Question about Toshiba 42HP95 Television
Will not turn on
Toshiba 42hpx95 plasma tv
TO ALL YOU TOSHIBA 42HPX95 I FOUND THE REAL PROBLEM ON THESE TV'S IM NOT SAYING THIS IS THE SOLUTION TO ALL TOSHIBA PROBLEMES BUT I GOT TOO OF THESE AND MANAGED TO REPAIRE THEM FOR ALMOST NOTHING "!!!!!' THE DEFECTIVE PCB IS THE SIRIEN PCB OR WHAT WE COULD CALL ACCESORY PCB THE PCB IS SHORT CREATING A OVER LOAD CONDITION AND THE PROTECT SYSTEM DOES ITS JOB I AM INCLUDING TWO PICTURES THE FIRST ONE WHATS THE ACCESORY PCB AND THE SECOND WHAT CONNECTER TO DISCONNECT IN THE SECONDARY SMPS WHAT YOU HAVE TO KNOW IS THAT YOUR PIP WILL PROBABLY NOT FONCTION ANY MORE YOUR PCCARD READER WITCH IS TOTALLY OUT OF DATE AND OUT OF DATE COMMUNICATION PROTOCOLS LIKE IEEE 1394
AND G-LINK AND MAYBE THE CARD READER ON THE SIDE IF NONE OF THESE ACCESSORYS ARE VIMPORTANT FOR YOU WELL YOUR TV IS FIXED IF THE ARE SIMPLY REPLACE PCB THE NUMBER OF THE PCB IS PD2266 I FOUND ONE FOE 120 DOLLARS AT SHOP JIMMY ALSO IF YOU MANAGE OUT WELL WITH A OHM METER HERES A TEST YOU CAN DO DISCONNECT TV FROM POWER DISCONNECT CONNECTER PJ63 ON ACCESSORY PCB WITC OHM METER TEST BETWEEN GROUND PIN 2 AND PIN 1 DO THIS ALSO WITH PIN 3 AND 4 THERE MUST BE NO CONTINUTY WITH GROUND ! HOPE THIS WILL HELPwill not turn on - tombou300619.jpgtombou300619_1.jpg
Posted on Nov 17, 2010
  • isaac_maton Jan 07, 2011
    my tv work's again thanks for u help
  • Anonymous Jan 07, 2011
    it was a plessure to help
  • 3 Answers
Go to badcaps forum and sign up. There,s a post thread that helped me fix mine. The red blinking lite indicates the siene brd had a bad surface mount cap. I got the cap from partsstore.com. Cost me 7.67 and it,s fixed. There,s pictures there you can access as a member showing the board, how to troubleshoot,factory tech.service order and more.
Posted on Mar 29, 2012
Toshiba 42HP95 problems - I have no picture and it was with the repairman for almost four months. He kept saying the parts he ordered were bad and he had to reorder, but hen he said he called Toshiba and - supposedly - they said it was the picture that was bad. He was thinking it was something else. Long story short is that now he claims this in not repairable??
Does that make any sense? This TV is not that old and we paid quite a lot for it because we bought it BEFORE the prices dropeed fpr TV's.
Posted on Sep 21, 2011
3 Suggested Answers
SOURCE: Toshiba 42HPX95 wont turn on
I am having the exact same problem with my Toshiba 42HP95. From the information that I have been able to glean from the internet, it looks to be some sort of problem with the power supply or some other component of the power circuit. I am giving up and getting service
Posted on Jan 16, 2008
SOURCE: 5-inch black horizontal line across screen
Unplug the tv wait a minute .Plug it in turn it on see if that fix the problem. these tv are computers and can go hay wire.just like a computer ,some times a reboot will fix things for a while.make sure you have a good clean source of power at the receptical and your not having power spikes or drops . Good Luck!
Posted on Jul 29, 2008
My toshibn tvwont turn on stuck ontimer rec
Do a hard reset to this set and check. Just disconnect the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure should make it a hard reset. If it do not help you, contact any service technician. Gopakumar Gopalan Google
Apr 26, 2014 | Toshiba 42HPX95 42 in. Plasma Television
I have a 46 inch Toshiba plasma tv. It is having a problem where the picture does not come up as soon as I turn on the TV. After about 20 minutes of warming up, the picture appears as normal but during the...
This tv is not repairable only can be replaced the Plasma screen itself.Not woth it,replacing the plasma screen,will cost the same as a new tv.This problems,u discribing is the Plasma screen itself sure comming to used and ages.Not any electronic boards componnent.Because the floorscents Plasma gas u seeing on the screen itself forming and lighting up the Plasma screen itself.
Dec 31, 2010 | Toshiba 42HPX95 42 in. Plasma Television
Toshiba 42hpx95 wont turn on.. when i unplug and plug in i can hear a sound but then a red light on the front starts blinking and it does nothing
AND G-LINK AND MAYBE THE CARD READER ON THE SIDE IF NONE OF THESE ACCESSORYS ARE VIMPORTANT FOR YOU WELL YOUR TV IS FIXED IF THE ARE SIMPLY REPLACE PCB THE NUMBER OF THE PCB IS PD2266 I FOUND ONE FOE 120 DOLLARS AT SHOP JIMMY ALSO IF YOU MANAGE OUT WELL WITH A OHM METER HERES A TEST YOU CAN DO DISCONNECT TV FROM POWER DISCONNECT CONNECTER PJ63 ON ACCESSORY PCB WITC OHM METER TEST BETWEEN GROUND PIN 2 AND PIN 1 DO THIS ALSO WITH PIN 3 AND 4 THERE MUST BE NO CONTINUTY WITH GROUND ! HOPE THIS WILL HELPtombou300619.jpgtombou300619_0.jpgtombou300619_1.jpg
Sep 13, 2010 | Toshiba 42HPX95 42 in. Plasma Television
the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Apr 29, 2010 | Toshiba 42HPX95 42 in. Plasma Television
2vertical Black bar
need replaced y board ..
The Y SUS board is only supplied as part of the PDP.
Nov 09, 2009 | Toshiba 42HPX95 42 in. Plasma Television
Jul 28, 2008 | Toshiba 42HPX95 42 in. Plasma Television
Dec 01, 2007 | Toshiba 42HPX95 42 in. Plasma Television
Televison & Video Logo
853 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
