Question about HP DesignJet 1050c InkJet Printer
Blank screen on hp1055 cm plus plotter, has had problems in past error msg re paper loaded improperly as well
  • Michael Schaffter
    Michael Schaffter May 11, 2010
    Does the screen light bright green? If you look at the screen at a sharp angle, do you see any letters or lines? Change contrast settings.
    New Friend:
  • 20 Answers
It Could Be a Issue WIth Firmware Dimm/Memory Module
Posted on Sep 11, 2009
  • neeraj1412
    neeraj1412 Sep 15, 2009
    Pl Share is that issue is with Roll Or sheet Feed
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Paper loaded incorrectly.remove paper in HP plotter T610.
T610 with "paper loaded incorrectly" error. Finally removed the paper roll completely and still had error. Opened top, but no signs of paper. I walked behind plotter and on the left , in the paper path ,I found the paper sensor using a flashlight. I got on my back and reached underneath to remove the plastic cover securing the paper sensor and the sensor itself. The sensor was dirty. Blew it off, reattached it and the error disappeared.
Jul 21, 2011 | HP Designjet T610 InkJet Printer
Hp designjet 500 plus 24"
HEYA
This error indicates that there is a problem in the Service Station Assembly (SVS). Either you have a paper left-over after a paper jam thats blocking the movement of the mechanism of the SVS or sometimes ink mounds around the Station if yes try cleaning it, or it could be a transient error that entails to turn the plotter off for a while and then turn it back on. If problem reappears and you are familiar in this plotter disassembly, check manually while the plotter is OFF the motion of the SVS gears; you can figure out the smooth movement.
In worst cases if problem persists i have to tell you that replacement of the SVS might solve your problem.
Hope this fixes your problem if not please reply
LONG LIVE THE GEEKS!!
Dec 08, 2010 | Computers & Internet
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
Hp plotter designjet 1055 CM plus plotter produces system error
one of the printheads is bad.....check the error code again,because 060308 does not exist in hp designjet 1055cm plotter.
Jul 31, 2009 | HP Office Equipment & Supplies
HP 755 CM CARTRIDGE MISSING ERROR
This normally points to a worn ribbon on the carrage. Make sure the ribbon where the cartrige makes contact is really clean, if cleaning make sure the plotter is turned off. Sometimes a build up of ink can cause problems. The bad news is that if the ribbon on the carrage is worn it firstly comes with the carrage as a unit, and secondally the carrage is no longer available from HP
Jan 13, 2009 | HP DesignJet 750c plus InkJet Printer
Out of media Design Jet 750c plus
u could try reloading the paper roll, i have had that prob, and had to reload paper. it always fixede it for me. good luck
Oct 14, 2008 | HP DesignJet 750c plus InkJet Printer
Blank papers comes when the print given
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
Feb 03, 2008 | Samsung ML-3051ND Laser Printer
HP DesignJet 1050c InkJet Printer Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
