Question about Hoover F5826-900 SteamVac Upright Wet Washer
I can't get my attachment to put out the solution
  • 483 Answers
According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
Posted on Jun 17, 2009
How do I put attachments on classic handheld dirt devil?
They would have to be attachments compatible with that particular model, and they usually come with it as original equipment. but you might try a Google search for Dirt Devil (model number) attachment kit. Also found this on ebay:
Original Dirt Devil by Royal Mini Attachment Kit Some Parts New Un Opened...
May 09, 2016 | Vacuums
Dyson attachment
Dear Anon, I'm not familiar enough with the Dyson units to know exactly what the stair attachment is or what it looks like. If it is an attachment to connects to the end of the hose then it should come off the same way it went on. I usually use a twist/pull method to get these types of attachments off of the wands. If this method fails try getting something metal, very flat, that can be used to slide along the side of the wand striking the flat side of the attachment connector. This action sometimes loosens the connector enough to allow it to be removed.
If these methods don't work for you, you may have to break down and take to a vac repair shop and ask a repair tech to help you. Good luck!
Jul 26, 2014 | Dyson DC25 All Floors Bagless Upright...
Lost manual. How do i hook up the suction part of the furniture upholstery attachment? I know where to plug it in to spray cleaner on the furniture but where does it plug in to **** it up? Model...
on the attachment where you put the attachment remove the lid, then remove the back panal, and slide the suction thing down not much pressure, re apply the lid then put back in vacuum, turn on and there you go...
Sep 02, 2011 | Hoover F5906-900 Upright Steam Vacuum
How do you put on the attachment hose to clean stairs
Assuming the rug nozzle is currently attached, lift up the headlight hood. Twist the belt lifter (black plastic square) on the rug nozzle counterclockwise to remove the belt tension. Then pull the accessory lock up until the rug nozzle comes loose of the Power Plant. You will notice two hinges at the bottom that hook on the the Power Plant's attaching bar. Gently lift up the rug nozzle to unhook it from the attaching bar.
Now your Kirby is naked. You will notice two small hooks on the hose attachment--hook them over the attaching bar, place the end of the hose attachment firmly against the Power Plant, then push the accessory lock down to clamp the hose in place.
You are now ready to use your Kirby with the hose attachment.
May 20, 2010 | Kirby Heritage II Vacuum
Can't get the bag attachment off my Kirby to use the shampooer.
You have to twist the bag attachment counterclockwise to release it. Then put the shampooer on opposite from that. Line up the arrows when putting attachments on.
Apr 06, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Putting on the attachments for the kirby g4
Well... some attachments you may end up not using at all... some of them are very handy...
I have online manual for attachments HERE
Good Luck
Mar 02, 2009 | Kirby G4 Bagged Upright Vacuum
How to put the attachments on the g4
Good Luck
Using my kirby vacuum
you have to put the screen attachment on the front of the machine where the nozzle goes then place your hose where the bag attaches then put on your attachment on the end of the hose
Mar 26, 2008 | Vacuums
Not sure what these parts are officially called, but...
There is a sort of blank cap that replaces the floor attachments.  It has a plastic grill front to keep fingers etc out of the input while blowing.  Then, the bag unscrews, unlocks with a partial turn counterclockwise, and PULL.  Then there is an attachment that replaces the bag holder and the hose fits on this attachment.
That's it.  Now the input is shielded, and the output air comes out the hose.  If you want, you can also take the upright handle off and put the small handle on to hand hold the body of the machine while blowing. One safety issue - the holes in cap on the input side are certainly large enough for sand or small debris to pass through it.  This debris would then be ejected out the blower side at high speed.
Oct 13, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Hoover F5826-900 SteamVac Upright Wet Washer Logo
226 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
