Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
H400 Lights, but turns off after 2 seconds
I already have a bill for $600 and the guy is coming out again. THe gas company gave me a huge meter and says pressure and volume are good. no leaks in the pipe. Heater problem. I have verified ignition by seeing blue flame thru the sight glass
  • 5,568 Answers
There may be a pressure regulator internal to the unit that has failed. For safety, most gas appliances monitor the output of the internal regulator; in a situation where the gas pressure is unstable, if the main burner does not ignite within a finite period, they will shut down to avoid a buildup of unburned gases that could pop your windows out (or worse) if the ignitor keeps trying.
Posted on Jun 17, 2009
Once again why was I billed already when you guys ad says 30 day free trial. My second time trying to receive an answer.
Fixya is a free site where volunteers answer questions AT NO CHARM for others. If you have been billed by someone you need to contact whomever billed you. Fixya does not charge anything
Feb 10, 2017 | Time Computers & Internet
I have a Rapak P-R266A-EP-C I just hooked it up and the gas valve does not seem to work properly. The pilot burner lights up even with gas valve turned off. The main burner never lights up fully. There is...
check your gas pressure most houses have too small gas meters add all gas powered appliances give the number to the gas company they probably will up grade yuor meter to a larger one this should take care of your problem
May 26, 2014 | Raypak 266K BTU Digital Propane Pool...
BO code heayer keeps cycling on and off
check to see if proper gas pressure call gas company give them added total thems all your appliances use they probably will give you a bigger meter then everything will run efficiently
May 24, 2014 | Hayward H-series Electronic Gas Pool...
1989 xj 600 completly dead
You need new battery for sure.When you install the new battery, check it with a volt meter (D.C.) that it charges at 14V +/- 0.5V at idle with your high beam on. If it doesn't, you need a regulator/rectifier as well.
Feb 10, 2012 | Motorcycles
Electric pre payment meter problems
deary me , my first instinct would be to contact a lawyer or the CAB, failing that this a link to the energy ombudsman paste this into your browser address bar
http://www.energy-ombudsman.org.uk/links/9-0-faqs.php
some meters do have a built in log that can be read by specialist equipment , if this is possible it will show them how much electricty youve used since your entry date ( get copys of your rental agreements for dares etc ), usually a fee is payable if your found at fault ,
i hope this helps , if it does please vote
Nov 11, 2009 | Extech EX710 800A Clamp On Electric...
Dryer turns but doesn't heat
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Sep 11, 2009 | Dryers
Hayward H400 Pool heater will not stay lit
"IF" - Hayward Pool Heater Fails to Ignite: the most common reason for this problem is insufficient gas supply. The Hayward heater LED display will show a diagnostic fault code of "IF" which stands for Ignition Failure. Undetected gas pressure problems if not investigated properly may result in unnecessary replacement and servicing of your Hayward Pool Heater.
Jun 06, 2009 | Hayward H-series Electronic Gas Pool...
Gas smell when oven turned on
CALL THE GAS COMPANY AND TELL THEM YOU SMELL GAS ... SOME GAS COMPANIES STILL COME OUT FOR FREE TO CHECK. DO NOT TELL HIM A BUNCH OF DETAILS. JUST THAT YOU SMELL GAS AT THE STOVE. CHANCES ARE YOU WILL GET A NICE GUY WHO MAY TELL YOU EXACTLY WHATS WRONG AND FIX IT. EVEN IF THEY CHARGE YOU CAN PAY THEM IN SMALL AMOUNTS EACH MOTH FOR THE BILL. 50 SECONDS IS TOO LONG ...THE 20-40 SECONDS ALLOWS FOR THE SLOW STEADY INCREASE OF GAS FLOW TO START ... TO AVOID THE GAS COMMING ON AT FULL PREASURE AND CAUSING A "HARD IGNITION" OF THE BURNERS. THE GAP AND THE CORECT DISTANCE OF THE LOCATION OF THE IGNITOR TO THE BURNERS SHOULD BE CHECKED.THIS GAP IS USUALLY IN THE SPEC. MANUAL. ALSO MAKE SURE THE FLAME SENSOR IS IN THE FLAME. FOR THE FACT YOU SAY THIS IS HAPPENING TO BOTH UPPER AND LOWER BURNERS LEAVES ME TO THINK THE GAS PRESSURE IS NOT CORRECT GOING INTO THE APPLIANCE ... THE GAS COMPANY WILL CORRECT THAT. GOOD LUCK AND BE SAFE !!!! Joe_Rex
May 02, 2007 | Whirlpool SF315 Dual Fuel (Electric and...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
188 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
