Question about Mitsubishi WS-55511 55" Rear Projection Television
Wavy green lines and offset during convergence calibration
My T.V. seemed to loose sync on the green gun. There are two pictures offset vertically on the screen. I went to the convergence screen and the green target is offset to the right. The red and blue targets align with each other perfectly, but they cannot be moved far enough to the right to match the green target. When I went to the advanced convergence screen, the blue and red lines are straight and aligned across the entire tv. The green lines are offset the the right, are not perfectly straight and are jumpy/wavy at the top 1/4 of the screen. The set is 4 years old and has never had any service.
  • mike_e Nov 01, 2007
    Techman, could you please send me the information on changing the capacitors. I'll get all of this done while I have it apart. Thanks
    mje@oceansurveys.com
    President:
  • 3,130 Answers
There is whats called a convergence IC that is going bad inside this TV set. There is only one for all three tubes and the IC number is STK 393-11- and can be purchased here http://www.electronic-repair-kits.com/STK393-110.html You will only need to order one. If you are handy and can solder this should correct your problem. One very important thing is, before you reinstall the new convergence IC, make sure you use a good coating of heat sink compound on the back of the new IC. If you do not, the IC will fail within a short time frames. Only if you are good with a soldering gun should you attempt the repair. If you are not, this repair should run you about 300 bucks or so. Also if you are handy, there are seven capacitors that go bad inside a board called the DM board. These will go bad very soon so while your in there these should be changed as well. If you need info on how to change these capacitors, let me know and leave an e-mail and I will send you the pictorial on how this is done. the IC change you will need to find that, but I do have a service manual if you need one also to help you along if you can follow the schematic. Good Luck
Posted on Nov 01, 2007
  • Larry  Dillon
    Larry Dillon Nov 01, 2007
    I need an e-mail address man.
Wavy lines green and orange hue.While watching a fooball game the status bar is wavy and in two separate lines-Green and Orange-Tried flash focus and convergence and powered unit off for several minutes...
Flash focus button push,didn't solved pictures convergence problems.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have an rca model hd52w67 tv and there is a problem with the picture. the picture has a red and green picture that don't allign by about an inch. I think it is in the picture guns but i cant find a...
Do not align the guns! they are located facing up toward the mirror; they are picture tubes! covered with big glass lenses! heavy!
instead look for a red/green/blue adjustment knob on the set's front; the buttons should say: convergence or, crosshatch push the crosshatch button: once you have three vertical lines crossing three horizontal lines; just merge them using the other R/G/B knobs untill you have one white vertical line and, one horizontal line crossing in the center of the screen.
(you may have to find the controls on the remote using "setup")
Feb 11, 2010 | RCA Televison & Video
Toshiba Rear Projection TV Picture Problems
The convergence circuits need to be replaced Sometimes it is just the matter of 4 capacitors and an IC but often than not ythe whole board has to be replaced.
Sep 02, 2009 | Toshiba 57HX81 57" Rear Projection...
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red Offset Image
yes the convergence ICs need to be replaced they are both STK392-120 ICs and you will also need four 6.8 ohm 1 watt resistors you can get replacment ICs and resistors at the following link and they provide free instalation instructions with pictures and free on line instant messageing to help you do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Aug 14, 2008 | Philips 55PW9363 55" Rear Projection...
Jvc av56wp74 blue shadow
my suggestion would be...to replace the focus block..john
Aug 10, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc av56pw74 blue shadow
You are going to need a full convergance alignment to rectify this issue.
Aug 09, 2007 | JVC AV-27720 27" TV
Wavy colors do not line up
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.eserviceinfo.com/
Oct 25, 2006 | Toshiba 56H80 56" Rear Projection...
BAD PICTURE
Well the green gun is whats inside the green picture tube or crt(cathode ray tube).. Irt certainly sounds like you have a problem with the convergence but the only way to tell for sure is put on a full cross hatch pattern like the one thats used for major alighnments such as after a tube is replace. This problem you have is probably the convergence IC and the part dosent unplug or come out easyly as there are no user serviceable parts inside this set. It should be left up to the service station for the manufacturer. Not alot you can do unless your a tech . Sorry Good luck
Jun 14, 2006 | Hitachi 43GX01B 43" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
