Question about Mitsubishi WS-65313 65" Rear Projection HDTV
Fuzzy screen on my mitsubishi HDTV 1080 series WS-55313
I just bought a used WS-55313 Mitsubishi HDTV 1080 series and I was hoping to get some help on a clearer picture for the TV Stations. The DVD screen quality is beautiful and clear; however, I have attached the TV to the conversion box required to get our local channels due to the digital conversion and the picture is very fuzzy. The same line hooked up to another (smaller) TV was clear. Is there something that I can do to get a crisper view or is this strictly the digital service coming through? I greatly appreciate your time and assistance with this issue.
TVtechmaniac
  • 140 Answers
SOURCE: Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Posted on Aug 25, 2007
pattersj78
  • 70 Answers
SOURCE: mitsubishi ws-55809
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV.  If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i.  Otherwise, use the 2 other component connections directly to the left of the DTV connections.
Posted on Oct 19, 2007
Slinteriors
  • 8617 Answers
SOURCE: T.V. Problems
sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Posted on Jul 22, 2008
SOURCE: Cleaning the bulbs and mirror on my Mitsubishi 55" WS-55313 TV.
You should re-consider having a tech do that for you. The access is by removing the screen assmbly which are somewhat fragile. If you want to give it a try, pull the speaker grill off, it comes off just from pulling it, there should be five screws across the bottom of the screen assy, remove those, there is also an access door on the front of the set with four screws, that has to be removed to unplug the cable that goes to the screen sensors. The screen assy has to be lifted straight up an inch or two and then you can pull it forward away from the set.
As far as cleaning the mirror and lenses, you can't get to the face of the tubes so it's the top of the lenses that you clean, just use a soft lint free cloth (cloth baby diaper) and wipe the dust off the lenses, you can slightly dampen the cloth with water if necessary, same type of cloth on the mirror and you can use a glass cleaner on it just don't press too hard on the mirror.
Posted on Feb 05, 2009
ltfrc
  • 227 Answers
SOURCE: No Audio with HDTV on Mitsubishi WS 55859; no problem w analog tv
Have had bad exprience with RCA converter boxes. The box will lose audio and has to be turned off and then back on. You may want to hit mute during this process, the volume varies from analog to DTV. If you have no problem with analog audio I would look into a different converter box.
Posted on Feb 22, 2009
Mitsubishi ws-55313 vertical hold problem with tv
This set does not have a vertical hold control etc---try to explain what the set is doing or not doing so I or another expert can help you.
SD TECH
May 18, 2011 | Mitsubishi WS-55313 55" Rear Projection...
How to cancel pip on mitsubishi ws-55313?
Usually the PIP control toggles on and then off.
Hope that helps
Jan 01, 2011 | Mitsubishi WS-55313 55" Rear Projection...
WS-55313 Where can I find replacement Lenticular screen?
800-553-7278 CALL MITSUBISHI PARTS
A WS-55413 LENTICULAR SCREEN IS $171.10 + DELIVERY BUT THE DIAMOND SHIELD ISNT NEEDED THEY TELL ME AND IT WAS DISCONTINUED ANYWAYS BUT YOUR PART IS PROBABLY AVAILABLE THERE.
Nov 24, 2010 | Mitsubishi WS-55313 55" Rear Projection...
I have a 2004 1080 HD Mitsubishi TV that has pink lines running across the picture.. How can I fix this.
Pink lines can mean many things, what does the set look like if you take it in the customer menu and select convergence and then advanced?
The more you tell me the better I can help. Post a comment here to let me know
SD TECH
Aug 23, 2010 | Mitsubishi WS-55313 55" Rear Projection...
I just noticed my ws-55313 has a fuzzy middle, almost egg shaped, the letters on the top and bottom and outsides are sharp, the letters in this area in the middle are puffy, on the convergence setup srceen...
HI,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} CHANGED Z SUSTAIN BOARD.PICTURE PERFECT.APART FROM WHITE DOTS..THINK IT COULD BE DUST OR FINGER PRINTS ON RIBBON JOINTS,,WILL RE CHECK AND WIPE F/PRINTS TO SEE IF ANY CHANGE.
HOPE THIS HELP
May 25, 2010 | Mitsubishi WS-55313 55" Rear Projection...
I bought a used mitsubishi ws 55513 and when i turn the tv on is says 480i stretch. How do i use the 1080?
U don't get to chose modes.480,720 and 1080 it chose by the tv show itself.Want more 1080 must have HD package from cable or satalite compannies.
Jan 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Mar 12, 2009 | Mitsubishi WS-65311 65" Rear Projection...
HDTV Reception
Yes , If  a  high definition device is connected to the tv then you can watch high deff tv.
Dec 21, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-55313 no video
Resolder the vertical output IC that should take care of your problem.
Jun 16, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi WS-65313 65" Rear Projection HDTV Logo
371 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
