Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mits WD-52525 random 1-pixel jitter
Hi, I've got a WD-52525 that shows random jitter. At the beginning of a line of video, the entire line will be shifted over to the right by no more than 1 pixel. It does this at random intervals and on random lines (usually frequent enough to see it on perhaps 5-10% of the lines at the same time). Seems like a horizontal sync problem, but replacing caps has not helped. It does this on all video sources, incl. when showing test patterns. Since test patterns are generated on the FMT board itself, it seems that the HSync is too close to the edge of a clock signal and is sometimes detected late. Anyone know if this is a FMT bd problem, vs a light engine problem? Could it be a bad DVI cable? Thanks in advance!
  • 18 Answers
If you are a profetional replaced all capacitors on FMT and DM board.. or replaced the chassis........
DM and FMT board N/L/A .........
Posted on Aug 23, 2009
Picture has the jitters and horizinatl lines
Check power supply board for bad capacitors they will be swollen,vented or puffed up on top . Let me know if you need anymore help.
Mar 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
50 in mits tv wont power on. green reset light
Hi, It's either the lamp or the power supply capasitors. Thanks.
Sep 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525 can no longer connect with any input deviced, and is fuzzy in the middle of the screen.
I would "reset" the entire tv (like when you first got it) and make sure all input devices are ASSIGNED correctly and each of those has a physical connection that is good. Can you access "setup" OK?? If OK, there is a known problem with the "input board" on some Mits...not an easy or cheap repair.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mits wd-52525 i got it from my neighbor, he said it needs a new screen,but the outside looks fine, i hear glass when i move it, someone said the mirrors are broke.could there be anything else, and...
the mirror is a single unit and can be purchased from mitsubishi however you will probably have some scratches in the optics eye and this will show in your picture
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Black Screen with White Randomized Pixels
Bad FMT (Formatter) circuit board. No longer available for purchase from Mitsubishi.
The electrical chassis will need to be sent to Mitsubishi for rebuild.
Wait time: 4-8 weeks
Cost (including labor to uninstall it and reinstall it: $800 +)
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Cannot hook up my playstation2 to my mits wd 52525
on the set you have to go in to the menu and turn on those port so you can play. it should be under inputs the turn on the one you are using. if that dos not work let me know.
Aug 13, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
