Question about Dell OptiPlex 170L PC Desktop
Front Panel help for Dell Dimension 4600
I need to know how to connect back my front panel I/O pins in my Dell Dimension 4600 (Dell F4491 or N2828 MotherBoard). I have no idea on how to connect back my Switch On/Off, Power LED wires. Can anyone help?
  • yu_buffon Jun 18, 2009
    The prob s there r no any labels on the motherboard.. N the Malaysian Dell website wont reply us unless v renew our warranty. just to connect a wire, am I gonna spend that amount of money?? Anyone help plz!!
  • 42 Answers
Go to dell site and query for *********** board specs. Then query for the pinouts on the board. Or goodle dell optplex+motherboard+hardwire connections. good luck
Posted on Jun 17, 2009
    Novelist:
  • 166 Answers
Most Dell's have a connector that all of the front panel wires go in to. That connector should only fit one place on your motherboard. If you use a flashlight you may be able to see some writing on the motherboard that will lead you to where it goes.
9-pin control panel connector (J7J2).
Hi this is Alex Walker I am expert to help you for your issue call me +1(404)981-1535
Dec 03, 2011 | Dell Dimension 4600 PC Desktop
Dell case 4600 replaced mother board with gigabyte but front power wiring needs different connection plz show diagram
Pinout (Wiring diagram) for the GigaByte GA-8I865GVME motherboard's Front Panel header,
(Looks like a 1 but it is an 'Eye'. GA-8 i 865GVME ),
{The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel cables (Wires) connect to, is the Front Panel header }
;Motherboard Manual download page,
http://www.gigabyte.com/products/product-page.aspx?pid=1933&dl=1#manual
Look under the heading - English
Look across from English, and click on the country name nearest yours.
This is a PDF file. After you click on the server country it may take 30 seconds or more, to see the first page come up.
It may also take additional time for the file to fully download.
(Took approximately 30 seconds just now for me. Medium speed DSL connection)
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 6.
Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner.
(F_PANEL)
It is two rows of pins that are laid out horizontally. It is parallel to the bottom outside edge of the motherboard.
Go to Page 22.
F_PANEL (Front Panel Jumper)
The pins are numbered Even on the top, and Odd on the bottom.
Starting at the Left side of the motherboard going to the Right, for the TOP row of pins;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20
Starting at the Left side of the motherboard going to the Right, for the BOTTOM row of pins;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19
A) Pins 2 and 4 are for the Power On LED light. (On the computer case. Not on the motherboard)
(Pin 2 is for the Positive { + } wire.
If the LED light is dim, switch the wires around )
B) Pins 6 and 8 are for the Power On switch. (Plastic - Power On button assembly has the Power On switch inside it)
C) Pins 10 and 12 are not used. In fact there probably isn't any pins.
D) Pins 14, 16, 18, and 20 are used for an internal 'speaker'. The 'speaker' is used so you can hear any BIOS Error Codes. (The computers way of telling you something is wrong, and an area to look into for it)
E) Pins 1 and 3 are for the HarDDrive activity LED light.
The LED light that blinks when the harddrive is active in use.
(Pin 1 is for the Positive wire)
F) Pins 5 and 7 are for a Reset switch, IF USED.
G) Pin 9 is NC. Not Connected
To Add:
1) If the Dell Dimension 4600 power on LED light has 3 wires, it is a dual color LED.
Only use two of the wires, and one color.
(Follow the wires to the LED light. One is a Ground wire { - }, and the other two are positive wires for the dual colors of the LED )
2) The Front USB headers are on Page 24
Make sure your Power Supply has a 4-pin ATX +12 volt power cable. Plugs into the square connector on the motherboard, to the bottom Left corner of the Processor socket.
It is power for the Processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
CAUTION!!
For a time period Dell was really @nal about being a Proprietary computer manufacturer.
This means they wanted THEIR parts used in THEIR computers.
I don't know if your Dimension 4600 falls into this category, or not.
They switched the pins around in the ATX main power cable connector, on the motherboard.
Go to Page 18.
Look at the connector that has 20 socket holes. (Two columns of 10 socket holes)
The Dell Dimension 4600 also has a 20-pin ATX main power cable connector, on the motherboard,
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/techov.htm#1138239
Scroll the page down a little, look at the illustration for the DC Power Connector P1
See how the power and color of the wires are labeled for each pin in the connector?
Orient the connector by the lock tab on the side of it. Now compare the color chart here for the wires in a standard 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
A) Orange colored wires are 3.3 Volts
B) Red wires are 5 Volts
C) Yellow wires are 12 Volts
D) ALL Black wires are Ground wires
(ALL are DC voltage)
Guess what would happen if a 12 volt wire is connected to a pin that uses 3.3 Volts, or 5 Volts?
Yep, lets the 'Smoke' out of the motherboard.
Guess what would happen if a 3.3 , 5, or 12 volt wire is plugged into a pin that is a Ground wire?
Same thing. Will fry the motherboard. Possibly the Processor, Ram Memory, Harddrive, and so on, also.
Check before you plug in, and turn the computer on.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page. Our site is constantly undergoing changes)
Regards,
joecoolvette
Jul 18, 2011 | Gigabyte GA-8I865GVME Motherboard
I NEED HELP IN REPAIRING THE FRONT HEADPHONE JACK ON THE TOWER, AND WOULD LIKE TO HAVE ACCESS TO THE SHOP REPAIR MANUAL. DELL DIMENSION 2400 DESK TOP PC, THANK YOU AND KINDLY APPRECIATED !!!
You can just remove and replace the front I/o panel rather than repairing it . The part is not more than 10$. You can get the part from the following site
http://www.txcesssurplus.com/servlet/the-5850/Dell-Dimension-2400-4600/Detail
or
http://www.impactcomputers.com/d0971.html
How to remove the front panel
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/fpanel.htm
Thanks for using fixya
Proton
Aug 20, 2010 | Dell Dimension 2400 PC Desktop
What tool do I need to remove the cover of a Dell Dimension 4600PC Desktop
There is no tool neccesary to remove the side and front panel. Once the side panel is removed, there is a tab that will have a curve to it on the side of your cd drive and also tabs down the side, disengage these and the front cover will break free and pulll to the right and straight back. do this in reverse when reinstalling you will hear clicks when the reengage the chassis. Hope this helps
May 15, 2010 | Dell Dimension 4600 PC Desktop
Show me where the printer should connect to the back of dimension 3000 tower windows xp
google for dell dimension 3000 and you find the manuall see below i found it on :
http://support.dell.com/support/edocs/SYSTEMS/dim3000/en/SM/index.htm
Connectors
External connectors:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Network adapter
RJ45 connector
PS/2 (keyboard and mouse)
6-pin mini-DIN
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Audio
three connectors for line-in, line-out, and microphone; one front-panel connector for headphones
Mar 12, 2010 | Dell Computers & Internet
How do i open the front cover on my DELL DIMENSION 4600?
Just check the below manual for more information on the same:
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards Anand
Feb 17, 2010 | Dell Dimension 4600 PC Desktop
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
Parallel
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
Need proper wiring for the J9C2 connector pinout
The User Manual for this m/board (E210882) can be found at :- ftp://download.intel.com/support/motherboards/desktop/d865glc/BFLC_English.pdf
you will need adobe free reader to view it. refer to pages 40 thru 46 for the front panel header and isb info.
Apr 01, 2009 | Dell Dimension 4600 PC Desktop
About front panel
Do u mean you are unable to connect any device to the front panel of your pc?
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/parts.htm#1138510
Sep 20, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex 170L PC Desktop Logo
740 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
