Question about Aiwa NSX-D9 Shelf System
No reception I have an old Aiwa NSX-D9 (1994 model, maybe?) with a TX-N9 tuner that came with it. The speakers are now Acoustic Energy AE100, though. When I turned on the set, the tuner did not seem to pick up any signal, not even static. However, the system was working well just a few hours earlier. The CD and cassette deck were broken before the incident and the system was left on standby for a few days.
  • 298 Answers
SOURCE: Aiwa NSX-KT9
Try replacing the Carousel belt.
Posted on Feb 29, 2008
  • 135 Answers
SOURCE: Aiwa NSX-V70 Cassette deck Belt?
http://www.donberg.ie/warehs/groupba.htm
try here
Posted on Jan 18, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: right i have an aiwa mx-n9 + mx-n7 systems mx-n9 keeps
These little fans are driven by fluctuating currents not DC current. It is a problem with the circuitry the drive it. The current are pulse width modulated, which is how the speed of the fan is controlled.
Posted on Jul 01, 2009
  • 4234 Answers
SOURCE: I have a NSX-V70 stereo. Tapes and CD do not work, FM/AM is fine
Your unit needs a little TLC. Let me address the likely problems/solutions:
1) Tape deck stuck - The most common problem here is that the belt has gotten slippery. This has prevented the mechanism from resetting to a known position and that is what prevents the door from opening. Hopefully when you pried it open, nothing bot broken.
2) Both tape drives run from the same motor and use different belts. The same applies to the second deck as the first. The belts are sliping and need to be replaced.
3) The CD lens is probably dirty and needs to be cleaned. The fact that the CD stops and an attempt is made to play it suggests that the optics are working enough to detect the disc. Clean the lens using a cotton swab and alcohol and that should resoplve the CD problem.
If you have not opened up these before, I would not suggest you start without someone around who has. There are 3 belts that need to be chagned for the cassette section to work. Plan on $15-$20 for the belts.
Dan
Posted on Feb 23, 2010
Grubhead
  • 5515 Answers
SOURCE: i have a nsx-9000 cassette deck will not play.
Make a note of how the belt fits, then remove it and measure the diameter. Then buy a replacement, belts do go bad from time to time, so a new one might cure the problem. Put the diameter size (to the nearest mm result, IE: 50 or 55mm, not 52mm! Into google and "cassette belt" and you should find one for the job.
Posted on Feb 27, 2010
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK"...
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Jan 09, 2013 | Aiwa Audio Players & Recorders
Sx-nd22 speaker to be connected whihc one is positive and which wire is negative
http://www.retrevo.com/support/Aiwa-NSX-D22-manual/id/1076dj393/t/2/
Page 4:
1 Connect the front speakers.
Connect the right front speaker to the SPEAKERS R terminals and place it on the right side of the unit. Connect the left to the SPEAKERS L terminals and place it on the left side.The speaker cords with the white stripes go to the + terminals.
Jan 15, 2011 | Aiwa NSX-A777 Shelf System
How to open the speaker cabinet of aiwa nsx-k780 stereo system? there are no screws at the back panel of the speaker
most are glued together. or some models the screws are in the speaker if the grill pulls off.
Dec 15, 2010 | Aiwa Audio Players & Recorders
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Right i have an aiwa mx-n9 + mx-n7 systems mx-n9 keeps
Jul 01, 2009 | Aiwa Audio Players & Recorders
My Aiwa NSX-999mkII keeps switching off
Without speakers indicates that it is shutting off due to thermal protection. Do not store anything on top of it, especially any device that has heat of it's own and give it plenty of air space all around it, at least 6 inches.
Jun 17, 2009 | Onkyo TX-8511 Receiver
Aiwa NSX-D9 Shelf System Logo
48 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
