Question about Sport & Outdoor - Others
Caravan water heater not letting hot water through
We have a caravaer cascade 2 water heater in our caravan, the water heater works fine it is heating the water up but we can not get the water to come through the hot water taps in the shower room or the kitchen area,we were told that the return valve does seize on them so we have changed that and it is the same still no water coming through the hot taps . the cold water taps are fine
  • davies_famil Jun 20, 2009
    THANK YOU FOR YOU REPLAY WE HAVE SOLVED THE PROBLEM NOW THE PIPES WE BLOCKED .
    Sergeant:
    Champion:
  • 236 Answers
Pipes are rusted and cloggen from the inside of them
Posted on Jun 17, 2009
2003 Dodge Grand Caravan. Heater sometime blows hot but most often very cold when engine is at operating temp. Right now it is blowing cold and the line coming into the heater core is hot but the line out...
There should be a actuator valve on the line that determines if the heater core gets hot water or cold water. When the heater is selected, the actuator opens and lets hot water into the heater core. It sounds like that actuator is corroded and not opening.
Dec 10, 2017 | 2000 Dodge Caravan
The front passenger side of the floor is always 2005 DOdge Carava
Is it wet with water or coolant? If it is coolant you have a damaged heater core. If it is water it could be from a windshield with a bad seal, a leak in the floor or possibly an air conditioning system with a plugged drain tube. There is nothing else that would bring water in from the vehicle. If your are a cold climate and snow gets in on someone's boots it will melt and wait till dry weather to clear.
Dec 22, 2009 | 2005 Dodge Caravan
Carver cascade 2 No water at all comes out of the hot water outlet. The inlet non return valve has been changed & is working correctly.
Check the tank drain valve for water there.If you get a good water flow there you know the tank is getting water pressure.Check the first outlet downline from WH and if there is no water there you have a blockage or other problem.If you have to turn off water to tank, remove the outlet pipe ,and check for water flow from tank with in valve on.If no flow, tank is plugged up.
Hope this gets you going.
Oct 06, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Is it ok to drink the hot water from a carver cascade water heater?
Why would you want to do that? It should be ok. Its the same water as the cold, in a motor home or camper. just heated.
Sep 28, 2009 | 1997 Dodge Caravan
CARVER CASCADE 2
Hello .. when an electric water heater only gets warm, it is usually the thermostats. I would replace the thermostats, make notes where the wires are connected .. make sure after replacing that the back of the thermostat is flat against the metal of the tank.
Please Vote !!
Jul 05, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
No stop tap. cold water coming through cold taps in caravan but no hot water the carver cascade water heater is getting the water hot but it just wont come through the taps in the shower room or kitchen in...
your pipes are clogged, what if you were to not turn on the cold and turn on the hot does any water come out at all, with just the hot side turned on,, if not there could be a valve that has been turned off, or the pipes are clogged
Jun 17, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
No water coming out of carver cascade water heater
is the cold side hooked to the cold side if not you will be feeding the unit backwars making it to where the cold is just comming across the top of the tank, check the dip tube also, this makes the cold water go to the bottom and push the hot out of its outlet,, how many faucets are involved, if just one might want to check the cartridge to make sure it is working properly
Jun 16, 2009 | Reliance & 40 Gal Mobile Home Water Heater...
Carver cascade 2 burning smell
CASCADE 2 WATER HEATER WATER ISNT GETTING VERY HOT...HELP
Apr 02, 2009 | Heating & Cooling
Kenmore..Few years old came with the house
Check the spade/lug wiring connectors under the unit at the motors They can work loose. These newer units only use the heating element for a short time. If you get it running again do not use tablet soap. Start your sink's hot water until its too hot to touch then start the washer, let the tank fill then open the door and pour in an additional gallon of hot sink water mixed up with liquid cascade soap. To get "Energy Star" compliance, They have made trade offs to use less water and energy. When mine is running it still doesnt clean very well at all. consider installing a small R.V. water heater under the sink or nearby.
Also make sure your drain hose is clear and has no kinks in it.
Jan 01, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Sport & Outdoor - Others Logo
117 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
