Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
PVS50 rheem power vent water heater do not reignite/restart/kick
I have 3 year old Rheem PVS50. It works fine once plugged in to power supply. After it reaches the desired temperature it shuts off also. But it does not restart/ reignite/ kick back once water is consumed and it is again below desired temperature set in thermostate. I need to remove power supply and reconnect it. then it starts again and problem repeats.
The small red LED shows "two blinks and off for a while" signal when it is not working. The LED constantly blinks when working good.
  • 332 Answers
I actually just installed one of these the other day, I found that the ignitor wires were straped to the gas inlet and they were shorting out,, I wraped them with electric tape and the unit came on and stayed as for the thermostat make sure your flue is clear of all obstuctions even outside, make sure on the vent on the top back of the unit is clean and no lint or dust has built up on it, you can take a small soft brush and just sweep it across it
Posted on Jun 21, 2009
Works for 2 or 3 min then burner kicks out
www.rheem.com/products/tank_water_heaters/contact_support
Jul 03, 2014 | Rheem Richmond 50 Gal LP Gas 6 Year Tall...
The indicator light stays on our PVS50 water heater.
You have the Robershaw wiper gas control valve.
Here are error codes and troubleshoot table for that gas control.
http://waterheatertimer.org/pdf/Robert-shaw-gas-control-error-codes-1610.pdf
Here is general service manual for power vent water heaters.
http://waterheatertimer.org/pdf/Power-vent-water-heater-service-manual.pdf
Here is general parts list for that water heater, 2009:
http://waterheatertimer.org/pdf/Rheem-power-vent-RS-parts.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 20, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
I too have an issue where our Rheem power vent water heater will not stay lit. I cannot see that it has a thermocouple though. I can only see the "glowplug" with two wires. The glow plug is fine....
You do not have thermocouple on your unit, you have a sensor. Rheem power vent water heaters ir very sensitive to any pressure changes. There are several things you can do to trouble shoot your water heater. Make sure the flue vent is fully open all the way out of the house. Unplug the unit from its electrical power source for 3 minutes, and then rest the heater. Make sure you have an adequate fuel supply, you may need to contact your local utility for a free inspection.
Dec 06, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem power vent motor doesn't shut off
There could be blockage in your water heaters venting on the outside of the home. It sound like the high limit switch has been tripped. Try unplugging the tank and plugging it back in. this will reset the tank. if the problem persists you will want to call your provider for service.
Oct 07, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
Unit stops heating and must be unplugged to 'reset' once a week.
do you have alot of suit in the flue??? take the flue off and clean it then clean the burner assembly and see if this doesn't help you
Jun 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
2,798 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
