Question about Dryers
Kenmore 80 dryer working but will not shut off.
Need to leave the door open or heat element will get cherry red inside. Cloths are getting way hotter than normal. Any ideas on what the problem might be? Thanks
  • speedzone Jun 17, 2009
    Sounds like the thermostat should be my first move. Where is the thermostat located and whats the best way to change it? Also whats the best way to check for a stuck switch on the motor? Thanks
  • 999 Answers
Check the operating thermostat. Make sure there is nothing blocking the vent. The element does glow red when active and the thermostat controls how long it stays on. If you are saying the element is on all the time even when dryer is off there is either a stuck switch on the motor or something shorted somewhere.
Eric
Posted on Jun 17, 2009
  • Eric Duda
    Eric Duda Jun 17, 2009
    The thermostat is on the back side of the box the lint screen goes in. The motor switch would require some ability to read the schematic and use of a VOM.
    Eric
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
I have a kenmore 80 series electric dryer it was deying cloths and just shut off . now want come back on . what would cause that to happen
Hello there and thank you for choosing fixya
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch the part testing video at the bottom of this page. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached. tbirdfan1_95.jpg
Jul 31, 2011 | Kenmore Dryers
My kenmore elite dryer is not heating up on any cycle except cotton and then it is taking multiple cycles to dry cloths. I have already cleraned the vent and hose and vaccumed out the inside of the dryer....
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the blower motor to make sure it is not faulty, also check the blower fan blade to make sure it is not broken or plugged with lint.
Check the Door Switch.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It's located on the blower housing.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Jan 14, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
I have an kenmore 80 series electric dryer that won't heat. The heat coils look good. What else could it be? Is there a test I can do to see what it is?
Check your Wiring
replace it)
Jan 06, 2011 | Kenmore Dryers
Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
My dryer still heats up when the dryer is not running
The heating element might be shorted to ground. This sometimes happens if the vent pipe is clogged with lint. The heater gets hotter than normal causing the heating coils to sag, touching the metal shield.
May 09, 2009 | Kenmore 62802 Electric Dryer
Dryer not drying correctly
The coils are getting hot and won't open the gas valve. replace them dudes
291385a.jpgMore HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 07, 2009 | Kenmore 73952 Gas Dryer
Cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Jan 02, 2009 | Kenmore 63942 Dryer
No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Nov 02, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
Marvin
Marvin
