Question about Brother DCP-7020 All-In-One Laser Printer
Same problem as mdmckinnon
Some one said to change the fuser.
where do you get it and did this work for mdmckinnon
  • 526 Answers
Eject sensor actuator is too short or the main board is defective
Recommendation: Either the eject sensor actuator is not properly actuating the back cover
sensor, which is mounted on the rear side of the main board, or the
main board is defective.
check the sensor, if its moves easily, then you have a bad main board, if it does not,
your sensor needs to be aligned properly.
not too hard to do.
Posted on Jun 19, 2009
50.9 fuzur error hp 4515
it seems like fuser problem
* turn off then turn on
* check fuser connector.
* reconnect fuser again
* if the problem persist again then change the fuser
before changing fuser check maintenance kit, if it is near 225000 then change maintenance kit
Jun 27, 2013 | HP P4515n LaserJet Printer
Error 50.7 colour laserjet 6030
Its either the fuser flag or pressure switch would be my guess. Remember when troubleshooting something. KISs....Keep It Simple....its usually the easiest thing that fixed the problem. Replace the fuser then work out from there, especially since you have a spare machine to work from. Here is the Canon Service manual page on it. Good Luck!!
From the Canon Service Manual:
50.7 Fuser Error : Fuser has experience a pressure-release mechanism error
1) Reseat the following connectors: fuser motor, fuse-unit home-position, intermediate & the DC controller PCB
2) Test the Fuser Pressure-release sensor by performing the paper-path test or the manual sensor test
3) Check the sensor flag on the Fuser Pressure-release sensor. If the sensor flag is damaged, replace the fuser.
4) Check the inside gear on the product that drives the fuser
5) Perform the fuser motor & fuser pressure release motore components test.
6) Replace the fuser Motor
7) Replace the Fuser
Jun 04, 2012 | HP COL LJ CM6030 MFP P/C/S 30PPM 1 100SHT...
Verticle lines printing on laser printer
Check the fuser. If it is the fuser, you should be seeing 3 dark lines on the fuser film. Here is the picture about how the film looks like:
Changing the film usually solve the problem. However changing the film itself is difficult. You have to remove and basically disasseble the fuser, and change the film. However it is fairly cheap and if you decide you would like to save some money, here is the link available in ebay:
http://cgi.ebay.com/Fuser-Film-Sleeve-HP-LaserJet-P3005-RM1-3740-/250558576965?cmd=ViewItem&pt=BI_Toner&hash=item3a56747945
Or, simply search for 'P3005 Fuser Film' and you will find a lot.
Other than that, you can change the entire fuser. Please note that fuser for P3005 is not consumer installable part. You still have to take out some parts in order to change the fuser.
The parts are available from many parts supplier. Simply google 'P3005 fuser'. Usually around $100 for a refurbished fuser.
You can also recycle your old fuser and get some moeny! (about $15-$25 per fuser).
Apr 09, 2010 | HP LaserJet P3005n Printer
We have put a new toner in but still we are experiencing lots of horizontal lines??
Nov 17, 2009 | HP LaserJet P3005n Printer
Brother hl-5250dn fuser unit faliure
I have 2 printers that dosn´t work. Brother HL-5250 dn One with fuser that dosn´t work. Can I take thee fuser from the other and attach it into the first one. Or do you ned spcial tools and knowldge to do it?
rolf@edeborg.se
Jan 19, 2009 | Brother HL 5250DN Laser Printer
Hp 3550 fuser problem
try this
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support
Oct 29, 2008 | HP LaserJet 3550 Printer
Hp 4350 error code 50.3
I have just changed the fuser unit and the printer is still giving the
same error [fuser error and low heating] Kindly help.
Maxwell Mpundu@technet.co.zm
Apr 21, 2008 | HP LaserJet 4350 Printer
50.2 fuser errer message
Hello, even i am having the same problem. I was looking online and found this stuff: step 1: Turn off the printer and switch it on after 20 mins. Step2. If the above step doesnt work then remove the fuser and replace it back again. Step3: if the above two stpes doesnt work and you still have that error message, then remove the fuser and check the impedance, if its below the required level(i dont know whats the required impedance is), then you have to change the fuser. I tried both step1 and 2, it still shows the error message, i guess i will have to change the fuser. Let me know if this helps Susheel
Oct 03, 2007 | HP LaserJet 2840 Printer
Brother DCP-7020 All-In-One Laser Printer Logo
80 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
