMPUTER and right click on the drive letter of that portable drive and select PROPERTIES, you can untick the READ ONLY box the same way you did it for the individual folder. This will take off the readonly flag for everything on that drive. Depending on how many folders and files are on there, it might take a while since it will scan each folder and file to take off the read only flags.
    Why this happened could be because the previous laptop was on a corporate network or something that required a password. By shifting the drive to a new computer could cause a mismatch in the credentials. OR......someone may have inadvertently set the read only flag for the whole drive.
I have an external WD My Passport hard drive but Pages says it cannot create a file when I try to save a document on the external hard drive. Is it because the file format is not compatible with Imac? Can...
Apple Pages has a few bugs like this. There is a work around.
  1. Save to Desktop or Documents folder on the System Drive
  2. In Finder, move the file to your external drive.
  3. Now when you open the file from your external any saves will continue to go to your external drive.
It's a bit of a pain but works for now.
All the best
Mar 29, 2015 | Apple iMac Desktop
How to move/copy user files to external hard disc (wall or usb powered) so that productivity applications default-save to the external hard disc (virtual drive) foldervia the serial bus rather than to
The answer is simple. Where files are saved by default is determined by the options you set in the software application. For example in Word, go into "File" , choose options and look for "save" on the left side. Then navigate to the drive and folder where you want your docs saved to, and make it the default. Same goes for Excel, and other apps
Oct 29, 2014 | Computers & Internet
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Dec 11, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
Currently my 500 GB WD External Drive has 353GB as free space. But when I try and add a 6GB file I get the following message "Error Copying File or Folder Cannot copy filename: There is not enough free...
How many directory deep is the file going that you are trying to save? I believe the maximum NTFS file (location + name) of file length can not exceed 256 characters total.
Example: C:\user\documents\file.exe is OK
But: C:\user\documents\folder\folder\folder\folder\folder\this folder name 230 charicters long\file.exe BAD
Feb 05, 2010 | Western Digital My Book Essential Edition...
I'm a teacher. I store all my documents on Simpletech pininfarina 500GB and take the drive from work to home. I need to be able to transform the documents as I go but it doesn't let me ad or delete any...
they may be "read only" right click on one of the docs (assuming they are Word files) go to properties - untick the box that says read only.
when you saving files - go to save as 97 to 2003 doc
the global template (normal.doc) may be saving as read only
Nov 14, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
When I right click a file, select "send to" then WD digital book as the recipient, the following error message "the target cannot handle this type of document" is received
You have to save documents to the drive.
When you send the documents to the drive it means that you want the drive to read them for you.
Not being a program that recognises the document it comes up with that error.....
Oct 09, 2009 | Western Digital My Book Essential Edition...
Tring to back up pc to elements 1 tb external hd
Fat32 simply means that your hard drive can only read files up to 4GB, format your external harddrive using file system NTFS then try to back up all your files again. Hope it helps you...
Jun 22, 2009 | Western Digital My Book Home Edition 500...
Cannot Read External Western Digital Mybook 500GB Drive
I have ".Window 7." Sometime I see a icon and it shows the drive size and can't read and my work. Yes, I do save my work on my hard drive, but I also want to save it on my external drive. . I even reboot.
Jan 13, 2009 | Western Digital 500GB My Book World...
The file system of my hard drive become RAW.
http://www.z-a-recovery.com/unformat-tutorial.htm
This tutorial describes the procedure to recover one volume when
  • the volume was accidentally formatted
  • Windows reports the volume is "raw filesystem", or "not formatted"
  • An external drive failed, either flash (so called "thumb drive") or an hard disk connected using USB or FireWire enclosure.
  • MFT is corrupt on the NTFS volume, rendering filesystem partially or completely unreadable
The recovery is done in seven steps, requiring about eleven (11) mouse clicks. Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
plashkablue_left.gif Step 1 - Get, install, and start ZAR
plashkablue_right.gif box-top-l.gif box-top-r.gif Download and install ZAR just like you do with any regular program.
When you run it, ZAR displays the window like the one below:
  1. Click "Next >>"
plashkablue_left.gif Step 2 - Select processing mode
  1. Select "Recover data from a simple volume or from a functional RAID volume"
  2. Click "Next >>"
plashkablue_left.gif Step 3 - Select physical device to recover
  1. Select the appropriate hard drive
  2. Click "Next >>" for a list of volumes (logical disks) on this hard drive
Nov 19, 2008 | Western Digital My Book Essential Edition...
I have certain text on a CD disk that I would like to edit. Computer tells me when I try, that it is "read only". How do I change mode to "read/write" to permit editing?
CD's are normally "read only", so the edited files cannot be saved back to the same CD.
You need to copy the documents you want to edit to your PC, edit, then save them to the PC. At some point, you may want to create a new CD with the edited files.
Put the CD in the computer, open up "My Computer". Double click on the CD (probably the "D:" drive) and right click on the file you want to edit, and choose "Copy".
Now go to "My Documents" on your computer (you can use the Start button to find it), and open that folder.
Right click again, and choose Paste.
Doubleclick the newly pasted file, and Word will allow you to edit and save it. You might want to use "Save As" instead of "Save" and give it a different name. So, Doc1.doc becomes Doc1a.doc or something similar.
There are other ways to do this - I'm giving you the most basic method.
Jul 15, 2008 | Microsoft Word 2003 for Students &...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
77 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
